Salta al contenuto principale
Microsoft Surface Laptop 3 13.5" Feet Replacement
Cosa ti serve
  1. Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: passo 1, immagine 1 di 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Flip the laptop over: passo 1, immagine 2 di 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: passo 2, immagine 1 di 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Removal tip: passo 2, immagine 2 di 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: passo 3, immagine 1 di 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: passo 3, immagine 2 di 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the rear feet: passo 3, immagine 3 di 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: passo 4, immagine 1 di 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: passo 4, immagine 2 di 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Remove the front feet: passo 4, immagine 3 di 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: passo 5, immagine 1 di 2 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: passo 5, immagine 2 di 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: passo 6, immagine 1 di 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: passo 6, immagine 2 di 3 Microsoft Surface Laptop 3 13.5" Feet Replacement, Reassembly tip: passo 6, immagine 3 di 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Carsten Frauenheim
Membro da: 03/10/20
114.641 Reputazione
339 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.303 Guide realizzate
Un commento
Nice, that good for me, first time :D
TrungLun0112 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 165
Tutti i Tempi: 5,771
