Salta al contenuto principale
Google Pixel 9a Wireless Charging Assembly Replacement
Cosa ti serve
  1. Google Pixel 9a Wireless Charging Assembly Replacement, Safety precautions: passo 1, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 9a Wireless Charging Assembly Replacement, Heat the rear cover: passo 2, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Heat the rear cover: passo 2, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Heat the rear cover: passo 2, immagine 3 di 3
    • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover.
    • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 9a Wireless Charging Assembly Replacement, Apply a suction handle: passo 3, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Apply a suction handle: passo 3, immagine 2 di 2
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 9a Wireless Charging Assembly Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 9a Wireless Charging Assembly Replacement, Adhesive information: passo 5, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Adhesive information: passo 5, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Adhesive information: passo 5, immagine 3 di 3
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 9a Wireless Charging Assembly Replacement, Separate the rear cover adhesive: passo 6, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Separate the rear cover adhesive: passo 6, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Separate the rear cover adhesive: passo 6, immagine 3 di 3
    • If you ever have trouble separating the adhesive, apply more heat and try again.
    • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 9a Wireless Charging Assembly Replacement: passo 7, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 7, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 7, immagine 3 di 3
    • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
    • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 9a Wireless Charging Assembly Replacement, Separate the camera bezel adhesive: passo 8, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Separate the camera bezel adhesive: passo 8, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Separate the camera bezel adhesive: passo 8, immagine 3 di 3
    • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
    • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the rear cover: passo 9, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the rear cover: passo 9, immagine 2 di 2
    • Remove the rear cover.
    • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the camera bezel: passo 10, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the camera bezel: passo 10, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the camera bezel: passo 10, immagine 3 di 3
    • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
    • Slide an opening pick under the camera bezel and pry up to remove it.
    • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
    • If you're having trouble, lightly heat the camera bezel.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: passo 11, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: passo 11, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Magnetic Project Mat
    $16.96
    • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Thirteen 5.0 mm‑long screws
    • Three 2.2 mm‑long screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 9a Wireless Charging Assembly Replacement, Unclip the wireless charging assembly: passo 12, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Unclip the wireless charging assembly: passo 12, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Unclip the wireless charging assembly: passo 12, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the wireless charging assembly: passo 13, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the wireless charging assembly: passo 13, immagine 2 di 2
    • Remove the wireless charging assembly.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 9a Wireless Charging Assembly Replacement, Disassembly complete: passo 14, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old adhesive: passo 15, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old adhesive: passo 15, immagine 2 di 2
    • Use a spudger to scrape up and remove the six small pieces of adhesive around the rear cameras.
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives that were removed.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 16, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 16, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 16, immagine 3 di 3
    • Remove the larger, clear liner from the inner housing adhesive and lay it in place around the camera holes.
    • Use the cutouts for the small silver pads to help align the adhesive.
    • Use the flat end of a spudger to firmly push down on each piece of adhesive, securing them in place.
    • Remove the colored liner using the pull tab on the top edge.
    • If the adhesive starts to pull up with the liner, lay it back in place and use your spudger to secure it again.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 17, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 17, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 17, immagine 3 di 3
    • Use a spudger to firmly press down on each of the six pieces of inner housing adhesive to secure them.
    • These pieces of adhesive can easily be pulled up when removing the final liners, so make sure they're firmly in place.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 9a Wireless Charging Assembly Replacement, Install the wireless charging assembly: passo 18, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Install the wireless charging assembly: passo 18, immagine 2 di 2
    • Place the wireless charging assembly onto the frame.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 9a Wireless Charging Assembly Replacement: passo 19, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 19, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 19, immagine 3 di 3
    • Use your fingers to firmly press around the perimeter of the wireless charging assembly to re‑engage all of its clips.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 9a Wireless Charging Assembly Replacement, Install the wireless charging assembly screws: passo 20, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Install the wireless charging assembly screws: passo 20, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to install the 16 screws securing the wireless charging assembly:
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old rear cover adhesive: passo 21, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old rear cover adhesive: passo 21, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old rear cover adhesive: passo 21, immagine 3 di 3
    • Take your time during the next two steps. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    • When removing the rear cover adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
    • Use a spudger and tweezers to scrape up and remove all the old rear cover adhesive from the perimeter of your phone.
    • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 9a Wireless Charging Assembly Replacement, Clean the frame: passo 22, immagine 1 di 1
    • Using some high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter), clean the areas of the frame where the adhesive was.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 9a Wireless Charging Assembly Replacement, Find the adhesive orientation: passo 23, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Find the adhesive orientation: passo 23, immagine 2 di 2
    • Before applying the rear cover adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use the camera cutout in the liner to help visualize how it will lay on the frame.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 9a Wireless Charging Assembly Replacement, Peel the liner halfway down: passo 24, immagine 1 di 1
    • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 25, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 25, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 25, immagine 3 di 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved once you apply it.
    • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners with your fingers to secure the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 9a Wireless Charging Assembly Replacement: passo 26, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 26, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 26, immagine 3 di 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the top liner: passo 27, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the top liner: passo 27, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the top liner: passo 27, immagine 3 di 3
    • Use the pull tab to remove the large, colored liner.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 28, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 28, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 28, immagine 3 di 3
    • Use a spudger to press down firmly on the adhesive around the perimeter of your phone to secure it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old camera bezel adhesive: passo 29, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old camera bezel adhesive: passo 29, immagine 2 di 2
    • If the camera bezel detached when removing the rear cover, follow the next five steps to install it. Otherwise, skip down five steps.
    • Use a spudger to scrape up and remove any of the old adhesive from the camera bezel and its corresponding spot on the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the adhesive residue: passo 30, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the adhesive residue: passo 30, immagine 2 di 2
    • Use high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any adhesive residue from the camera bezel and its corresponding spot on the rear cover.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 31, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 31, immagine 2 di 2
    • Remove the large, clear liner from the camera bezel adhesive.
    • Put the adhesive over the top of the camera bezel and set it in place.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 9a Wireless Charging Assembly Replacement: passo 32, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 32, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 32, immagine 3 di 3
    • Use a spudger to firmly press around the perimeter of the camera bezel to secure the adhesive.
    • Remove the second, colored liner from the camera bezel adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 9a Wireless Charging Assembly Replacement, Install the camera bezel: passo 33, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Install the camera bezel: passo 33, immagine 2 di 2
    • Align the camera bezel such that the square foam is closest to the edge.
    • Use your fingers to press the camera bezel into place on the rear cover, squeezing firmly around the perimeter to secure it with the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old rear cover adhesive: passo 34, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the old rear cover adhesive: passo 34, immagine 2 di 2
    • Use the flat end of a spudger to scrape up and remove any all the old adhesive that stayed on the back cover, including the five pieces of small, oval‑shaped adhesive.
    • If you don't see all the oval adhesives, some might've stuck to the phone frame.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel 9a Wireless Charging Assembly Replacement: passo 35, immagine 1 di 1
    • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives you removed.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 36, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Apply the adhesive: passo 36, immagine 2 di 2
    • Remove the larger, clear liner from the back cover inner adhesive.
    • Lay the adhesive onto the bottom of the back cover, making sure the cutout goes around the camera bezel.
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 37, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement, Secure the adhesive: passo 37, immagine 2 di 2
    • Use your fingers or a spudger to firmly push down on the five small adhesives to secure them to the back cover.
    • Slowly peel up and remove the remaining liner.
    • If the adhesives start to peel up with the liner, lay it back down and use your spudger to secure the adhesive again.
    Chiedi a FixBot
    Aggiungi Commento
  38. Google Pixel 9a Wireless Charging Assembly Replacement, Remove the remaining liners: passo 38, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the remaining liners: passo 38, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Remove the remaining liners: passo 38, immagine 3 di 3
    • Use the point of a spudger to lift and remove the plastic liners from the adhesive around the rear cameras.
    Chiedi a FixBot
    Aggiungi Commento
  39. Google Pixel 9a Wireless Charging Assembly Replacement: passo 39, immagine 1 di 2 Google Pixel 9a Wireless Charging Assembly Replacement: passo 39, immagine 2 di 2
    • Use the pull tabs to remove the final liner from the rear cover adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  40. Google Pixel 9a Wireless Charging Assembly Replacement, Install the rear cover: passo 40, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Install the rear cover: passo 40, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement, Install the rear cover: passo 40, immagine 3 di 3
    • Align the rear cover over the frame and press it into place.
    Chiedi a FixBot
    Aggiungi Commento
  41. Google Pixel 9a Wireless Charging Assembly Replacement: passo 41, immagine 1 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 41, immagine 2 di 3 Google Pixel 9a Wireless Charging Assembly Replacement: passo 41, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membro da: 09/14/22
191.426 Reputazione
1.204 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 27
Ultimi 30 giorni: 103
Tutti i Tempi: 1,448
