Salta al contenuto principale
Samsung Galaxy Note 4 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Note 4 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 56 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
92.828 Reputazione
89 guide realizzate
9Commenti sulla guida
I updated my phone and the problem is that my phone just goes all black all the time and my phone it won't turn on and sometimes my phone restarts by itself and after the carrier goes on and on after a few mins it repeatedly goes black.
Can someone please me what's wrong with my phone. I have a Samsung Note 4.
Jessica Lee - Rispondi Condividi
Seems like your mobile device may be stuck in whats called, BootLoop Mode.
Gabe - Rispondi Condividi
Yeah. One time my Note 4 did that too. It has an Otter case. What happened was I put the phone in topside down position into the rubber part. By mistake, of course. Corrected that and the problem was solved.
Tony - Rispondi Condividi
Each time I trimmed my nails. It was impossible to open the back cover and had to use a mini screwdriver to open. Quite inconvenient. So I attached a small piece of clear packing tape (not the flimsy Scotchtape) to the inside of the cover's recess, with enough length sticking out to the side. Grab that tape and pull back on the cover. Voila. The otter case covers the tape, so the phone looks normal in use.
hi
can i now its Compatibility with note 4 ( 2 sim ) ???? or Compatibility with 1 sim ????
aigoostore - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 17
Ultimi 30 giorni: 112
Tutti i Tempi: 35,567
