Salta al contenuto principale
iPhone 6s Plus Home Button Assembly Replacement
Cosa ti serve
  1. iPhone 6s Plus Home Button Assembly Replacement, Pentalobe Screws: passo 1, immagine 1 di 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Home Button Assembly Replacement, Anti-Clamp instructions: passo 2, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement, Anti-Clamp instructions: passo 2, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement, Anti-Clamp instructions: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6s Plus Home Button Assembly Replacement: passo 3, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 3, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 3, immagine 3 di 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6s Plus Home Button Assembly Replacement, Opening Procedure: passo 4, immagine 1 di 1
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  5. iPhone 6s Plus Home Button Assembly Replacement: passo 5, immagine 1 di 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 6s Plus Home Button Assembly Replacement: passo 6, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 6, immagine 2 di 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  7. iPhone 6s Plus Home Button Assembly Replacement: passo 7, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 7, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 7, immagine 3 di 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  8. iPhone 6s Plus Home Button Assembly Replacement: passo 8, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 8, immagine 2 di 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  9. iPhone 6s Plus Home Button Assembly Replacement: passo 9, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 9, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 9, immagine 3 di 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  10. iPhone 6s Plus Home Button Assembly Replacement: passo 10, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 10, immagine 2 di 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  11. iPhone 6s Plus Home Button Assembly Replacement: passo 11, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 11, immagine 2 di 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  12. iPhone 6s Plus Home Button Assembly Replacement: passo 12, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 12, immagine 2 di 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  13. iPhone 6s Plus Home Button Assembly Replacement: passo 13, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 13, immagine 2 di 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  14. iPhone 6s Plus Home Button Assembly Replacement: passo 14, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 14, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 14, immagine 3 di 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  15. iPhone 6s Plus Home Button Assembly Replacement, Battery Connector: passo 15, immagine 1 di 1
    Magnetic Project Mat
    $16.96
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  16. iPhone 6s Plus Home Button Assembly Replacement: passo 16, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 16, immagine 2 di 2
    • Remove the battery connector bracket.
  17. iPhone 6s Plus Home Button Assembly Replacement: passo 17, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 17, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 17, immagine 3 di 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  18. iPhone 6s Plus Home Button Assembly Replacement: passo 18, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 18, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 18, immagine 3 di 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  19. iPhone 6s Plus Home Button Assembly Replacement, Display Assembly: passo 19, immagine 1 di 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  20. iPhone 6s Plus Home Button Assembly Replacement: passo 20, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 20, immagine 2 di 2
    • Remove the display cable bracket.
  21. iPhone 6s Plus Home Button Assembly Replacement: passo 21, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 21, immagine 2 di 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  22. iPhone 6s Plus Home Button Assembly Replacement: passo 22, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 22, immagine 2 di 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  23. iPhone 6s Plus Home Button Assembly Replacement: passo 23, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 23, immagine 2 di 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  24. iPhone 6s Plus Home Button Assembly Replacement: passo 24, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 24, immagine 2 di 2
  25. iPhone 6s Plus Home Button Assembly Replacement, Home Button Assembly: passo 25, immagine 1 di 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  26. iPhone 6s Plus Home Button Assembly Replacement: passo 26, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 26, immagine 2 di 2
    • Remove the home button bracket.
  27. iPhone 6s Plus Home Button Assembly Replacement: passo 27, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 27, immagine 2 di 2
    • Use the pointed tip of a spudger to disconnect the home button cable from its connector on the display assembly.
  28. iPhone 6s Plus Home Button Assembly Replacement: passo 28, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 28, immagine 2 di 2
    iOpener
    $24.99
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  29. iPhone 6s Plus Home Button Assembly Replacement: passo 29, immagine 1 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 29, immagine 2 di 3 iPhone 6s Plus Home Button Assembly Replacement: passo 29, immagine 3 di 3
    • Use the pointed end of a spudger to pry the lightly-adhered home button flex cable off the display assembly.
  30. iPhone 6s Plus Home Button Assembly Replacement: passo 30, immagine 1 di 2 iPhone 6s Plus Home Button Assembly Replacement: passo 30, immagine 2 di 2
    • Remove the home button assembly.
Conclusione
Altre 79 persone hanno completato questa guida.
Evan Noronha
Membro da: 02/05/15
228.028 Reputazione
168 Guide realizzate
14Commenti sulla guida
I swear a night time operation for a home button transfer was not easy! But... I pulled it off!
SerJay - Replica
Which part is difficult?
yinliangdl -
The only problem I experienced was that you have to re-use the black gasket around the home button. It was tricky to have to place it on the new home button, but I got it after a few tries.
Noah Donovan - Replica
can i still use the finger print scanner after changing the home button?
Ej Villar - Replica
No, the fingerprint scanner and logic board are paired during their manufacturing so if the original scanner is destroyed, you will never have Touch ID again. But you should regain the functionality of the button.
Dakota Martin -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 103
Ultimi 7 Giorni: 925
Ultimi 30 Giorni: 1,720
Tutti i Tempi: 57,571
