Salta al contenuto principale
Lenovo ThinkPad T480s Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  2. Lenovo ThinkPad T480s Keyboard Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad T480s Keyboard Replacement: passo 2, immagine 2 di 2
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  3. Lenovo ThinkPad T480s Keyboard Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T480s Keyboard Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T480s Keyboard Replacement: passo 3, immagine 3 di 3
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  4. Lenovo ThinkPad T480s Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad T480s Keyboard Replacement: passo 4, immagine 2 di 2
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  5. Lenovo ThinkPad T480s Keyboard Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad T480s Keyboard Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad T480s Keyboard Replacement: passo 5, immagine 3 di 3
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  6. Lenovo ThinkPad T480s Keyboard Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad T480s Keyboard Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad T480s Keyboard Replacement: passo 6, immagine 3 di 3
    • Use the spudger to disconnect the keyboard cable from the system.
  7. Lenovo ThinkPad T480s Keyboard Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T480s Keyboard Replacement: passo 7, immagine 2 di 2
    • Lift the keyboard off of the palm rest.
Conclusione
Altre 2 persone hanno completato questa guida.
Sarah Westberg
Membro da: 03/11/19
23.384 Reputazione
70 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.449 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 63
Ultimi 30 Giorni: 252
Tutti i Tempi: 5,970
