Salta al contenuto principale
Fairphone 5 Front Camera Replacement
Cosa ti serve
  1. Fairphone 5 Front Camera Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 1
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Chiedi a FixBot
    Aggiungi Commento
  2. Fairphone 5 Front Camera Replacement, Pry up the back cover: passo 2, immagine 1 di 2 Fairphone 5 Front Camera Replacement, Pry up the back cover: passo 2, immagine 2 di 2
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
    Chiedi a FixBot
    Aggiungi Commento
  3. Fairphone 5 Front Camera Replacement, Remove the back cover: passo 3, immagine 1 di 3 Fairphone 5 Front Camera Replacement, Remove the back cover: passo 3, immagine 2 di 3 Fairphone 5 Front Camera Replacement, Remove the back cover: passo 3, immagine 3 di 3
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
    Chiedi a FixBot
    Aggiungi Commento
  4. Fairphone 5 Front Camera Replacement, Remove the battery: passo 4, immagine 1 di 3 Fairphone 5 Front Camera Replacement, Remove the battery: passo 4, immagine 2 di 3 Fairphone 5 Front Camera Replacement, Remove the battery: passo 4, immagine 3 di 3
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
    Chiedi a FixBot
    Aggiungi Commento
  5. Fairphone 5 Front Camera Replacement, Unfasten the connector cover: passo 5, immagine 1 di 2 Fairphone 5 Front Camera Replacement, Unfasten the connector cover: passo 5, immagine 2 di 2
    • Use a Phillips driver to remove the 3.9 mm-long screw securing the top unit connector cover at the bottom left corner.
    • The connector cover is labeled with a "1" and a triangle pointing downward.
    Chiedi a FixBot
    Aggiungi Commento
  6. Fairphone 5 Front Camera Replacement, Pry up the connector cover: passo 6, immagine 1 di 3 Fairphone 5 Front Camera Replacement, Pry up the connector cover: passo 6, immagine 2 di 3 Fairphone 5 Front Camera Replacement, Pry up the connector cover: passo 6, immagine 3 di 3
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the left edge of the connector cover.
    • Pry up the cover to separate it from the top unit.
    • The cover is connected to the top unit by a plastic cord. Don't try to completely remove it from the top unit.
    Chiedi a FixBot
    Aggiungi Commento
  7. Fairphone 5 Front Camera Replacement, Disconnect the top unit: passo 7, immagine 1 di 2 Fairphone 5 Front Camera Replacement, Disconnect the top unit: passo 7, immagine 2 di 2
    • While holding the cover out of the way, use a spudger to pry up and disconnect the top unit press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  8. Fairphone 5 Front Camera Replacement, Unfasten the top unit: passo 8, immagine 1 di 2 Fairphone 5 Front Camera Replacement, Unfasten the top unit: passo 8, immagine 2 di 2
    • Use a Phillips driver to remove the six 4.9 mm‑long screws securing the top unit.
    Chiedi a FixBot
    Aggiungi Commento
  9. Fairphone 5 Front Camera Replacement, Remove the top unit: passo 9, immagine 1 di 3 Fairphone 5 Front Camera Replacement, Remove the top unit: passo 9, immagine 2 di 3 Fairphone 5 Front Camera Replacement, Remove the top unit: passo 9, immagine 3 di 3
    • Insert the flat end of a spudger under the screw hole along the bottom edge of the top unit.
    • Pry up to release the clips securing the top unit to the phone frame.
    • During reassembly, insert the top edge of the top unit at a downward angle into the frame before pressing it down and re-engaging the clips.
    Chiedi a FixBot
    Aggiungi Commento
  10. Fairphone 5 Front Camera Replacement, Remove the front camera: passo 10, immagine 1 di 3 Fairphone 5 Front Camera Replacement, Remove the front camera: passo 10, immagine 2 di 3 Fairphone 5 Front Camera Replacement, Remove the front camera: passo 10, immagine 3 di 3
    • Use the tip of a spudger to pry up and disconnect the front camera press connector.
    • Lift the front camera out of its slot in the frame and remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Alex Diaz-Kokaisl
Membro da: 01/16/22
239.265 Reputazione
1.171 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 47
Tutti i Tempi: 1,057
