Salta al contenuto principale
Sostituzione gruppo pannello anteriore iPad Mini WiFi
Cosa ti serve
  1. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Riscaldamento iOpener: passo 1, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Riscaldamento iOpener: passo 1, immagine 2 di 2
    • Ti raccomandiamo di pulire il tuo forno a microonde prima dell'operazione, perché ignobili entità unte e appiccicose potrebbero attaccarsi all'iOpener.
    • Disponi l'iOpener al centro del tuo forno a microonde.
    • Per forni a microonde con piatto rotante: assicurati che il piatto giri liberamente. Se l'iOpener si incastrasse da qualche parte, potrebbe surriscaldarsi e bruciare.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - Replica
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - Replica
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - Replica
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - Replica
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - Replica
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - Replica
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - Replica
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - Replica
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - Replica
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - Replica
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - Replica
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - Replica
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - Replica
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - Replica
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - Replica
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - Replica
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - Replica
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - Replica
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - Replica
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - Replica
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - Replica
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - Replica
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - Replica
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - Replica
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - Replica
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - Replica
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - Replica
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - Replica
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - Replica
    Can’t you just use a hair curler instead?
    Aspect22 - Replica
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - Replica
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - Replica
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - Replica
  2. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 2, immagine 1 di 1
    • Riscalda l'iOpener per 30 secondi.
    • Se durante la riparazione l'iOpener si raffredda, scaldalo di nuovo nel microonde per altri 30 secondi.
    • Fai attenzione a non surriscaldare l'iOpener durante l'operazione. Il surriscaldamento potrebbe far esplodere l'iOpener. Non scaldare sopra i 100°C (212°F)
    • Non toccare mai l'iOpener se appare gonfio.
    • Se l'iOpener è ancora troppo caldo in mezzo per poterlo toccare, continua a utilizzarlo mentre attendi che si raffreddi un po' prima di scaldarlo di nuovo. Un iOpener riscaldato correttamente dovrebbe rimanere caldo fino a 10 minuti.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - Replica
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - Replica
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - Replica
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - Replica
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - Replica
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - Replica
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - Replica
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - Replica
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - Replica
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - Replica
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - Replica
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - Replica
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - Replica
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    Get a heat gun.
    alesha adamson - Replica
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - Replica
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - Replica
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - Replica
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - Replica
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - Replica
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - Replica
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - Replica
  3. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 3, immagine 1 di 1
    • Rimuovi l'iOpener dal forno a microonde, afferrandolo per una delle due estremità piatte per evitare il contatto con la parte centrale calda.
    • L'iOpener sarà davvero caldissimo, perciò fai attenzione quando lo maneggi. Usa una presina da forno, se necessario.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - Replica
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - Replica
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - Replica
    This thing melts when placed up side down in the microwave…
    Mark - Replica
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - Replica
  4. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Metodo di riscaldamento alternativo per l'iOpener: passo 4, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Metodo di riscaldamento alternativo per l'iOpener: passo 4, immagine 2 di 2
    • Se non hai un microonde, segui questo passo per scaldare il tuo iOpener in acqua bollente.
    • Riempi una pentola o una padella con abbastanza acqua per immergerci un iOpener.
    • Scalda l'acqua finché non bolle. Spegni il fuoco.
    • Posiziona l'iOpener nell'acqua calda per 2-3 minuti. Assicurati che l'iOpener sia completamente immerso nell'acqua.
    • Usa delle pinze per estrarre l'iOpener scaldato dall'acqua calda.
    • Asciuga accuratamente l'iOpener con un asciugamano.
    • L'iOpener sarà molto caldo, quindi fai attenzione e tienilo solo dalle linguette alle estremità.
    • Il tuo iOpener è pronto all'uso! Se devi scaldare di nuovo l'iOpener, scalda l'acqua fino all'ebollizione, spegni il fuoco e immergi l'iOpener in acqua per 2-3 minuti.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - Replica
    Use a hair dryer
    Edited To the max - Replica
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - Replica
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - Replica
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - Replica
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - Replica
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
  5. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Vetro anteriore: passo 5, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Vetro anteriore: passo 5, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Vetro anteriore: passo 5, immagine 3 di 3
    • Se il tuo vetro è rotto, evita di romperlo ulteriormente e di tagliarti con le schegge coprendolo con del nastro adesivo.
    • Applica delle strisce di nastro adesivo trasparente da pacchi sul vetro, una sopra l'altra, finché non è completamente coperto.
    • Ciò conterrà le schegge di vetro e manterrà l'integrità strutturale quando dovrai fare leva e sollevare lo schermo.
    • Fai del tuo meglio per seguire il resto della guida come descritto. Comunque, una volta rotto il vetro, continuerà a rompersi mentre ci lavori e potresti dover usare uno strumento di apertura in metallo per rimuovere il vetro.
    • Indossa degli occhiali protettivi per proteggere gli occhi e stai attento a non danneggiare il pannello LCD.
    In case of broken glass, here are some hints:
    - I prefer 3M "3350" tape; a metalized polypropylene tape with an acrylic adhesive. It's a very thin, silvery HVAC tape, not your standard duct tape.
    - Test your tape to make sure it sticks really well to the glass.
    - Use isopropyl alcohol on a paper towel to remove fingerprints and other dirt to help the tape stick to the screen.
    - Use the widest tape you can find, and apply it evenly, without trapping bubbles, without crinkles: This greatly improves your chance of success with the suction cup later.
    - Cut tape pieces long enough and go over the (rounded) edge; afterwards carefully run a scalpel alongside the edge (between bezel and glass) to trim off any excess.
    - Don't overlap edges of the tape: butt-join them instead.
    - If needed: repeat in other direction.
    - If needed: Cut square piece of tape (size of suction cup) and place it where you want to lift the glass, so that the suction cup doesn't cover any butt-joins.
    Good luck, you brave person!
    volty - Replica
    This is the second broken screen I’ve fixed. Overlapped package tape carefully stuck to the glass and trimmed to the edges will contain most of the shards. I found that a hair dryer works for softening the glue. After getting under an edge with the suction cup I carefully followed the opening sequence using a combination of plastic picks and a single edge razor blade to get under the small pieces. It was slow going with lots of reheating with the dryer (about 45 minutes), but the taped glass came off without glass everywhere.
    Bill Roughen - Replica
  6. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 6, immagine 1 di 1
    • Prendendolo dalle alette, appoggia l'iOpener scaldato sul bordo a sinistra rispetto al tasto Home dell'iPad.
    • Lascia l'iOpener appoggiato per circa cinque minuti per ammorbidire l'adesivo sotto il vetro.
    I worked at it for over 2 hours before deciding to microwave the opener for 45 seconds at a time. That seemed to do the trick.
    jaromhyde - Replica
  7. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 7, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 7, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 7, immagine 3 di 3
    • Applica con cura una ventosa al centro del bordo scaldato.
    • Assicurati che la ventosa sia completamente piatta sullo schermo per avere una miglior presa.
    • Mentre tieni fermo l'iPad con una mano, tira verso l'alto la ventosa per separare leggermente il vetro dalla scocca.
    • Assicurati di sollevare il vetro giusto il necessario per infilarci un plettro: se lo sollevi di più potresti romperlo.
    This step is totally pointless if you have a shattered screen. The suction cup is rendered useless. Any tips on what to do if you can't get any suction due to a shattered screen?
    robloomis - Replica
    just pick out the glass shards if it is cracked that bad you are better off scrapping the digitizer
    echow2001 -
    for shattered screens I cover the screen with tape. I find packing tape works best for me.
    George - Replica
  8. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 8, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 8, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 8, immagine 3 di 3
    • Mentre tieni sollevato il vetro con la ventosa, infila la punta di un plettro nella fessura tra il vetro e la scocca dell'iPad.
    • Non infilare il plettro oltre la cornice nera del vetro. Inserendolo a profondità maggiore, potresti danneggiare il pannello LCD.
    • Tira la sporgenza sulla ventosa per rilasciarla e rimuovila dal gruppo dello schermo.
    you have to pull up on the suction cup harder than you might be comfortable with!
    jfaulks1 - Replica
    thanks jfaulks1 (I did not copy and paste lol)
    iliketrains kid - Replica
  9. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 9, immagine 1 di 1
    • Scalda di nuovo e riappoggia l'iOpener.
