Salta al contenuto principale
Nokia G310 5G Back Cover Replacement
Cosa ti serve
  1. Nokia G310 5G Back Cover Replacement, Eject the SIM card tray: passo 1, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Eject the SIM card tray: passo 1, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Eject the SIM card tray: passo 1, immagine 3 di 3
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G310 5G Back Cover Replacement, Remove the SIM card tray: passo 2, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Remove the SIM card tray: passo 2, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Remove the SIM card tray: passo 2, immagine 3 di 3
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G310 5G Back Cover Replacement, Insert an opening pick: passo 3, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Insert an opening pick: passo 3, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Insert an opening pick: passo 3, immagine 3 di 3
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G310 5G Back Cover Replacement, Release the plastic clips: passo 4, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Release the plastic clips: passo 4, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Release the plastic clips: passo 4, immagine 3 di 3
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G310 5G Back Cover Replacement: passo 5, immagine 1 di 3 Nokia G310 5G Back Cover Replacement: passo 5, immagine 2 di 3 Nokia G310 5G Back Cover Replacement: passo 5, immagine 3 di 3
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G310 5G Back Cover Replacement: passo 6, immagine 1 di 3 Nokia G310 5G Back Cover Replacement: passo 6, immagine 2 di 3 Nokia G310 5G Back Cover Replacement: passo 6, immagine 3 di 3
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G310 5G Back Cover Replacement: passo 7, immagine 1 di 3 Nokia G310 5G Back Cover Replacement: passo 7, immagine 2 di 3 Nokia G310 5G Back Cover Replacement: passo 7, immagine 3 di 3
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G310 5G Back Cover Replacement, Flip open the back cover: passo 8, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Flip open the back cover: passo 8, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Flip open the back cover: passo 8, immagine 3 di 3
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G310 5G Back Cover Replacement, Unfasten the fingerprint reader bracket: passo 9, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader bracket: passo 10, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader bracket: passo 10, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader bracket: passo 10, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
  11. Nokia G310 5G Back Cover Replacement, Disconnect the fingerprint reader: passo 11, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Disconnect the fingerprint reader: passo 11, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Disconnect the fingerprint reader: passo 11, immagine 3 di 3
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G310 5G Back Cover Replacement, Release the fingerprint reader: passo 12, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Release the fingerprint reader: passo 12, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Release the fingerprint reader: passo 12, immagine 3 di 3
    • Using a pair of tweezers, grip the top of the fingerprint reader and lift it out and around the top plastic tab, separating it from the back cover.
  13. Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader: passo 13, immagine 1 di 3 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader: passo 13, immagine 2 di 3 Nokia G310 5G Back Cover Replacement, Remove the fingerprint reader: passo 13, immagine 3 di 3
    • Use a pair of tweezers to lift the fingerprint reader out of its bottom plastic tab.
    • Remove the fingerprint reader.
    • During reassembly, you'll need to transfer the fingerprint reader to the new back cover.
  14. Nokia G310 5G Back Cover Replacement, Only the back cover remains: passo 14, immagine 1 di 1
    • Only the back cover remains.
Conclusione
Altre 3 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
136 Membri
17.430 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 48
Tutti i Tempi: 441
