Salta al contenuto principale
iPad Mini 3 LTE Battery Replacement
Cosa ti serve
    1. iPad Mini 3 LTE Battery Replacement, iOpener Heating: passo 1, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement, iOpener Heating: passo 1, immagine 2 di 2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Mini 3 LTE Battery Replacement: passo 2, immagine 1 di 1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Mini 3 LTE Battery Replacement: passo 3, immagine 1 di 1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Mini 3 LTE Battery Replacement, Alternate iOpener heating method: passo 4, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement, Alternate iOpener heating method: passo 4, immagine 2 di 2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Mini 3 LTE Battery Replacement, LCD Shield Plate: passo 5, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement, LCD Shield Plate: passo 5, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement, LCD Shield Plate: passo 5, immagine 3 di 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Mini 3 LTE Battery Replacement: passo 6, immagine 1 di 1
      • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
      • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Mini 3 LTE Battery Replacement: passo 7, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 7, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 7, immagine 3 di 3
      • Carefully place a suction cup halfway up the heated side.
      • Be sure the cup is completely flat on the screen to get a tight seal.
      • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
      • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Mini 3 LTE Battery Replacement: passo 8, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 8, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 8, immagine 3 di 3
      • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
      • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
      • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Mini 3 LTE Battery Replacement: passo 9, immagine 1 di 1
      • Reheat and reapply the iOpener.
      • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
      • Let it rest for a few minutes to reheat the left edge of the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Mini 3 LTE Battery Replacement: passo 10, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 10, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 10, immagine 3 di 3
      • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
      • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad Mini 3 LTE Battery Replacement: passo 11, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 11, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 11, immagine 3 di 3
      • Continue moving the opening pick down the side of the display to release the adhesive.
      • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad Mini 3 LTE Battery Replacement: passo 12, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 12, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 12, immagine 3 di 3
      • Take the first pick you inserted and slide it up toward the top corner of the iPad.
      • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
      Chiedi a FixBot
      Aggiungi Commento
    9. iPad Mini 3 LTE Battery Replacement: passo 13, immagine 1 di 1
      • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
      • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
      • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
      Chiedi a FixBot
      Aggiungi Commento
    10. iPad Mini 3 LTE Battery Replacement: passo 14, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 14, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 14, immagine 3 di 3
      • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    11. iPad Mini 3 LTE Battery Replacement: passo 15, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 15, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 15, immagine 3 di 3
      • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
      • The third image shows where the front-facing camera and housing are in the iPad.
      • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
      Chiedi a FixBot
      Aggiungi Commento
    12. iPad Mini 3 LTE Battery Replacement: passo 16, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 16, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 16, immagine 3 di 3
      • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
      Chiedi a FixBot
      Aggiungi Commento
    13. iPad Mini 3 LTE Battery Replacement: passo 17, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 17, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 17, immagine 3 di 3
      • Leave the opening pick in the iPad slightly past the front-facing camera.
      • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
      • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
      Chiedi a FixBot
      Aggiungi Commento
    14. iPad Mini 3 LTE Battery Replacement: passo 18, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 18, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 18, immagine 3 di 3
      • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
      • Be very careful of the small antenna cable near the upper-right corner. Only slide the pick away from the camera—while sliding it in the opposite direction you may accidentally tear the antenna cable.
      Chiedi a FixBot
      Aggiungi Commento
    15. iPad Mini 3 LTE Battery Replacement: passo 19, immagine 1 di 1
      • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
      • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
      Chiedi a FixBot
      Aggiungi Commento
    16. iPad Mini 3 LTE Battery Replacement: passo 20, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 20, immagine 2 di 2
      • Slide the top right opening pick around the corner to fully release the top edge of the glass.
      • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
      Chiedi a FixBot
      Aggiungi Commento
    17. iPad Mini 3 LTE Battery Replacement: passo 21, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 21, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 21, immagine 3 di 3
      • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
      Chiedi a FixBot
      Aggiungi Commento
    18. iPad Mini 3 LTE Battery Replacement: passo 22, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 22, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 22, immagine 3 di 3
      • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    19. iPad Mini 3 LTE Battery Replacement: passo 23, immagine 1 di 1
      • Leave the opening picks in place and reheat the iOpener.
      • Remember not to overheat the iOpener—no more than once every ten minutes.
      • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
      Chiedi a FixBot
      Aggiungi Commento
    20. iPad Mini 3 LTE Battery Replacement: passo 24, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 24, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 24, immagine 3 di 3
      • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
      • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
      • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
      • Antennas
      • Home button cavity
      • Digitizer cable
      • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
      Chiedi a FixBot
      Aggiungi Commento
    21. iPad Mini 3 LTE Battery Replacement: passo 25, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 25, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 25, immagine 3 di 3
      • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
      • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
      • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
      • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
      • Leave the pick in place before moving on.
      Chiedi a FixBot
      Aggiungi Commento
    22. iPad Mini 3 LTE Battery Replacement: passo 26, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 26, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 26, immagine 3 di 3
      • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
      • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
      • Insert the pick slightly deeper and work it back toward the home button.
      • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
      Chiedi a FixBot
      Aggiungi Commento
    23. iPad Mini 3 LTE Battery Replacement: passo 27, immagine 1 di 1
      • Reheat and reapply the iOpener to the top bezel of the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    24. iPad Mini 3 LTE Battery Replacement: passo 28, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 28, immagine 2 di 2
      • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
      • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
      • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
      Chiedi a FixBot
      Aggiungi Commento
    25. iPad Mini 3 LTE Battery Replacement: passo 29, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 29, immagine 2 di 2
      • Lift slowly and gently to further detach the adhesive along the lower edge.
      Chiedi a FixBot
      Aggiungi Commento
    26. iPad Mini 3 LTE Battery Replacement: passo 30, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 30, immagine 2 di 2
      • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
      • If you plan to reuse the front panel assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
      Chiedi a FixBot
      Aggiungi Commento
    27. iPad Mini 3 LTE Battery Replacement: passo 31, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 31, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 31, immagine 3 di 3
      • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
      • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
      • Return the front-facing camera housing to its recess in the rear case.
      Chiedi a FixBot
      Aggiungi Commento
    28. iPad Mini 3 LTE Battery Replacement: passo 32, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 32, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Remove the following Phillips #00 screws securing the LCD:
      • Three 3.3 mm screws
      • One 4.5 mm screw
      • If there is tape covering any LCD screws, peel it up with tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    29. iPad Mini 3 LTE Battery Replacement: passo 33, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 33, immagine 2 di 2
      • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
      • Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
      • Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
      • Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
      Chiedi a FixBot
      Aggiungi Commento
    30. iPad Mini 3 LTE Battery Replacement: passo 34, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 34, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 34, immagine 3 di 3
      • The LCD is secured by mild adhesive that should be loosened before you flip the LCD up from its shield plate.
      • Insert the spudger between the LCD and LCD shield plate and slide it to the far edge of the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    31. iPad Mini 3 LTE Battery Replacement: passo 35, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 35, immagine 2 di 2
      • Two wide strips of tape connect the LCD to the speakers.
      • Hold the LCD with one hand, and the rear body of the iPad with the other.
      • Do not attempt to fully remove the LCD from the iPad.
      • Gently pull the LCD away from the speakers to separate the tape, being careful not to pull on the digitizer cable.
      Chiedi a FixBot
      Aggiungi Commento
    32. iPad Mini 3 LTE Battery Replacement: passo 36, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 36, immagine 2 di 2
      • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
      • Be gentle and keep an eye on the LCD cables as you flip the display over.
      • Lay the LCD on the front panel glass to allow access to the display cables.
      Chiedi a FixBot
      Aggiungi Commento
    33. iPad Mini 3 LTE Battery Replacement: passo 37, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 37, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 37, immagine 3 di 3
      • Slide the tip of a spudger between the LCD and the adhesive tabs to free the display.
      • Push gently between each of the two adhesive tabs; be careful not to damage any of the nearby cables.
      Chiedi a FixBot
      Aggiungi Commento
    34. iPad Mini 3 LTE Battery Replacement: passo 38, immagine 1 di 1
      • Remove the seven 1.8 mm Phillips #00 screws from the LCD shield plate.
      Chiedi a FixBot
      Aggiungi Commento
    35. iPad Mini 3 LTE Battery Replacement: passo 39, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 39, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 39, immagine 3 di 3
      • Use the flat end of a spudger to pry the LCD shield plate up and out of the iPad.