    • Stai attento a non surriscaldare l'iOpener durante la riparazione. Aspetta sempre almeno dieci minuti prima di riscaldare nuovamente l'iOpener.
    • Lascialo appoggiato per qualche minuto per riscaldare il bordo sinistro dell'iPad.
  10. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 10, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 10, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 10, immagine 3 di 3
    • Infila un secondo plettro accanto al primo e fallo scorrere sotto il bordo dell'iPad verso l'angolo inferiore per tagliare l'adesivo.
    • Durante tutta la procedura, se incontri troppa resistenza mentre fai scorrere i plettri sotto il vetro, fermati e riscalda la parte sulla quale stai lavorando. Fare troppa forza con i plettri può rompere il vetro.
  11. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 11, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 11, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 11, immagine 3 di 3
    • Continua a far scorrere il plettro lungo il bordo dello schermo verso il basso per tagliare l'adesivo.
    • Se il plettro si incastra nell'adesivo, "ruotalo" attorno al bordo dell'iPad per far staccare l'adesivo.
  12. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 12, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 12, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 12, immagine 3 di 3
    • Prendi il primo plettro che hai inserito e fallo scorrere sotto il vetro verso l'angolo superiore dell'iPad.
    • Se vedi la punta del plettro sotto il vetro, niente panico: semplicemente tira un po' indietro il plettro. Probabilmente tutto funzionerà ancora, ma cerca di evitare che succeda per non depositare dell'adesivo, che sarà poi difficile da rimuovere dal pannello LCD.
  13. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 13, immagine 1 di 1
    • Scalda di nuovo l'iOpener e appoggialo al bordo superiore dell'iPad, sopra la fotocamera frontale.
    • Se hai un iOpener flessibile, puoi piegarlo in modo da scaldare sia il bordo superiore sia l'angolo superiore sinistro allo stesso tempo.
    I left my iOpener on the bezel the entire time I slid picks in. worked great
    jfaulks1 - Replica
  14. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 14, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 14, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 14, immagine 3 di 3
    • Fai scorrere il plettro attorno all'angolo in alto a sinistra dell'iPad per tagliare l'adesivo.
    Gezz this is though! Cracked the glass while replacing it.
    Padraic Hoselton - Replica
    :( sad (rip glass lol)
  15. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 15, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 15, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 15, immagine 3 di 3
    • Fai scorrere il plettro lungo il bordo superiore dell'iPad, fermandoti subito prima di raggiungere la fotocamera.
    • La terza immagine mostra dove sono posizionati nell'iPad la fotocamera frontale e il suo supporto.
    • Evita di passare il plettro sopra la fotocamera frontale: potresti sporcare la lente con l'adesivo o danneggiare la fotocamera. I prossimi passaggi ti mostreranno come evitare al meglio di interferire con la camera frontale.
  16. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 16, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 16, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 16, immagine 3 di 3
    • Tira leggermente indietro il plettro e fai scorrere solo l'estremità della punta oltre la sezione della fotocamera frontale.
  17. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 17, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 17, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 17, immagine 3 di 3
    • Lascia il plettro infilato nell'iPad appena oltre la fotocamera frontale.
    • Prendi un altro plettro e infilalo a sinistra della fotocamera, dove sei già passato con il primo plettro. Fai scorrere questo plettro tornando indietro verso l'angolo in alto a sinistra per tagliare l'adesivo rimasto.
    • Lascia il secondo plettro infilato sotto l'angolo per evitare che l'adesivo si reincolli.
  18. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 18, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 18, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 18, immagine 3 di 3
    • Reinfila più a fondo nell'iPad il primo plettro e fallo scorrere allontanandolo dalla fotocamera verso l'angolo a destra.
    Shattered my screen pretty bad here, making it so that whenever I continued to move the pick the glass separated and I couldn’t continue moving it. Be VERY gentle moving the pick; almost no force is required.
    Jasper Holden - Replica
  19. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 19, immagine 1 di 1
    • Lascia i tre plettri sotto gli angoli dell'iPad per evitare che l'adesivo si reincolli.
    • Scalda di nuovo l'iOpener e appoggialo al rimanente lato lungo dell'iPad, quello destro dove ci sono i tasti di accensione e del volume.
  20. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 20, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 20, immagine 2 di 2
    • Fai scorrere il plettro nell'angolo in alto a destra attorno all'angolo stesso per staccare completamente il bordo superiore del vetro.
    • Lascia il plettro in questa posizione per evitare che l'adesivo si reincolli e prepara un altro plettro per il prossimo passaggio.
  21. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 21, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 21, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 21, immagine 3 di 3
    • Infila il plettro che hai preparato sotto l'angolo in alto a destra e fallo scorrere verso il centro del bordo destro dell'iPad per tagliare l'adesivo.
  22. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 22, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 22, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 22, immagine 3 di 3
    • Continua a far scorrere il plettro lungo il bordo destro dell'iPad per tagliare l'adesivo.
  23. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 23, immagine 1 di 1
    • Lascia i plettri sotto gli angoli e scalda di nuovo l'iOpener.
    • Ricorda di non surriscaldare l'iOpener: non scaldarlo più di una una volta ogni dieci minuti.
    • Appoggia l'iOpener riscaldato al bordo inferiore dell'iPad, sopra il tasto Home, e lascialo lì per qualche minuto per ammorbidire l'adesivo sotto il vetro.
  24. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 24, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 24, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 24, immagine 3 di 3
    • Fai scorrere il plettro sotto l'angolo in basso a sinistra attorno all'angolo per tagliare l'adesivo.
    • Lascia il plettro sotto l'angolo. Non andare oltre e non rimuovere il plettro dall'iPad.
    • Ci sono alcune componenti da evitare sotto il bordo inferiore, quindi presta attenzione alla terza immagine:
    • Antenne
    • Alloggio tasto Home
    • Cavo digitizer
    • I prossimi passaggi ti mostreranno dove fare leva per evitare queste componenti. Scalda e fai leva solo dove indicato.
  25. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 25, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 25, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 25, immagine 3 di 3
    • Lascia dove si trova il plettro che hai usato nell'ultimo passo dove si trova per evitare che l'adesivo si reincolli.
    • Infila un altro plettro e fallo scorrere delicatamente sopra l'antenna sinistra, fermandoti prima del tasto Home.
    • Fai scorrere il plettro solo verso il tasto Home dall'angolo sinistro. Non farlo scorrere in direzione opposta o potresti danneggiare l'antenna.
    • Se devi far scorrere il plettro lungo il bordo inferiore più di una volta, rimuovilo e reinfilalo vicino all'angolo e fallo scorrere verso il tasto Home.
    • Lascia il plettro vicino al tasto Home prima di procedere.
  26. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 26, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 26, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 26, immagine 3 di 3
    • Infila solo la punta di un ultimo plettro accanto a quello del passaggio precedente e fallo scorrere sotto il tasto Home.
    • Fermati a circa 25 mm dall'angolo destro per evitare di rompere il cavo del digitizer.
    • Infila il plettro più a fondo e fallo scorrere verso il tasto Home.
    • Come nell'ultimo passaggio, assicurati di far scorrere il plettro solo nella direzione che va dall'angolo verso il tasto Home quando è inserito a fondo, altrimenti potresti danneggiare l'antenna sotto il vetro.
  27. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 27, immagine 1 di 1
    • Scalda di nuovo e riappoggia l'iOpener al bordo superiore dell'iPad.
  28. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 28, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 28, immagine 2 di 2
    • Stai molto attento durante questo passaggio. Prenditi tutto il tempo necessario e assicurati che l'adesivo sia caldo e morbido e di aver tagliato abbastanza adesivo con i plettri. Non esitare a fermarti e scaldare di nuovo se necessario.
    • Sul bordo superiore dovresti avere un plettro infilato sotto ogni angolo. Torci i plettri per fare leva e sollevare leggermente il vetro, separando l'adesivo rimasto sotto i quattro bordi.
    • Se incontri troppa resistenza fermati. Lascia i plettri in posizione, scalda di nuovo e riappoggia l'iOpener e fai scorrere un plettro sotto il punto problematico un'altra volta.
  29. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 29, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 29, immagine 2 di 2
    • Solleva con cura e lentamente il bordo superiore per separare ulteriormente l'adesivo lungo il bordo inferiore.
