Salta al contenuto principale
Google Pixel 2 Motherboard Replacement
Cosa ti serve
  1. Google Pixel 2 Motherboard Replacement, Opening Procedure: passo 1, immagine 1 di 2 Google Pixel 2 Motherboard Replacement, Opening Procedure: passo 1, immagine 2 di 2
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 2 Motherboard Replacement: passo 2, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 2, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 2, immagine 3 di 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
    • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 2 Motherboard Replacement: passo 3, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 3, immagine 2 di 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 2 Motherboard Replacement: passo 4, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 4, immagine 2 di 2
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 2 Motherboard Replacement: passo 5, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 5, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 5, immagine 3 di 3
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 2 Motherboard Replacement: passo 6, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 6, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 6, immagine 3 di 3
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 2 Motherboard Replacement: passo 7, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 7, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 7, immagine 3 di 3
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
    • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 2 Motherboard Replacement: passo 8, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 8, immagine 2 di 2
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 2 Motherboard Replacement: passo 9, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 9, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Magnetic Project Mat
    $16.96
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 2 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the display cable bracket.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 2 Motherboard Replacement: passo 11, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 11, immagine 2 di 2
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 2 Motherboard Replacement, Midframe: passo 12, immagine 1 di 1
    • Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 2 Motherboard Replacement: passo 13, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 13, immagine 2 di 2
    • Slide the point of a spudger under the proximity sensor cable, starting from the side closest to the front-facing camera.
    • Gently lift the edge of the sensor cable until the sensor is perpendicular to the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 2 Motherboard Replacement: passo 14, immagine 1 di 1
    $16.96
    • Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
    • Remove the following screws securing the midframe:
    • Eleven 3.7 mm Phillips screws
    • One 4 mm T5 Torx screw
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 2 Motherboard Replacement: passo 15, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 15, immagine 2 di 2
    • Insert an opening tool into the notch in the midframe near the hold button.
    • Pry the midframe up enough to create a gap between it and the phone case. The midframe cannot yet be completely removed.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 2 Motherboard Replacement: passo 16, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 16, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 16, immagine 3 di 3
    • Lift the midframe up starting from the bottom edge.
    • When the midframe starts to make about a 45° with the rest of the phone, lift the midframe straight up and away from the phone.
    • As you lift the midfame, carefully guide the proximity sensor through the small slot in the midframe.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 2 Motherboard Replacement, Battery Connector: passo 17, immagine 1 di 2 Google Pixel 2 Motherboard Replacement, Battery Connector: passo 17, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 2 Motherboard Replacement, Motherboard: passo 18, immagine 1 di 2 Google Pixel 2 Motherboard Replacement, Motherboard: passo 18, immagine 2 di 2
    • use the flat end of a spudger to disconnect the charging assembly connector from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 2 Motherboard Replacement: passo 19, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 19, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 19, immagine 3 di 3
    • Insert a paperclip or SIM eject tool into the small hole on the left side of the phone and push until the SIM card tray pops out.
    • Remove the SIM card tray.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 2 Motherboard Replacement: passo 20, immagine 1 di 1
    • Remove the two 2.5 mm PH00 screws.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 2 Motherboard Replacement: passo 21, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 21, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 21, immagine 3 di 3
    • Disconnect two connectors at the bottom edge of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 2 Motherboard Replacement: passo 22, immagine 1 di 2 Google Pixel 2 Motherboard Replacement: passo 22, immagine 2 di 2
    • Pry up the motherboard using a plastic opening tool.
    • Remove the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 2 Motherboard Replacement: passo 23, immagine 1 di 3 Google Pixel 2 Motherboard Replacement: passo 23, immagine 2 di 3 Google Pixel 2 Motherboard Replacement: passo 23, immagine 3 di 3
    • Flip the motherboard over.
    • Disconnect the fingerprint sensor cable.
    • The motherboard is now completely detached from the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Nick Lyon
Membro da: 01/24/18
1.173 Reputazione
2 guide realizzate
Cal Poly, Team S18-G5, Livingston Winter 2018 Membro di Cal Poly, Team S18-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G5
4 Membri
12 guide realizzate
1Commento della guida
Rotated screen too far while removing it seems and the screen no longer turns on. Can't seem to get any signs of light/ sound out if the phone.
No way to shut down the phone without the screen either? So can't continue the repair until phone battery dies again.
Matthew Higgins - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 27
Ultimi 30 giorni: 93
Tutti i Tempi: 11,274
