Salta al contenuto principale
Acer Aspire E1-532-2616 Battery Replacement
Cosa ti serve
  1. Acer Aspire E1-532-2616 Battery Replacement, Battery: passo 1, immagine 1 di 2 Acer Aspire E1-532-2616 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Insert a small, skinny tool, such as a spudger, into the battery release latch.
  2. Acer Aspire E1-532-2616 Battery Replacement: passo 2, immagine 1 di 2 Acer Aspire E1-532-2616 Battery Replacement: passo 2, immagine 2 di 2
    • Slide the latch into the unlock position and pull the battery away from the laptop.
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,517