    Really, add a few more pics and a few more picks, see how long and difficult you can make this guide. 26 steps to get the top screen off is ridiculous.
    B. A. Computer Services - Replica
  30. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 30, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 30, immagine 2 di 2
    • Una volta separato tutto l'adesivo, apri il vetro come la pagina di un libro e appoggialo sulla superficie di lavoro.
    • Se vuoi riusare il gruppo dello schermo, durante il rimontaggio dovrai sostituire l'adesivo. Segui la nostra guida per l'applicazione dell'adesivo dello schermo per farlo e sigillare di nuovo il dispositivo.
    I recommend wearing latex gloves or be sure not to put too many finger prints on the front or back of this front glass when lifting it or completing the remainder of the steps. I made this mistake and upon installing the new LCD and putting the iPad back together I realized that I left a few finger prints on the inside of the front glass. After re-securing the adhesive strips putting the iPad back together there are now unremovable fingerprints visible when the LCD is turned off. Just a recommendation on the gloves or be sure to wipe both sides of the front glass clean before putting all back together.
    Christian Screen - Replica
  31. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 31, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 31, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 31, immagine 3 di 3
    • Il supporto della fotocamera frontale potrebbe restare incollato al pannello anteriore: rimuovilo e rimettilo sulla fotocamera per proteggerla.
    • Fai oscillare il supporto attorno a uno dei suoi bordi per liberarlo dall'adesivo e poi rimuovilo dal pannello anteriore.
    • Rimetti il supporto della fotocamera frontale nel suo alloggio nel case posteriore.
    this didn’t happen to me BUT the glue was still sticking to the top of the glass because one pick had gone OVER the glue and the other under, so I had to pull the glue off and cut it with scissors
    jfaulks1 - Replica
    OK this was glue, it was the tape from step 35!
    jfaulks1 - Replica
  32. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo LCD: passo 32, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo LCD: passo 32, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo LCD: passo 32, immagine 3 di 3
    • Dei piccoli pezzi di schiuma adesiva coprono le viti in alto e in basso a destra di fissaggio del pannello LCD alla copertura posteriore.
    • Usa un paio di pinzette per rimuovere il pezzo di schiuma rettangolare sopra la vite del pannello in alto a destra.
    • Rimuovi il pezzo di schiuma triangolare sopra la vite del pannello in basso a destra.
  33. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 33, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 33, immagine 2 di 2
    • La vite del pannello LCD in alto a sinistra potrebbe essere coperta da del nastro adesivo del vetro anteriore.
    • Se il nastro è presente, usa la parte piatta di uno spudger per rimuoverlo, scoprendo la vite sottostante del pannello LCD.
  34. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 34, immagine 1 di 1
    • Svita le quattro viti a croce Phillips #000 che fissano il pannello LCD al case inferiore.
    In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
    mitja
    Mitja Jankovic - Replica
    Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
    Walter Galan -
    The top left screw is longer than the other 3 - iPad mini Retina Wi-Fi.
    sandro - Replica
    On mine the top right screw is longer
    oliver - Replica
    top right is longer on an ipad mini 2 retina wifi 32GB
    sagert - Replica
    ipad mini wifi no screws are longer
  35. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 35, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 35, immagine 2 di 2
    • Usa un paio di pinzette per rimuovere il piccolo pezzo di nastro adesivo che unisce la cornice del pannello LCD allo speaker destro.
    I wonder what does this sticker stands for…
    K8L - Replica
  36. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 36, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 36, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 36, immagine 3 di 3
    • Un sottile pezzo di schiuma adesiva sulla cornice del pannello LCD copre un pezzo di nastro adesivo che unisce la cornice del pannello LCD al pannello sottostante. Per procedere dovrai rompere e rimuovere parte della schiuma per scoprire il nastro nascosto sotto.
    • Usa un paio di pinzette per sollevare la schiuma adesiva attorno al pannello LCD.
    • Stai attento a non toccare il pannello LCD con le pinzette: potresti danneggiarlo.
    • Usa un paio di pinzette per sollevare la schiuma adesiva per scoprire la parte superiore del pannello LCD.
  37. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 37, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 37, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 37, immagine 3 di 3
    • Infila la punta di uno spudger tra la cornice del pannello LCD e il nastro sulla parte superiore del pannello.
    • Fai scorrere lo spudger lungo lo spazio tra la cornice del pannello LCD e il nastro adesivo, separando quest'ultimo dalla cornice.
    I finished a successful replacement of my screen following these instructions. Thanks.
    Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
    Kenneth Snyder - Replica
  38. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 38, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 38, immagine 2 di 2
    • Il pannello LCD è incollato alla schermatura di protezione in metallo sul retro del pannello lungo i bordi superiori, destro e sinistro. Per ammorbidire in sicurezza questo adesivo dovrai usare un plettro per spostare di qualche millimetro il pannello LCD a destra e a sinistra più volte.
    • Infila un plettro nella fessura tra il pannello LCD e la copertura posteriore, vicino alla parte superiore del bordo sinistro del pannello.
    • Inclina leggermente il plettro verso l'esterno dell'iPad, giusto il necessario per allargare la fessura tra il pannello LCD e la copertura posteriore.
    I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
    bababooey - Replica
    The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
    Brandon Lukasik - Replica
    This step is what destroys my LCDs :(
    Dan Harris - Replica
    Just destroyed my LCD as well. A red warning remarking is missing here! The LCD assembly is very fragile an cannot be bent, even slightly!!
    brauliox - Replica
    I have broken about 10 of the 50 or so iPad minis that I have repaired. I always try to have a LCD on hand. I’ll have to try the fishing line trick!
    northstar - Replica
    I also recommend doing step 45 first (removing the two pieces of foam tape at the bottom).
    northstar - Replica
    I was able to do this the first time w/out damaging the LCD simply by following the instructions to the letter, slowly and carefully. The only thing I did differently was to follow Northstar’s instructions to remove the two pieces of tape at the bottom of the LCD before beginning.
    Jenny Lawson - Replica
    I found a good way to remove the LCD without breaking it. Once you finish to clean up around the LCD just lift a bit one of the white metal backing plate and insert in the gap a plastified playing card under le LCD and slowly make your way to the center of the LCD. Repeat on the other side and the LCD will lift up intact.
    lemerise - Replica
    nothing Brocken after
    (I did not read the comments before doing it lol)
  39. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 39, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 39, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 39, immagine 3 di 3
    • Infila il plettro in tre altre posizioni lungo il bordo sinistro del pannello LCD e inclinalo in ogni posizione per far scorrere il pannello verso il bordo destro del case posteriore.
  40. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 40, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 40, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 40, immagine 3 di 3
    • Ora passa al lato destro del LCD, fai leva col plettro in diversi punti lungo il bordo per muovere il pannello LCD verso il bordo sinistro.
    • Ripeti un po' di volte questi ultimi due passaggi, finché il pannello LCD non riesci a muoverlo facilmente da destra a sinistra.
  41. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 41, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 41, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 41, immagine 3 di 3
    • Nei prossimi passi dovrai far scorrere uno spudger tra il pannello LCD e la piastra posteriore in metallo per separare del tutto il pannello dall'adesivo sottostante.
    • Infila la parte piatta di uno spudger tra la cornice del pannello LCD e la piastra posteriore in metallo.
    • Assicurati di infilare lo spudger tra la cornice del pannello LCD e la piastra di schermatura in metallo e non sotto la piastra stessa. Far leva direttamente sulla schermatura la danneggerà, in quanto è avvitata sul case posteriore sotto il pannello LCD.
  42. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 42, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 42, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 42, immagine 3 di 3
    • Iniziando nell'angolo in alto a destra del pannello, fai scorrere lo spudger tra la cornice del pannello LCD e la sua protezione in metallo, il che separerà l'adesivo man mano che avanzi.
    • L'obiettivo è separare l'adesivo, non di sollevare il pannello LCD, quindi tieni la punta dello spudger il più in basso possibile per evitare di piegare il pannello.
    • Se infilare lo spudger causa una piega nell'angolo del pannello, ripeti i passaggi precedenti con il plettro per ammorbidire ulteriormente l'adesivo.
