Salta al contenuto principale
Lenovo Ideapad 320-15IAP Battery Replacement
Cosa ti serve
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: passo 2, immagine 1 di 1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: passo 3, immagine 1 di 1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: passo 4, immagine 1 di 2 Lenovo Ideapad 320-15IAP Battery Replacement: passo 4, immagine 2 di 2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: passo 5, immagine 1 di 2 Lenovo Ideapad 320-15IAP Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 44
Tutti i Tempi: 1,098
