Salta al contenuto principale
Xbox Series S Foot Replacement
Cosa ti serve
  1. Xbox Series S Foot Replacement, Set your Xbox down: passo 1, immagine 1 di 2 Xbox Series S Foot Replacement, Set your Xbox down: passo 1, immagine 2 di 2
    • Place your Xbox on your work surface so that the foot you're replacing is facing upward.
    Chiedi a FixBot
    Aggiungi Commento
  2. Xbox Series S Foot Replacement, Pry up the old foot: passo 2, immagine 1 di 3 Xbox Series S Foot Replacement, Pry up the old foot: passo 2, immagine 2 di 3 Xbox Series S Foot Replacement, Pry up the old foot: passo 2, immagine 3 di 3
    • This step shows how to remove a loose foot. If your Xbox is already missing the foot, skip this step!
    • Insert the point of a spudger underneath one end of the foot.
    • Pry up to separate the foot from the Xbox.
    • Remove the foot.
    Chiedi a FixBot
    Aggiungi Commento
  3. Xbox Series S Foot Replacement, Clean the footwell: passo 3, immagine 1 di 3 Xbox Series S Foot Replacement, Clean the footwell: passo 3, immagine 2 di 3 Xbox Series S Foot Replacement, Clean the footwell: passo 3, immagine 3 di 3
    • Cleaning the footwell will drastically help the new foot to stay on your Xbox.
    • Apply a drop of >70% isopropyl alcohol to the footwell.
    • Use the point of a spudger or a toothpick to scrape and loosen any adhesive residue in the footwell.
    • Wipe the footwell with a lint-free cloth or a coffee filter.
    Chiedi a FixBot
    Aggiungi Commento
  4. Xbox Series S Foot Replacement, Replace the foot: passo 4, immagine 1 di 3 Xbox Series S Foot Replacement, Replace the foot: passo 4, immagine 2 di 3 Xbox Series S Foot Replacement, Replace the foot: passo 4, immagine 3 di 3
    • Pick up a foot from the replacement sheet.
    • Align the foot in its footwell.
    • Use your finger to press the foot down for ten seconds to secure it onto your Xbox.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If your Xbox is missing additional feet, repeat the procedure to replace them.
Altre 2 persone hanno completato questa guida.
Arthur Shi
Membro da: 01/03/18
344.107 Reputazione
915 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
31.535 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 20
Ultimi 30 giorni: 105
Tutti i Tempi: 1,607