    These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
    me to it was hard
  43. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 43, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 43, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 43, immagine 3 di 3
    • Ripeti la precedente procedura lungo il bordo superiore del pannello LCD.
    • Infila la parte piatta dello spudger tra la cornice del pannello LCD e la schermatura in metallo e spingilo delicatamente sotto al bordo superiore, separando l'adesivo.
  44. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 44, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 44, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 44, immagine 3 di 3
    • Continua con il bordo sinistro del pannello LCD: infila la parte piatta dello spudger tra il pannello LCD e la protezione e spingilo fino in fondo.
    • A questo punto il pannello LCD dovrebbe staccarsi dall'adesivo che lo teneva fermo. Se non succede, reinfila lo spudger sotto il bordo destro o superiore per separare del tutto il pannello.
  45. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 45, immagine 1 di 1
    • Solleva il pannello LCD di qualche centimetro dal case posteriore per assicurarti che si sia scollato del tutto.
    When I did it I found that the adhesive sticking was mainly on the edges, so if you take a spudger and just break that adhesive carefully it will help. Be gentle lifting the lcd as it’s very breakable.
  46. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 46, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 46, immagine 2 di 2
    • Due larghe strisce di nastro adesivo uniscono il pannello LCD agli altoparlanti.
    • Mentre tieni il pannello LCD con una mano, infila la parte piatta dello spudger nella fessura tra questo nastro e lo speaker sinistro.
    • Tira delicatamente il pannello via dagli altoparlanti mentre ruoti lo spudger verso l'esterno per rimuovere il nastro dallo speaker.
    I recommend removing these two pieces of foam tape prior to loosening and lifting the LCD.
    northstar - Replica
  47. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 47, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 47, immagine 2 di 2
    • Infila la parte piatta dello spudger nella fessura tra l'altoparlante destro e il nastro del pannello LCD.
    • Mentre tiri il pannello allontanandolo dagli speaker, ruota lo spudger verso l'esterno per allargare la fessura e rimuovere il nastro dall'altoparlante.
  48. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 48, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 48, immagine 2 di 2
    • Gira il pannello LCD a testa in giù e appoggialo sopra il vetro anteriore.
    • Non cercare di rimuovere il pannello dall'iPad: è ancora collegato con dei cavi.
  49. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Piastra di schermatura pannello LCD: passo 49, immagine 1 di 1
    • Svita le seguenti viti che fissano la protezione del pannello LCD alla copertura posteriore dell'iPad:
    • Due viti a croce Phillips #00 da 2,6 mm
    • Tredici viti a croce Phillips #00 da 1,7 mm
    • Una vite a croce Phillips #00 da 1,7 mm aggiuntiva su alcuni dispositivi.
    At the iPad mini retina Wi-Fi there are only 7 screws.
    sandro - Replica
    On my iPad Mini (Gen 1 WiFi; A1432), these are not #00 screws, but #000 screws. They're much tinier than the first four screws that held the LCD tabs in place. The #00 driver sorta works, but requires a lot of force to get traction. The #000 driver works like a charm, though.
    volty - Replica
    On my 1432 there were mixed in 4 tiny #000 screws holding the shield plate aong the right side. Looks like these can be mixed in without consequence as they are shorter anyway
    gfriedman99 - Replica
    I have a missing plate and screws
    Keah Smith - Replica
  50. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 50, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 50, immagine 2 di 2
    • Infila la parte piatta di uno spudger sotto il centro della piastra di schermatura del pannello LCD dal bordo inferiore.
    • Fai leva con lo spudger per sollevare la piastra dai bordi della scocca posteriore.
  51. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 51, immagine 1 di 1
    • Rimuovi la piastra metallica del pannello LCD dall'iPad.
    theres a lip on the rear case that prevents you from lifting this straight out, be careful to not bend the plate.
    jfaulks1 - Replica
    Once the LCD is clear of the shield, wiggle a long plastic spudger up the center between the shield and the battery to gently bend the shield. That will help in getting it away from the sides and make it easier to come out.
    Bill Shannon - Replica
  52. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Connettore batteria: passo 52, immagine 1 di 1
    • Svita le tre viti a croce Phillips #00 da 1,3 mm che fissano la copertura del connettore alla scheda madre.
    • Assicurati di non scambiare queste tre viti con delle altre, in particolare quelle che fissano la protezione del pannello LCD alla copertura posteriore dell'iPad. Qualsiasi vite leggermente più lunga potrebbe rovinare la presa della vite, causando un danno irreparabile alla scheda madre.
    Note: These three screws are smaller than the rest of the screws holding the larger LCD shield although they look similar. If you substitute the larger screws, you will pop a screw bracket which can damage the board on both the mini original and mini 2 retina. I just wrote a blog post about how this happens: http://mendonipadrehab.com/entries/gener...
    jessabethany - Replica
    Hi jessabethany. Thank you for the warning. I read your blog post and found it to be very informative. Thanks for adding the warning to the step. It will most definitely help others avoid any damage to the logic board. Thanks!
    Walter Galan -
    Be careful: At iPad mini retina Wi-Fi there are thw short and one longer screw! Don't mix them!
    sandro - Replica
  53. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 53, immagine 1 di 1
    • Usa un paio di pinzette per rimuovere la copertura del connettore dall'iPad.
  54. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 54, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 54, immagine 2 di 2
    • Usa uno strumenti di apertura in plastica per fare leva e sollevare delicatamente il connettore dalla sua presa sulla scheda madre.
    • Stai molto attento a fare leva sul connettore della batteria e non sulla presa. Se fai leva sulla presa sulla scheda madre, potresti danneggiare l'intero connettore.
    Make sure you disconnect the battery. If not and ipad is still on you can have problems with the LCD backlight. To fix that problem you have to solder
    Mattis - Replica
    I may be experiencing the backlight problem you mentioned. What connection needs to be soldered?
    Grillwrecka -
    Have an issue - heard that if you don't disconnect the battery a fuse is blown. I need help to fix the blown fuse.
    Andrew Kivell -
    There is an extensive thread in Answers about iPad mini backlight problems.Th screen stays black after a digitizer replacement.
    jessabethany -
    After unplugging the battery place a guitar pick in-between the two connections.
    While continuing to work on the iPad you may inadvertently cause the two connections to touch.
    Michael Vovaris - Replica
    Yeah, you need to put the pick in between the connections so the battery doesn't touch the logic board connector and blow a fuse and make your backlight not turn on. You really don't want to have to solder the 2 connections together, especially if you don't know how, like me! I will use your comment's advice when working.
    WolfyHD - Replica
    I put a piece of cellotape on the contact side of the connector and could happily forget about it while getting on with the rest of the repair.
    Rory Filer - Replica
  55. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Pannello LCD: passo 55, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Pannello LCD: passo 55, immagine 2 di 2
    • Usa uno strumento di apertura in plastica per fare leva e sollevare il connettore del pannello LCD dalla sua presa sulla scheda madre.
    • Non fare leva sul grande IC vicino al connettore, o potresti romperlo. Fai leva dal lato del connettore come mostrato nelle immagini.
    Putting the iPad back together: While plugging the LCD Connector back in, take your time finding the socket on the logic board. Do no use pressure until you are certain it is seated properly. Trust me, if you take your time you will know its seated correctly.
    Does it shares the same shape/size of the LCD connector between the ipad mini wifi only WHITE and the other one ipad mini 32gb BLACK?
    muhammadbukhari10 - Replica
  56. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 56, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 56, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 56, immagine 3 di 3
    • Il pannello LCD è ancora unito all'iPad da due larghe strisce di nastro adesivo che vanno dall'interno del case posteriore alla parte frontale del bordo inferiore della cornice del pannello.
    • Mentre tieni il pannello LCD con una mano, infila la parte piatta di uno spudger tra il pannello LCD e il nastro sul bordo destro dell'iPad.
    • Fai scorrere lo spudger verso l'esterno per separare l'adesivo, mentre sollevi delicatamente il pannello LCD per staccarlo dal nastro.
    • Può essere utile torcere lo spudger per allargare la fessura e separare il pannello dal nastro.
    Removing this tape and such to take the LCD off completely is unneccessary when replacing just the glass and digitizer, the digitizer cable is easily removed without further work to the LCD
    Dave Davidson - Replica
    When this tape damage, how we can take a new?
