Salta al contenuto principale
Cosa ti serve
Panoramica video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Steam Deck, usa il nostro manuale di assistenza.
    • Type 1: M1.6x9; plastic thread forming; 1.6 mm thread diameter; 0.64 mm thread pitch; 9 mm thread length; 2.8 mm head diameter; 0.6 mm head thickness
    • Type 2: M1.6x5; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 5 mm thread length; 2.8 mm head diameter; 0.5 mm head thickness
    • Type 3: M2x3.5; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 3.5 mm thread length; 5 mm head diameter; 0.9 mm head thickness
    • Type 4: M1.6x4.5; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4.5 mm thread length; 3.5 mm head diameter; 0.8 mm head thickness
    • Type 5: M1.6x3; machine screw; 1.6 mm thread diameter; 0.35 mm thread pitch; 3 mm thread length; 2.8 mm head diameter; 0.8 mm head thickness
    • Type 6: M2x2.2; machine screw; 2 mm thread diameter; 0.4 mm thread pitch; 2.2 mm thread length; 4.5 mm head diameter; 0.5 mm head thickness
    • Type 7: M1.6x4; plastic thread forming; 1.6 mm thread diameter; 0.53 mm thread pitch; 4 mm thread length; 3 mm head diameter; 0.8 mm head thickness
    • Type 8: M1.2x2; machine screw; 1.2 mm thread diameter; 0.25 mm thread pitch; 2 mm thread length; 2.2 mm head diameter; 0.4 mm head thickness
    Chiedi a FixBot
    Aggiungi Commento
  1. Steam Deck Screw ID, Back cover: passo 2, immagine 1 di 2 Steam Deck Screw ID, Back cover: passo 2, immagine 2 di 2
    • Type 1: M1.6x9 plastic thread forming screw
    • Type 2: M1.6x5 machine screw
    Chiedi a FixBot
    Aggiungi Commento
  2. Steam Deck Screw ID, Back cover removed: passo 3, immagine 1 di 2 Steam Deck Screw ID, Back cover removed: passo 3, immagine 2 di 2
    • Type 3: M2x3.5 machine screw
    • Type 4: M1.6x4.5 plastic thread forming screw
    • Type 5: M1.6x3 machine screw
    Chiedi a FixBot
    Aggiungi Commento
  3. Steam Deck Screw ID, Motherboard shield removed: passo 4, immagine 1 di 2 Steam Deck Screw ID, Motherboard shield removed: passo 4, immagine 2 di 2
    • Type 6: M2x2.2 machine screw
    Chiedi a FixBot
    Aggiungi Commento
  4. Steam Deck Screw ID, Trigger area: passo 5, immagine 1 di 2 Steam Deck Screw ID, Trigger area: passo 5, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  5. Steam Deck Screw ID, Bumper area: passo 6, immagine 1 di 2 Steam Deck Screw ID, Bumper area: passo 6, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  6. Steam Deck Screw ID, Trackpad area: passo 7, immagine 1 di 2 Steam Deck Screw ID, Trackpad area: passo 7, immagine 2 di 2
    • Type 7: M1.6x4 plastic thread forming screw
    Chiedi a FixBot
    Aggiungi Commento
  7. Steam Deck Screw ID, Midframe: passo 8, immagine 1 di 2 Steam Deck Screw ID, Midframe: passo 8, immagine 2 di 2
    Chiedi a FixBot
    Aggiungi Commento
  8. Steam Deck Screw ID, Under display: passo 9, immagine 1 di 2 Steam Deck Screw ID, Under display: passo 9, immagine 2 di 2
    • Type 8: M1.2x2 machine screw
    Chiedi a FixBot
    Aggiungi Commento
2Commenti sulla guida
Is there a way to convert these sizes to the ones used in the rest of the guides?
such as: M1.6x4= 4.7mm
Emojitsu Gaming - Rispondi Condividi
you need to update this for the oled screw sizes and include they are torx
james william runciman - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 76
Ultimi 30 giorni: 373
Tutti i Tempi: 12,279
