Salta al contenuto principale
iPad Wi-Fi Front Panel Assembly Replacement
Cosa ti serve
Panoramica video
    1. iPad Wi-Fi Front Panel Assembly Replacement, Display Assembly: passo 1, immagine 1 di 3 iPad Wi-Fi Front Panel Assembly Replacement, Display Assembly: passo 1, immagine 2 di 3 iPad Wi-Fi Front Panel Assembly Replacement, Display Assembly: passo 1, immagine 3 di 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Wi-Fi Front Panel Assembly Replacement: passo 2, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 2, immagine 2 di 2
      • In this guide you will be prying the iPad's display assembly away from the aluminum body. Read ahead and follow the directions closely to avoid damaging the display assembly or the fragile clips holding it in place.
      • There are 14 metal clips holding the display assembly in place, shown at left. As you pry in the following steps, do your best to pry around these clips and not slice through them with your opening tool.
      • If you do happen to break some clips, you can buy replacements here.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Wi-Fi Front Panel Assembly Replacement: passo 3, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 3, immagine 2 di 2
      • Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
      • Rotate the spudger away from you to release the tabs along the top edge of the display.
      • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Wi-Fi Front Panel Assembly Replacement: passo 4, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 4, immagine 2 di 2
      • With one spudger, work your way along the right edge of the iPad.
      • The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
      • Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
      • Pry carefully and gently—if you feel resistance, stop and pry at another spot.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Wi-Fi Front Panel Assembly Replacement: passo 5, immagine 1 di 1
      • Lift the display assembly away from the rear panel assembly by its bottom edge.
      • Do not attempt to remove the display at this time, as it is attached to the rear panel assembly.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Wi-Fi Front Panel Assembly Replacement: passo 6, immagine 1 di 1
      • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
      • Digitizer
      • Ambient Light Sensor
      • Display Data Cable
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad Wi-Fi Front Panel Assembly Replacement: passo 7, immagine 1 di 3 iPad Wi-Fi Front Panel Assembly Replacement: passo 7, immagine 2 di 3 iPad Wi-Fi Front Panel Assembly Replacement: passo 7, immagine 3 di 3
      • Use the edge of a plastic opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
      • Be sure you are flipping up the retaining flap, not the socket itself.
      • Pull the digitizer ribbon cables straight out of their sockets.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad Wi-Fi Front Panel Assembly Replacement: passo 8, immagine 1 di 1
      • Use a plastic opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
      Chiedi a FixBot
      Aggiungi Commento
    9. iPad Wi-Fi Front Panel Assembly Replacement: passo 9, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 9, immagine 2 di 2
      • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
      • Pull the cable connector away from its socket.
      • Pull the connector parallel to the face of the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    10. iPad Wi-Fi Front Panel Assembly Replacement: passo 10, immagine 1 di 1
      • Remove the display assembly from the rear panel assembly.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Wi-Fi Front Panel Assembly Replacement, Ambient Light Sensor: passo 11, immagine 1 di 3 iPad Wi-Fi Front Panel Assembly Replacement, Ambient Light Sensor: passo 11, immagine 2 di 3 iPad Wi-Fi Front Panel Assembly Replacement, Ambient Light Sensor: passo 11, immagine 3 di 3
      • If you are reusing the LCD, it is not necessary to peel the ambient light sensor off the back face of the LCD.
      • Use the edge of a plastic opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame.
      • Once you've gained enough clearance, peel the ambient light sensor off the LCD.
      • Be careful not to crease the ambient light sensor below its top section, as the portion with adhesive applied may break off.
      • If necessary, attach the plastic view window to your new ambient light sensor before installation.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Wi-Fi Front Panel Assembly Replacement, LCD: passo 12, immagine 1 di 1
      • While holding the digitizer cable down, carefully peel back the piece of tape connecting the digitizer cable to the display frame.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Wi-Fi Front Panel Assembly Replacement: passo 13, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 13, immagine 2 di 2
      • Remove the three T5 Torx screws securing the clips and LCD brackets covered in EMI tape near the home button switch.