    Muhammed Kilic - Replica
    When this tape are damage, how we can order and take a new one?
    Following from Nick H’s comment about LCD removal being unnecessary - I tried that first and got my broken glass OUT of the assembly by threading it thru a limited space beneath the LCD. Later when trying to reseat the digitizer connector I gave up and removed the LCD anyhow. Not that much extra work but a LOT easier to install the digitizer and reseat the connector without having to navigate around the LCD and its cable. Removal of the tape holding the LCD was easy - there are two short lengths of rubber or foam along the bottom edge of the LCD that faces the outside world. Remove those(save them) and then _carefully_ peel up the tape; I saw some metallic looking residue underneath. Later when re-assembling everything, I put the tape back and then those two short lengths of foam.
    on mine this tape was already loose.
    jfaulks1 - Replica
  57. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 57, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 57, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 57, immagine 3 di 3
    • Mentre tieni il pannello LCD con una mano, passa al bordo sinistro dell'iPad e ripeti il passaggio precedente per rimuovere il secondo pezzo di nastro.
    • Infila la parte piatta di uno spudger tra il pannello LCD e il nastro e fallo scorrere verso l'esterno per separare l'adesivo mentre sollevi delicatamente il pannello LCD.
  58. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 58, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 58, immagine 2 di 2
    • Solleva e rimuovi il pannello LCD dall'iPad Mini.
  59. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo pannello anteriore: passo 59, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo pannello anteriore: passo 59, immagine 2 di 2
    • Stai molto attento a fare leva uniformemente sul connettore del digitizer, ma non sulla sua presa. La presa e il connettore sono molto delicati e se danneggi uno dei due il digitizer non funzionerà più.
    • Per ridurre lo sforzo sulla presa, prova a fare leva sotto i lati corti del connettore piuttosto che sotto quelli lunghi, come mostrato nelle immagini.
    • Fai leva delicatamente sul connettore del digitizer per sollevarlo dalla sua presa sulla scheda madre.
  60. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 60, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 60, immagine 2 di 2
    • Fai leva delicatamente sulla scheda del cavo del digitizer per sollevarla dal case posteriore.
    Be careful not to dislodge any of the surface mount components next to the connectors. This is sometimes a reason for the digitiser not working.
    Simon - Replica
    There is adhesive holding it down, so it may take some time to get it off. It helped me to push with my spudger on the piece with the yellow text instead from the same side.
    I put the iOpener under the iPad to weaken the adhesive for this step.
    Nathan Lloyd - Replica
  61. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 61, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 61, immagine 2 di 2
    • Solleva e rimuovi il pannello anteriore dall'iPad.
    == After step 55 ==
    Before installing your new digitizer (front panel), make sure to put the necessary bends on the new digitizer's ribbon cable. Look at the old panel that you've removed to see the bends that you'll need to make. Without doing this, once you are at the last step of laying down the digitizer, the cable may bunch-up in between the glass and the iPad's aluminum frame. Thus, it will not allow that corner to sit flush and glue down. If you didn't make the bends, you can use the tweezers at that point to situate the cable. It is just easier to do this beforehand. Do not make the bends as if you were folding paper. You run the risk of damaging the ribbon by doing so. You just want enough pressure to make the cable retain a bend. Again, look at and copy the cable from your old panel.
    Good Luck!!!!
    Mike - Replica
    If your panel is shattered, you may want to have some canned air to get rid of all those pesky little glass pieces that fly everywhere. I used a Giottos air blaster because that is all I had at my disposal.
    Mike -
    might be better to use a vacuum for safety reasons. you really dont want glass shards all over the place
    If your case corners are damaged from being dropped, seal across the corners with wide packing tape, then grind them out carefully with a small motor tool. Use a corner piece from the broken screen (adhesive side upwards) as the template. Keep removing aluminium until screen piece above fits snug and flat. Remove all traces of metal filings before reassembly.
    Jennifer Fordyce - Replica
    Good tip! Most times the corners are damaged.
    northstar -
  62. Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo pannello anteriore: passo 62, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi, Gruppo pannello anteriore: passo 62, immagine 2 di 2
    • Se stai installando un nuovo gruppo del pannello anteriore, potresti dover fare i seeguenti preparativi:
    • Rimuovi le coperture in plastica dell'adesivo attorno al perimetro del gruppo del pannello anteriore.
    • Rimuovi il piccolo pezzo di adesivo protettivo dal cavo del digitizer.
    • Assicurati che tutto il rame sia coperto sul nuovo schermo di ricambio, altrimenti, una volta installato in questo modo, potrebbe muoversi in modo casuale.
    I just received a new front planel and the digitizer connector is wrapped in a black electrical tape. I removed to check for the adhesive between circuit and connector but didn't see any, I re-wrapped in the original black tape which I think should be left alone. Also there was a yellow tape over the back of the home button and circuitry between the digitizer cable and home button. I removed this when I removed the blue plastic on the adhesive but I don't think your suppose to. After repair, home button doesn't work which might be because removing that tape.
    Ken Bauer - Replica
  63. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 63, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 63, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 63, immagine 3 di 3
    • Piega il cavo del digitizer su se stesso e premilo con decisione per incollarlo all'adesivo.
    The old glue was full of tiny shards. I rubbed it all away with many Q-tips and petroleum ether. To protect the LCD I used a sheet of heavy paper. Cleaning took a lot of patience.
    Still should have listened to Mike: The digitizer ribbon cable went between the frame and the panel. It was bent too sharply. Touch worked, but the home button did not. When i tried to reopen, the glass cracked. Big disappointment, but ill try again!
    luc - Replica
    Same here, so suspect I have the same problem, didn't see these comments until after I finished!
    Took me nearly 2 hours to remove the glass because it just shattered even more every time I used the sucker. Used IsoPropanol to clean.
    Checked all was working with the new digitiser and home button by starting iPad before sealing the glass shut, all ok.
    Stuck it all down, home button works occasionally, but also siri bleeps on it's own sometimes as if someones pressing the button. Also, if I press either side of the home button I get a reaction as if I've pressed the home button, or sometimes I get the double tap action and sometimes Siri, makes me think that there is something shorting / touching that shouldn't be, unless it's the ribbon.
    Will order another kit and give it another go shortly as the glass is sure to break when you re-open.
    Barry Tresadern -
    @Barry Tresadern
    I had the same problem with the home button acting crazy. The problem is on the new screen there are metal contacts that are exposed and they are touching the metal frame making it seem the button is being pressed. If you look on the old screen you'll see strips of tape covering these metal contacts. You can either peel them off and put them on the new screen or just use some electrical tape.
    Patrick -
    With this step, im looking for a replacement screen. I cant seem to see the same connector as the one illustrated here. Is there 2 ribbons mixed there?
    James - Replica
    James, I think you're referring to the IC chip that most glass panels do not include. If you do not have soldering knowledge (and a lot of confidence and time) then it's crucial that you purchase a panel that has the IC chip attached, otherwise you will need to remove the old one from the broken assembly and re-solder it on to the new one - honestly not worth the time involved unless you know what you're doing.
    Katie -
    I've been able to replace a shattered screen. Took about an hour and a half. This consisted of mostly cleaning the shards. I wish there were some glue in the kit - I don't know if there is enough left from the previous screen to hold the new one. I'm likely going to use craft glue to make up the difference. Any other suggestions?
    [deleted] - Replica
    Heating the glue with a hair dryer or heat gun helps or you can buy very thin double faced tape.
    Michael Vovaris -
    I thought that it was a successful repair and resealed the iPad and turned it back on after replacing the digitalizer and the LCD screen, yet neither the home button nor the power button are working. After holding the power button, the power will come on but just one "click" the screen does not react. I tried moving the tape around the home button from the broken digitalizer to the new digitalizer, yet neither button works. I need help ASAP, I don't want to damage the iPad screen more by leaving it unopened for extended periods of time. Any suggestions?
    James Johnson - Replica
    the new pannel comes with a yellow tape on those contacts. Do not remove it. (or replace it !)
    ZARAGOZA - Replica
    Yes..do not remove this tape!