      • Remove the LCD shield plate.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Mini 3 LTE Battery Replacement, LCD: passo 40, immagine 1 di 1
      • Remove the following Phillips #00 screws from the display cable bracket:
      • One 2.8 mm screw
      • Three 1.4 mm screws
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Mini 3 LTE Battery Replacement: passo 41, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 41, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 41, immagine 3 di 3
      • Remove the display cable bracket from the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Mini 3 LTE Battery Replacement: passo 42, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 42, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 42, immagine 3 di 3
      • Use the tip of a spudger to lift the home button cable up off of its socket on the logic board.
      • Fold the home button ribbon cable out of the way.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Mini 3 LTE Battery Replacement: passo 43, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 43, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 43, immagine 3 di 3
      • Use the tip of a spudger to gently lift the battery connector up off its socket on the logic board.
      • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Mini 3 LTE Battery Replacement: passo 44, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 44, immagine 2 di 2
      • Use the tip of a spudger to lift the LCD connector up off its socket on the logic board.
      • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Mini 3 LTE Battery Replacement: passo 45, immagine 1 di 1
      • Lift and remove the LCD from the iPad Mini 3.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Mini 3 LTE Battery Replacement, Front Panel Assembly: passo 46, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement, Front Panel Assembly: passo 46, immagine 2 di 2
      • Use the tip of a spudger to lift the digitizer cable connector straight up off of its socket.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Mini 3 LTE Battery Replacement: passo 47, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 47, immagine 2 di 2
      • Slide the flat end of a spudger under the battery side of the digitizer board to begin separating it from the rear case.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Mini 3 LTE Battery Replacement: passo 48, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 48, immagine 2 di 2
      • Lift the digitizer board up to free the last of the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Mini 3 LTE Battery Replacement: passo 49, immagine 1 di 1
      • Lift and remove the front panel assembly from the iPad.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Mini 3 LTE Battery Replacement, Battery: passo 50, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement, Battery: passo 50, immagine 2 di 2
      • The battery is held to the iPad case with some adhesive that will need to be heated in order to be separated.
      • Heat an iOpener and place it in the center of the back of the iPad case.
      • After about two minutes, remove the iOpener and place it on the right side of the iPad—the side farthest from the camera.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Mini 3 LTE Battery Replacement: passo 51, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 51, immagine 2 di 2
      Plastic Cards
      $2.99
      • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
      • Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
      • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Mini 3 LTE Battery Replacement: passo 52, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 52, immagine 2 di 2
      • Remove the plastic card and insert it under the battery cell nearest the edge of the case.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Mini 3 LTE Battery Replacement: passo 53, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 53, immagine 2 di 2
      • Insert a second plastic card beneath the battery cell on the logic board side near the front-facing camera.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Mini 3 LTE Battery Replacement: passo 54, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 54, immagine 2 di 2
      • Remove and insert the second card under the battery near the headphone jack.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Mini 3 LTE Battery Replacement: passo 55, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 55, immagine 2 di 2
      • Grasp both cards and slowly pull the case-side battery cell up about two inches from the rear case.
      • Peel slowly and try not to bend the battery cell.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad Mini 3 LTE Battery Replacement: passo 56, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 56, immagine 2 di 2
      • Move the right-hand card up under the other battery cell.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad Mini 3 LTE Battery Replacement: passo 57, immagine 1 di 2 iPad Mini 3 LTE Battery Replacement: passo 57, immagine 2 di 2
      • Move the left-hand card up under the other battery cell.
      Chiedi a FixBot
      Aggiungi Commento
    9. iPad Mini 3 LTE Battery Replacement: passo 58, immagine 1 di 3 iPad Mini 3 LTE Battery Replacement: passo 58, immagine 2 di 3 iPad Mini 3 LTE Battery Replacement: passo 58, immagine 3 di 3
      • Grip both cards and use them to lift the battery from the rear case.
      • Remove the battery from the iPad.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
477.756 Reputazione
538 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
35.831 guide realizzate
2Commenti sulla guida
i appreciate your work and am near complete but saw no mention on home button switching out to new face, think i broke thecable.
Still haven't figured how to get it off.
Steven Greenberg - Rispondi Condividi
For safety reasons, fire proof gloves and eye protection is required. Have a fire blanket and extinguisher ready and it would be best to do this outside due to the lithium gas. These batteries burn at a very high temperature and do this very quickly.
mephone58 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 19
Ultimi 30 giorni: 55
Tutti i Tempi: 8,298
