Salta al contenuto principale
MSI GE62 Apache Pro 004 Web Camera Replacement
Cosa ti serve
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Start with the bottom of the laptop facing up.
    Chiedi a FixBot
    Aggiungi Commento
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 2, immagine 1 di 2 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 2, immagine 2 di 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate by pulling away from laptop
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
    Chiedi a FixBot
    Aggiungi Commento
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, immagine 1 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, immagine 2 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, immagine 3 di 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
    Chiedi a FixBot
    Aggiungi Commento
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: passo 4, immagine 1 di 1
    • Flip over the laptop and open it.
    Chiedi a FixBot
    Aggiungi Commento
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, immagine 1 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, immagine 2 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, immagine 3 di 3
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    Chiedi a FixBot
    Aggiungi Commento
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 6, immagine 1 di 2 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 6, immagine 2 di 2
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
    • Do not force off. Front screen panel is thing and can break or crack very easily.
    Chiedi a FixBot
    Aggiungi Commento
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 7, immagine 1 di 2 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 7, immagine 2 di 2
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro di USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 1,207