    Banu -
    Yes I learned the hard way as well, be sure you leave the yellow plastic tape over the back of the home button and surrounding circuitry or put tape over this area before install. New screen installed and the home button isn't working :-(
    Ken Bauer -
    THANK YOU Patboy2008, you saved me a friendship and a lot of heartache. I was racking my brain trying to figure out why the home button was on the fritz. Siri kept interrupting, the screen would go black, then flick on, then apps would randomly open, then it wouldn't even give me enough time to punch in my passcode. It was all about those two SILLY pieces of tape. Sure enough reopened it and noticed that the new screen didn't have the two black pieces of tape the old screen had. So glad I dug it out of the trash and transferred those pieces. It works like a charm now. Oh and this was so much harder to fix than the iPhones. The hardest part is getting the front panel off and if it's broke it'll come off in the tiniest of pieces. I hard shards of glass in my fingers that you were like invisible splinters. Be careful and take your time with this one.
    iKimmy - Replica
    Thanks for comments. Yes, do pay attention the the metal bands in the bottom frame of the front panel. DO cover a trip of electric tape on it. You will find the random moving and touching away.
    shanhaidong -
    It pays not to take the protectors off the glass panel adhesive until you have fitted the panel and turned on the ipad to test functionality a few times. (Once the adhesive sticks, it's very difficult to take the panel back off.) Also, I ended up applying two layers of electrical tape over the copper contacts on the panel before the random actions stopped. Now I am closing my third repair on the same machine. Let's hope this one sticks.
    philippschuller - Replica
    In a kit purchased in June 2019, this operation was already done.
    Clément Marshall - Replica
  64. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 64, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 64, immagine 2 di 2
    • Prima di installare il tuo nuovo pannello anteriore, dovrai trasferire i magneti della Smart Cover dal pannello ORIGINALE a quello nuovo.
    • Appoggia la punta di uno strumento di apertura in plastica su ogni lato del magnete vicino all'angolo in alto a sinistra del gruppo del pannello anteriore.
    • Infila attentamente la punta dello strumento di apertura in plastica di destra sotto il magnete.
    • Tieni lo strumento di apertura in plastica di destra infilato sotto il magnete.
    • Infila la punta dello strumento di apertura in plastica di sinistra sotto il magnete mentre fai leva e lo spingi verso lo strumento di destra.
    • Questo passaggio richiederà della forza, in quanto il magnete della Smart Cover è incollato con dell'adesivo resistente.
    On the new front panel with the adhessive pre-installed, there are perforated area on the blue plastic you can peal away just for the magnets without exposing the rest of the adhesive.
    Ken Bauer - Replica
    I found these come off much easier after applying heat to the area for 5 seconds.
    Korey Bennett - Replica
    On the kit purchased in June 2019, magnets were included in the replacement part.
  65. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 65, immagine 1 di 1
    • Se necessario, usa un paio di pinzette per rimuovere il pezzo di nastro adesivo nero che copre il magnete nell'angolo in basso a sinistra del gruppo del pannello anteriore.
    In the kit as of July 2019, there is an area of adhesive (separate from the edge adhesive) on the screen where you want to relocate the magnets. It is in the rough shape of the magnet, so you can see how to orient the magnet (curve parallel to the curve of the case corner). When you close up the screen, the magnets fit into the depression above where the tabs of the LCD are (the ones you remove the screws from in step 31). The magnets shouldn’t be too far away from the copper-colored rim of the interior of the screen, or they will not fit into the depression and may crack the screen when you press it to close. Definitely dry fit!
    Sara Austin - Replica
    Hi, I’d like to know if this magnets are necessary to maintain the screen attach, if they do something beside the adhesive. Thank you for your help.
    castrofabian - Replica
  66. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 66, immagine 1 di 2 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 66, immagine 2 di 2
    • Esegui la procedura precedentemente descritta per rimuovere anche il magnete della Smart Cover nell'angolo in basso a sinistra del gruppo del pannello anteriore.
  67. Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 67, immagine 1 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 67, immagine 2 di 3 Sostituzione gruppo pannello anteriore iPad Mini WiFi: passo 67, immagine 3 di 3
    • In questo passo, dovrai trasferire i magneti della Smart Cover al NUOVO gruppo del pannello anteriore.
    • Usa un paio di pinzette per posizionare attentamente il magnete della Smart Cover dell'angolo in alto a sinistra in posizione.
    • Ripeti la procedura con il magnete della Smart Cover dell'angolo in basso a sinistra.
    • Se necessario, usa la punta di uno strumento di apertura in plastica per appiattire il pezzo di nastro adesivo incollato al magnete della Smart Cover nell'angolo in basso a sinistra.
    Do not forget to remove the protective film from inside of new digitizer, remove black insulating tape from bottom of old digitizer and place on new one, covering any and all exposed copper. Take your time - the repair is not hard but it is time consuming
    David D - Replica
    Thank you for mentioning that! I don’t think I would have noticed until too late.
    ted -
    BEFORE you close everything up power up your ipad and make sure all the buttons and functions work properly, charging, rotation, home button, sleep button
    Chris Grayden - Replica
    Step 66, it is important to put the magnets in the same Exact place and orientation or you could break the glass (again) during installation.
    Phil Fite - Replica
    The orientation of the magnets may also be important to the devices’s ability to wake/sleep in response to the cover being opened and closed.
    ciradrak -
    No mention is made of using any adhesive during the installation of the new panel. There are gobs of adhesives for many different purposes. Is there any recommendation for re-establishing an adhesive for the new panel?
    Jim Dutton - Replica
    Step 35b : watch for LCD white screw tabs as you pull up LCD panel so that they don't bind at the bottom and break off (definite crack)!
    Step 46: was easier, at least for me, to insert spudger between frame and digitizer board (left side) rather than trying to get under it from its right side.
    All of this & they could have simply made the connector cable on the front glass a snap on connector & cut out 60 steps of this repair.
    Gary - Replica
    I was repairing the broken glass on my iPad. A lot of the broken glass was in small fragments along the edges which made sliding the pick underneath to loosen the glass quite difficult. Things would go well until I hit a small island of broken glass and the pick would stall as the glass wouldn’t budge. It took several re-heating cycles with the microwave heat pad and a lot of patience to break those loose. In retrospect, probably could have ignored them until the bulk of the glass was removed and then _gently & patiently_ chisel them out separately.
    Still had ghost touch issue with the iPad mini so I ended up purchasing Kapton tape on Amazon and used it to cover the entire bottom part of the iPad mini 2 where the Home button is, not just the gold connectors as previously suggested. Apparently this is a common issue with the iPad minis where the digitizer and home button are grounded to the iPad’s chassis. Thankfully, that resolved the issues of ghost touch and my daughter’s iPad is now working like a charm. Just wished your iFixit digitizers were properly prepped with Kapton tape from the factory. Hope this helps with other iFixit customers suffering from the same issue.
    Yousef Ghalib - Replica
    I believe I finally figured out the issue with the iPad mini. I feel like an idiot! It was improper installation. Ghosting on a the iPad mini was caused by creasing the digitizer flex incorrectly. It can NOT be allowed to bend backwards and touch the adhesive for the screen (I checked--mine and was bent backwards and creased due to it sticking to the adhesive). The flex must gently bow forward towards the LCD and not be allowed to crease. Unfortunately the digitizer is compromised and unusable. We’ll need a new digitizer but this time I wont make the same mistake
    One of the more difficult/frustrating issues I had during reassembly was the tendency of the digitizer cable to place itself between the frame & the glass. This prevented the glass from seating completely in the frame & I believe would have caused damage to the ribbon cable had I not noticed it. I had to use a flat tool to guide the ribbon cable away from the frame as I lowered the glass into place. I am not in a position to do it, but I hope a reassembly document will be added to these instructions, as it’s not simply a matter of “following the instructions in reverse order.”!!!
    kevs - Replica
    Good tip! I replaced a digitizer myself after a shop had done it once already. Aside from new cracks, there were problems with dead spots on the screen, and the lock button would shut down but not sleep the screen. The screen I took off looked like the digitizer cable had been pinched like you noted, and I wonder if that was causing the problems.
    ted -
    If your ipad has a dented corner, you may need to trim the new glass a bit so that it fits flush. The ipad I worked on had been dented in the corner, which what cracked the screen in the first place. The dent pushed in the metal lip enough that a replacement screen would sit on top of it, so that a little too much pressure on the glass will make it crack again. A diamond-coated file will work to file off some of the glass on the corner. Full sized Leatherman multi-tools often have a diamond coating on the back side of the coarse file — it works great. Just be patient as it takes a while to grind off.
    ted - Replica
    You Could Add One more Step: When assembling the screen it is necessary to tuck the digitizer cable back into the tablet as it wants to fold toward the outer edge and prevent the digitizer glass assembly from laying flat against the framework. You can do that with a Spudger by pushing the cabole back into the tablet as you close or seat the glass digitizer.
