Salta al contenuto principale
How to Troubleshoot Bootloop Issues in an iPhone
Guida video
Questa guida è stata trascritta da un video di YouTube.
Cosa ti serve
    • Press the power button with the iPhone unplugged and check whether the screen stays dark.
    • A battery-related case may show no empty-battery icon and no reaction on battery power.
    • Connect the iPhone to a charging cable or charging station with a current display.
    • Watch for an Apple logo that appears, disappears, and repeats without the phone starting.
    • A charging station may supply about 5.1 V while the current draw sits around 0.1 to 0.3 A and drops to 0 A when the logo goes dark.
    • A normal iPhone charging current is usually about 0.7 to 1 A.
    • The battery may be too discharged, damaged, unable to deliver current, or unable to communicate with the logic board.
    • Bootloops can also come from logic board faults, so this battery replacement is only one likely fix.
    Chiedi a FixBot
    Aggiungi Commento
    • Unplug the iPhone and wait for the screen to go dark before opening it.
    • If the battery is swollen, hot, punctured, or smells sweet, stop and handle it as a fire hazard.
    • Don't bend, puncture, crush, or overheat a lithium-ion battery.
    • Use non-metal tools around the battery connector whenever possible to avoid shorts.
    • Keep the screws, rear case, and small battery contact organized for reassembly.
    Chiedi a FixBot
    Aggiungi Commento
    • Use a pentalobe screwdriver or T5 Torx screwdriver to remove the two bottom screws.
    • Press the rear case and slide it toward the top edge by a few millimeters.
    • Lift the rear case away from the iPhone.
    • Don't force the rear case because the small clips can break.
    • This opening method applies to the iPhone 4S used for this guide; other iPhone models may open differently.
    Chiedi a FixBot
    Aggiungi Commento
    • Use a Phillips screwdriver to remove the two screws near the battery connector.
    • Lift the battery connector from its socket with a fingernail, nylon tool, or plastic tool.
    • Don't use a metal tool to lift the battery connector.
    • Use tweezers to remove the small contact near the battery connector.
    • Keep the small contact safe because it helps cellular reception.
    Chiedi a FixBot
    Aggiungi Commento
    • Pull the battery removal tab if it is still attached and strong enough to lift the battery.
    • If the tab is missing or broken, slide a long flat plastic tool under the battery from the outer edge.
    • Lever the battery up slowly until the old adhesive releases.
    • Don't pry from the logic board side because the tool can press on and damage the logic board.
    • Don't puncture or sharply bend the battery while loosening the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
    • Remove the old battery adhesive and any broken pull tab pieces from the battery well.
    • Apply fresh double-sided adhesive where the new battery will sit.
    • For an iPhone 4 or 4S, use double-sided adhesive if model-specific battery adhesive strips aren't available.
    • Precut battery adhesive strips are ideal when they fit the model.
    • Cut oversized adhesive to fit the battery area.
    • Use tweezers to peel one liner from the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
    • Place the exposed side of the adhesive in the battery well.
    • Press the adhesive down lightly so it bonds to the case.
    • Don't press hard because the display is on the other side of the case.
    • Warm the adhesive very lightly with a heat source if it needs help sticking.
    • Don't overheat the case because the backlight is directly behind this area.
    • Peel off the remaining adhesive liner while the adhesive is slightly warm.
    Chiedi a FixBot
    Aggiungi Commento
    • Connect the new battery before seating it if its flex cable isn't pre-folded.
    • Use the connected flex cable to guide the battery into position without straining it.
    • Don't pinch or scrape nearby flex cables while lowering the battery.
    • Press the battery onto the double-sided adhesive so it stays in place.
    Chiedi a FixBot
    Aggiungi Commento
    • Lift the battery connector enough to place the small contact back in position.
    • Use tweezers to install the small contact near the battery connector.
    • Press the battery connector back onto its socket.
    • Align the screw holes in the connector area.
    • Use a Phillips screwdriver to reinstall the two screws near the battery connector.
    • Make sure the small contact stays in place while you tighten the screws.
    Chiedi a FixBot
    Aggiungi Commento
    • Set the rear case a few millimeters above its fully closed position.
    • Slide the rear case downward until it seats.
    • Don't force the rear case; check for a trapped screw, leftover part, or missing part if it resists.
    • Use a pentalobe screwdriver or T5 Torx screwdriver to reinstall the two bottom screws.
    • Tighten the bottom screws until they are seated.
    Chiedi a FixBot
    Aggiungi Commento
    • Connect the iPhone to the charging cable or charging station.
    • A 0 A reading is normal before the charging cable is connected.
    • A very low reading, such as 0.05 A, can appear while the phone starts using battery power.
    • Wait for the iPhone to boot.
    • Watch for the charging current to rise into the normal range.
    • A stable reading around 0.9 A indicates normal charging.
    • The iPhone may vibrate when it starts.
    • Confirm the battery percentage rises after a short charge.
    Chiedi a FixBot
    Aggiungi Commento
    • Treat a running phone that charges around 0.45 A as suspect because it may charge about half as fast as normal.
    • Use a battery charging station to test or recharge the removed battery if you have one.
    • Disconnect the iPhone; the charging station should return to 0 A with nothing connected.
    • Connect the removed battery to the iPhone 4S port on the battery charging station.
    • Watch whether the current stabilizes, because a bad contact may cause unstable readings.
    • A removed battery that accepts 1.7 to nearly 2 A can still have been too discharged for the phone to detect.
    • The battery circuit may also fail to communicate with the logic board.
    • Test the removed battery in another phone if you need confirmation and can do so safely.
    Chiedi a FixBot
    Aggiungi Commento
    • Use a replacement battery that is known to work with the exact iPhone model.
    • Compatible batteries may use generic lithium cells with either a compatible generic circuit or a refurbished original charge circuit.
    • Batteries with refurbished original charge circuits and new lithium cells are usually the most compatible type.
    • Generic batteries may start the phone but fail to charge correctly or communicate with the logic board.
    • If the bootloop remains and current still drops to 0 A, troubleshoot logic board faults.
    • Battery replacement is an easy test for this bootloop pattern, but it isn't the only possible fix.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If the iPhone boots and charging current stays near the normal range, let the new battery charge before regular use. Recycle the old battery through a battery recycler. Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
The Repair Academy Membro di The Repair Academy
Business
Membro di 1
22 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 14
Ultimi 7 giorni: 49
Ultimi 30 giorni: 49
Tutti i Tempi: 49
