Salta al contenuto principale
Dell Inspiron 13-7352 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 13-7352 Battery Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 13-7352 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: passo 2, immagine 1 di 2 Dell Inspiron 13-7352 Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: passo 3, immagine 1 di 1
    • Gently remove the battery from the rest of the device.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Altre 8 persone hanno completato questa guida.
3 Commenti
Last I looked up for a different model there was a video..
pc2053 - Replica
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Replica
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 24,957