    Larry Bennett - Replica
    At which step during reassembly to remove blue protective film on the adhesive is never mentioned. I did it too early and thought of preserving it with cling film which does not peel off afterwards. Don't do this. I suggest removing this stuff just before turning “the page” back on.
    Where can you buy the magnets? (not from ifixit)
    Emerald - Replica
    There is no mention anywhere about ingress of dust between the cover glass and the LCD…is this a nonissue??
    Jordan Clayson - Replica
    Just finished the digitizer replacement by buying a new one for $10 rather than pay $120 to get it repaired. Everything works great! A few tips that weren't mentioned:
    1) I used a hair dryer on low heat for 30-40 secs and it softened the adhesive enough to pry it open.
    2) If you have the wifi iPad (non-cellular), you don't have to worry about the antenna when prying, as it doesn't have one.
    3) Be sure to remove the old adhesive by pulling it off the iPad frame so your new digitizer can sit tight and flush. Most new digitizers have adhesive included (very convenient), just peel off the blue cover vinyl as your final step.
    4) Try to use something to cover the LCD screen from fingerprints and dust. I had to use a wet wipe to gently wipe down the LCD. I couldn't get every smudge off but it proved not to matter as it was not noticeable upon completion.
    Hope this helps!
    Christian Lee - Replica
Conclusione
Per rimontare il tuo dispositivo, segui le istruzioni in ordine inverso.
Altre 449 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
53 Commenti
This really isn't that hard of a repair, I struggle more with iphones than an iPad. Just be careful and diligent when you work. Hardest part for me is the stupid adhesive haha
Brendan McDonnell - Replica
ifixit is forgetting crucial steps in this repair. First off they need to make note of the small magnets on the back of the digitizer which are needed to use the smart cover feature on the ipad. And second they need to make note of the issues people are having with the touch acting up as soon as the digitizer is laid back down. you need to put tape on the contacts of the digitizer so that it does not directly touch the frame. also the iopener burned my microwave, your better off just using a heatgun and guitar picks/spudger.
info - Replica
Hi, I am having the exact issues where the touch is not responding. Where exactly do I need to put tape on the contacts of the digitizer so that it does not directly touch the frame? Can you explain in detail. Thanks.
yungwun619 -
Either it was updated or you overlooked it. For newcomers, the info implied about is covered in Step 60-63.
Keypad -
Again, ifixit leaves out a VERY important part that will BREAK the LCD if you forget to remove them. The sides of the LCD in the ipad mini has tape on it as well(you can even see the tape in the pictures above in the tutorial). If you do not remove this tape before inserting a tool under the sides of the LCD the LCD will BREAK! You must remove the foam ALL THE WAY AROUND THE LCD and peel back the tape from not only the top (as in the tutorial), but the sides of the LCD as well, holding it to the metal shield behind the LCD. The tape can be replaced, or re attached later, but it HAS to be removed before attempting removal of the LCD itself. I wish I would have known this before digging into the ipad mini. Fix the tutorial PLEASE!
Edward - Replica
too LATE, I BROKE THE TAPE lcd =((((((
Quynh Vu -
It is in there, in steps 41-46. You must’ve just looked it over.
TheYootz Media Group -
I completed a repair using this guide this past weekend. It took 2.5 hours mostly because the screen was too shattered to use the suction cup, and I had to clean up all the little bits of glass and adhesive. But the repair was a success! The iPad worked perfectly after I was done with the rebuild. I did forget to put back the two mini magnets that were for the smart cover but it was too late and I wasn't too worried about it at that point. Thanks again for a great guide.
Gregory Caporale - Replica
I was using the guide on the google app for Android and it was not as complete as this version on the website. Otherwise this was a great guide! Thanks again for the very detailed steps and photos.
The only issue I had was the screen was shattered and made the use of the suction cup useless. I just continued to heat and remove the shards of glass a little at a time.
paulmcneely - Replica
Place clear packing tape or a screensaver on the shattered glass before you start and generally the suction cups will stick.
Patti Pender -
The adhesive on the packing tape will liquify under the heat of yhe iopener making it pretty useless. Heating and chipping seems to be the way to go. Ifixit eally should have adressed this ahead of time as i am assuming most people will be teplacing shattered screens. I mean why else would you go through this?
David Stotz -
Hopefully someone can help me. I have replaced the digitizer, but something is wrong. The digitizer is basically unresponsive, and acts like it is being touched in multiple places at once. This only happens when fully assembled. I tested with the digitizer NOT mounted to the chassis, and it works perfect. Is this a grounding problem?
bradj47 - Replica
Do you have to replace the smart magnets? is this a necessary step if you do not use the smart covers?
Michael - Replica
I didn't. No need.
Patti Pender -
This guide and the pictures are the best way to destroy your ipad, sorry to say so. If you insert the picks as deep as shown, you cut various wires such as the 3G antenna, the camera, the home button - all of them are placed on both narrow sides of the ipad. Further on you risk scratching the LCD surface, which consists of a dark foil that you may scratch off.
So to make it short: Fingers away from this guide!
dadoc - Replica
There is no 3G antenna on the Wi-Fi version. Use the correct guide for your device and these issues go away.
The guide carries warnings where the cables and antennae are and cautions you where to place picks.
Patti Pender -
After connecting the new digitizer I plugged in the LCD the digitizer and the battery connectors, installed the metal shields and tried to power on the iPad. Unfortunately the screen is grey white while booting, only half the Apple is visible and upon booting the colours are strange but I can use both the digitizer and the home button. Do you think I damaged the LCD during the process or did I break anything on the motherboard?
finn2k1 - Replica
I would check that the lcd cable isn't trapped or kinked under itself when plugged into the board. The iPhone 5 does exactly this when the cable isn't located spot on.
Gavin -
I did this over the weekend, took about 2 hours all told, as others have said cos the glass was shattered.
I found it very easy to just use a hairdryer to melt the glue enough to get the panel and digitiser off the chassis.
Unfortunately the home button is behaving a little oddly, and Im guessing its grounding out as it keeps kicking back to the home screen.
Ill report back when I have found out more.
Gavin.
Gavin - Replica
This was my first attempt at repair. So I went with an older model. He's what I've learned. Quite a bit of attention was made to keep the digitizer connected to the device. In my case, I was replacing it, so it didn't make a difference if I kept the broken glass attached. It was pretty annoying to have glass all over the place (even after taping) when I could have just cut the ribbon cable. Secondly, as previously posted, bend your ribbon cable on the new digitizer FIRST. But, it's not clear how it should be bent. After folding the digitizer back, it becomes straightened back out a bit before you use it as an example for the new cable. It should really be folded up accordion style so that there's a tight backward S shape to it. If you don't get the fold right the first time, just reheat the corner, pull just enough on the suction cup to slide a guitar pick in and push the cable into it's little space where it belongs.
jefowler4th - Replica
Good thing! I did it with success!!
Few things to make it easier for new users, said above but now clear.
- if your glas is shattered, its hard to remove it. But keep tryin it will work if you give it enough time.
- be careful at removing the lcd. The glue is holding it back on the metal plate. Slow an easy.
- bend the flex cable of the front panel before you reassemble. Or be very careful if you already reassembled but have to glue the glas onto the body. Push with a stump tool onto the cable until its an "s" and fits into the gap.
- finally, there are many versions of new glas. The adhesive isnt very strong on them. Maybe put some extra glue under the glas. Otherwise it wont stay fixed.
Good Luck
harry - Replica
I did my iPad Mini repair yesterday, took me 4 hours because I was slow and careful and it was my first time with this device, and here is my 2 cents'worth:
If the glass is cracked I wouldn't bother with taping it. I put the tape on, found I couldn't proceed because I couldn't get any suction with the suction cup, so took the tape off again.
