Salta al contenuto principale
Dell Precision 5520 Battery Replacement
Cosa ti serve
  1. Dell Precision 5520 Battery Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Precision 5520 Battery Replacement, Base Cover: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
    Chiedi a FixBot
    Aggiungi Commento
  2. Dell Precision 5520 Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 14 persone hanno completato questa guida.
RampUP America, Inc. Membro di RampUP America, Inc.
Community
45 Membri
2.002 guide realizzate
2Commenti sulla guida
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - Rispondi Condividi
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
Jason W Wines - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 17
Ultimi 30 giorni: 103
Tutti i Tempi: 15,702