      • Carefully peel the display clip and its attached tape off the black plastic display frame.
      • If you are replacing the LCD, be sure to transfer these pieces of EMI tape and their attached clips to the new LCD.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Wi-Fi Front Panel Assembly Replacement: passo 14, immagine 1 di 1
      • Remove the remaining T5 Torx screws securing the LCD to the black plastic display frame.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Wi-Fi Front Panel Assembly Replacement: passo 15, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 15, immagine 2 di 2
      • Insert the edge of a plastic opening tool under one of the ears attached to the steel LCD frame.
      • Twist the plastic opening tool to gently pry the LCD up off the adhesive securing it to the front glass panel.
      • Be sure not to excessively bend the LCD, as it is made of glass.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Wi-Fi Front Panel Assembly Replacement: passo 16, immagine 1 di 1
      • Repeat the process detailed on the previous step to pry up the display around the three sides opposite the digitizer cable side of the display.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Wi-Fi Front Panel Assembly Replacement: passo 17, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 17, immagine 2 di 2
      • Lift the LCD from its free end, and remove it from the display frame.
      • Carefully peel the adhesive securing the long side of the LCD to the display frame, then remove the LCD.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad Wi-Fi Front Panel Assembly Replacement: passo 18, immagine 1 di 1
      • If it is still stuck to the front panel, remove the strip of EMI tape near the ambient light sensor socket.
      • If necessary, transfer this to your new LCD.
      • If it is attached to the LCD and you are reusing the LCD, skip this step. If you are replacing the LCD as well, transfer the strip of EMI tape to your new LCD.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad Wi-Fi Front Panel Assembly Replacement: passo 19, immagine 1 di 1
      • If they are still in good shape, transfer the clips and EMI tape near the bottom of the LCD to your new LCD.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: passo 20, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: passo 20, immagine 2 di 2
      • Remove the two T5 Torx screws securing the home button switch to the plastic display frame.
      • Remove the home button switch board from the front panel assembly.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Wi-Fi Front Panel Assembly Replacement: passo 21, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 21, immagine 2 di 2
      • If you are reusing your LCD, use the edge of a plastic opening tool to lift up a corner of the foam tape attached to the LCD.
      • Remove the tape from the perimeter of the glass face of the LCD.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Wi-Fi Front Panel Assembly Replacement: passo 22, immagine 1 di 2 iPad Wi-Fi Front Panel Assembly Replacement: passo 22, immagine 2 di 2
      • Remove the piece of yellow tape securing the digitizer cable to the inner face of the front panel assembly, being careful not to rip the cable in the process.
      • Peel the protective sheeting off the inner face of the front panel assembly.
      • Be careful not to get any fingerprints or dust on the inner face of the front panel, as they will be annoyingly visible when the device is turned on.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Wi-Fi Front Panel Assembly Replacement: passo 23, immagine 1 di 1
      • Be sure the face of the LCD is perfectly clean before proceeding.
      • Stick the tape down along the long edge of the LCD to the frame of the front panel assembly.
      • Carefully lower the LCD down into its recess in the front panel frame, being sure it is properly positioned.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Wi-Fi Front Panel Assembly Replacement: passo 24, immagine 1 di 3 iPad Wi-Fi Front Panel Assembly Replacement: passo 24, immagine 2 di 3 iPad Wi-Fi Front Panel Assembly Replacement: passo 24, immagine 3 di 3
      • Hold back the strips of EMI tape along the lower edge of the LCD as you remove the two T5 Torx screws securing the retaining clips shown.
      • Stick the tape down against the new clips and reinstall the two T5 Torx screws.
      • If you are replacing your panel with a new one, be aware that the new panel may have a protective film on the outside and/or inside of the frame. This needs to be removed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Continue the installation by following the guide from Step 12 in reverse.
Altre 44 persone hanno completato questa guida.
1Commento della guida
LCD cable is easily trapped under lcd on reassembly without due care causing colour differences on snapping into place
scott corbett - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 54
Tutti i Tempi: 60,676