Disconnecting the battery and LCD connectors is a swings and roundabouts thing. If you leave them connected, especially the battery connector, and you short something, you have a bad situation. However, if you disconnect them, and in the process of doing so, you damage the delicate connector. that is also a bad situation. I did it without disconnecting them and it worked OK.
The tape over the copper contacts is important. I put ordinary clear tape over the contacts and I got random movements on the screen. Then I put a strip of electrical tape on top of that and the random movements improved. Then I put another strip of electrical tape on and it's OK now.
Peter Gray - Replica
Another couple of things: the self adhesive strip around the edge of the new screen isn't anything like the original glue. It's OK for a temporary repair while you see if the thing works or not, but to make it permanent you really need to use iGlue or whatever Apple uses.
When I reassembled the unit I found that the front facing camera wasn't quite aligned with the spyhole in the front glass. This is because the camera is on a flexible mount which allows for a couple of millimetres movement in all directions. You just need to watch this when reassembling.
Mischief managed, though it would have been nice if there was process for changing out the home button. One I ordered did not come with one. Ended up going to YouTube to find a video on how to do those steps.
Greg Beaudry - Replica
how to order a digitizer for ipad mini 1
kent bacalso - Replica
Why didn't anyone cover how to tak out the home button and replace it in the new digitizer?
gocaps25 - Replica
Troubles with the home button why isnt there steps on how to put it ?
Marvin - Replica
The following should be added to this guide
Digitizer random touch after replacement
aRI - Replica
How do you remove the old adhesive?
There is nothing in the repair kit to remove the adhesive.
Pierre St Gelais - Replica
Did this fix the other day and everything works except the iPad won't charge past 2 percent and keeps restarting.
Any help on what is causing this?
Thanks!
Steve - Replica
Did the repair everything works except the screen keeps acting like the magnet case is on and turning itself off at random I took the magnets out and am still having the same issue.
Robert - Replica
Well the yellow tape that came with the new screen came off replaced it and works like it should make sure the yellow tape stays on the screen
Robert - Replica
I did it. Everything whent smoodly but one small problem. The digitaser reads nothing. :( the button works.
Sandor Falkesund - Replica
Didn't work. =( Did the whole replacement, seemed to go mostly okay, but when I powered the device back on the touchscreen is completely unresponsive. My daughter is very sad, and I'm out $60. All the connectors clicked into place, so I have no clue what I did wrong, or if the part is bad, but the thought of spending another 2+ hours re-doing it is more than I can stand.
bh - Replica
I had successfully done 5 minis with no issues the last one had ghost touch then the digitizer died i think I damaged the digitizer flex I used kapton tape over the copper contacts this should stop the screen jumping and ghost touch be very careful when bending the digitizer flex it so easily damaged take time to get it right. For sticking the digitizer back down the adhesive supplied is not man enough to keep screen down on its own so I used IPAD ADHESIVE TAPE DOUBLE SIDED REDTAPE SUPER STRONG STICKY comes in different width's Easily got on eBay I found 'this worked the best and so far had no issues with digitizer lifting since using this tape
Jon maccallum - Replica
Followed this to replace a broken LCD. Turned out I needed the front screen with digitizer. Word of warning: I might have been a bit rough removing the screen first time and damaged the digitizer.
Stephen - Replica
After doing this repair the cameras aren't working... :( The camera app starts up and appears to be working with all the white buttons, but the screen is black. I can change between front and back camera (I see that it does it because one of the cameras has HDR.
I don't know what to do here. I've tried to reset it with the power- and home button but that doesn't fix it.
Any ideas?
Krister Turøy - Replica
If you're on the fence about your abilities, give this a try. It really isn't too bad.
I decided to remove the old (shattered) digitizer with an Xacto knife as I had seen elsewhere. That made quick work of that stage, but I would recommend gloves and being extra careful on the sides. The rest is fairly familiar, a lot like an iPhone if you've ever repaired one of those.
Another tip is to use a magnet from your fridge to keep the right screws together.
Wesley Applequist - Replica
The new adhesive doesn't stick very well and the side of the screen keeps popping up and I don't know what to do what should I do about this?
Peter Carlson - Replica
Hi Peter! As with all adhesives it will work best on a clean surface. If you can pop the glass up without damaging it or the adhesive, you may be able to check for any dirt or leftover adhesive, and rub down the case with some isopropyl alcohol to clean up any grime or finger oils. You can also check for misplaced cables or other components that didn't settle back correctly. If you don't want to risk reopening the device, you may be able to help set the adhesive by applying light pressure for a few hours. Warning though, if there is a hard high-point on the case anywhere, adding pressure on the device may cause the glass to crack in that location. Stack a few mid-sized books on the iPad overnight to help activate the pressure sensitive adhesive, you don't need to press hard, just light pressure over time will help. You can also check out our Answers forum for more help. Good luck!
Sam Goldheart -
Me tomó como 3 horas completarlo por que fui super cuidadoso y pendiente para no cometer un error. Es tedioso por los detalles pero facil de hacer con las herramientas correctas (utilize las de ifixit). Si tienes prisa busca el dia adecuado para hacerlo con calma ya que vale la pena hacerlo uno mismo. Tener mucho cuidado al sacar el LCD y de eliminar bien la pega que tenia en el marco del digitizer para que selle bien el nuevo. Thank you ifixit!
ORLANDO ENCARNACION - Replica
Just completed this repair. Left the ipad out in the sun, playing music while I worked outside. It overheated, and afterwards exhibited “ghost touches” making it nearly impossible to use. It also had a dead spot on the touch screen just above the home button. Research indicated the digitizer was a likely suspect. Sure enough, that fixed it! These instructions were great. A few differences in what was taped and where as the LCD came out, but everything else was spot on. The kit I received from ifixit had kapton tape over some exposed copper at the bottom of the new screen assembly. That may have been all that was necessary, but I put some scotch tape over the copper touch screen traces at the bottom of the screen as well. The copper traces along both sides and the top appeared to be covered completely by a thin plastic sheet, just like the original screen, so I did not tape them. So far, no ghost touch behavior! Thanks for the great site!
Matt Mischnick - Replica
My son dropped our iPad Mini 2 and the glass shattered. Other than that it works perfectly. My question is, do I have to replace the LCD or can I just buy the glass (much cheaper, around $20) and replace that? It seems that repair would be much simpler as well. Thanks in advance.
Richard Cacciato - Replica
Hi Richard, sounds like you only need to replace the glass, although I highly recommend you buy a replacement digitizer that includes the home button. We also have iPad Mini 2-specific digitizer guides. You can find the iPad Mini 2 Wi-Fi guide here, and the iPad Mini 2 cellular guide here.
Sam Goldheart -
Thanks, Sam. How can I tell for sure if I need to replace the digitizer as well or only the glass? As I said, the iPad seems to work perfectly other than the shattered glass.
Richard, my bad on terminology, the digitizer is embedded in the top glass, if the display is undamaged, then you won’t need to replace the LCD, just the digitizer/glass.
Sam Goldheart -
Successfully repaired cracked screen, although more difficult than I anticipated after replacing screens on iPhone 5 and 6. I should have read more of the comments before starting.
The packing tape I used wouldn’t hold suction after heating, find tape with heat resistant adhesive, or pick out multiple pieces.
When I removed the protective film from the inside of the new screen, the yellow tape covering the Home button ribbon came with it, which caused the Home button to short out when the screen was put in place. Replacing the yellow tape solved the problem.
kimhoover - Replica
well i started this repair got the iopener and everything took it slow, got the glass of relised that it was the screen protector (am fixing for a friend). *facepalm* great practice though
GLaDOS .V42 - Replica
I feel that instead of putting plastics in the microwave, the iOpener, you could use a sock filled with sand as an alternative for a heat source to soften the adhesive around the screen.
Michael - Replica
I feel like there should be more steps than just 66 steps but they’re missing, why?
Nathaniel Egot - Replica
Excelente tutorial, OJO con los pegamentos del LCD a la altura del Botón Home. es muy fácil quitarlo. Todo super explicado.
crodrigocorona - Replica
The prior screen was ghost-touching some spots so I tried replacing with new. Now neither will respond. Any suggestions to troubleshoot or have I bricked it? Or perhaps an updated for the jargon: plated? :( it?
mark40 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 189
Tutti i Tempi: 332,691
