Salta al contenuto principale
Lenovo Thinkpad T450 Internal Battery Replacement
Cosa ti serve
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: passo 1, immagine 3 di 3
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: passo 2, immagine 1 di 1
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: passo 3, immagine 1 di 3 Lenovo Thinkpad T450 Internal Battery Replacement: passo 3, immagine 2 di 3 Lenovo Thinkpad T450 Internal Battery Replacement: passo 3, immagine 3 di 3
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: passo 4, immagine 1 di 2 Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: passo 4, immagine 2 di 2
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: passo 5, immagine 1 di 2 Lenovo Thinkpad T450 Internal Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: passo 6, immagine 1 di 1
    • Lift up and remove the battery from the device.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 2 persone hanno completato questa guida.
Justin Ogihara
Membro da: 09/18/17
27.236 Reputazione
52 Guide realizzate
EDU Team Membro di EDU Team
Staff
7 Membri
637 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 161
Tutti i Tempi: 4,397
