Salta al contenuto principale
iPad Mini 6 Screen Replacement
Cosa ti serve
    1. iPad Mini 6 Screen Replacement, Apply tape to a cracked screen: passo 1, immagine 1 di 3 iPad Mini 6 Screen Replacement, Apply tape to a cracked screen: passo 1, immagine 2 di 3 iPad Mini 6 Screen Replacement, Apply tape to a cracked screen: passo 1, immagine 3 di 3
      • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Mini 6 Screen Replacement, Heat the bottom edge: passo 2, immagine 1 di 1
      • Completely power off your device before you begin.
      • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. iPad Mini 6 Screen Replacement, Screen removal information: passo 3, immagine 1 di 3 iPad Mini 6 Screen Replacement, Screen removal information: passo 3, immagine 2 di 3 iPad Mini 6 Screen Replacement, Screen removal information: passo 3, immagine 3 di 3
      • While you're waiting for the adhesive to loosen, note the following:
      • The areas at the top and bottom of the screen are sensitive to prying.
      • Don't insert a pick more than 3 mm to avoid damaging the screen.
      • There's a long circuit board attached to the screen that sits parallel to the left edge.
      • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
      • The first two images are mirrored for demonstration purposes.
      Chiedi a FixBot
      Aggiungi Commento
    3. iPad Mini 6 Screen Replacement, Insert an opening pick: passo 4, immagine 1 di 3 iPad Mini 6 Screen Replacement, Insert an opening pick: passo 4, immagine 2 di 3 iPad Mini 6 Screen Replacement, Insert an opening pick: passo 4, immagine 3 di 3
      • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
      • Lift the screen with the suction handle to create a small gap between the screen and the frame.
      • Insert an opening pick into the gap between the frame and the screen.
      • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Chiedi a FixBot
      Aggiungi Commento
    4. iPad Mini 6 Screen Replacement, Separate the bottom adhesive: passo 5, immagine 1 di 3 iPad Mini 6 Screen Replacement, Separate the bottom adhesive: passo 5, immagine 2 di 3 iPad Mini 6 Screen Replacement, Separate the bottom adhesive: passo 5, immagine 3 di 3
      • Slide the pick along the bottom edge of the device towards the bottom-right corner.
      • Leave the pick in to prevent the adhesive from resealing.
      Chiedi a FixBot
      Aggiungi Commento
    5. iPad Mini 6 Screen Replacement, Heat the right edge: passo 6, immagine 1 di 1
      • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
      Chiedi a FixBot
      Aggiungi Commento
    6. iPad Mini 6 Screen Replacement, Separate the bottom-right corner adhesive: passo 7, immagine 1 di 3 iPad Mini 6 Screen Replacement, Separate the bottom-right corner adhesive: passo 7, immagine 2 di 3 iPad Mini 6 Screen Replacement, Separate the bottom-right corner adhesive: passo 7, immagine 3 di 3
      • Rotate the opening pick around the bottom-right corner of the device.
      Chiedi a FixBot
      Aggiungi Commento
    7. iPad Mini 6 Screen Replacement, Separate the remaining adhesive: passo 8, immagine 1 di 2 iPad Mini 6 Screen Replacement, Separate the remaining adhesive: passo 8, immagine 2 di 2
      • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
      • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
      Chiedi a FixBot
      Aggiungi Commento
    8. iPad Mini 6 Screen Replacement, Reposition the screen: passo 9, immagine 1 di 3 iPad Mini 6 Screen Replacement, Reposition the screen: passo 9, immagine 2 di 3 iPad Mini 6 Screen Replacement, Reposition the screen: passo 9, immagine 3 di 3
      • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
      • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
      • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
      • Rest the screen upside down and parallel to the frame before continuing.
      • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
      Chiedi a FixBot
      Aggiungi Commento
    9. iPad Mini 6 Screen Replacement, Unfasten the display cable bracket: passo 10, immagine 1 di 2 iPad Mini 6 Screen Replacement, Unfasten the display cable bracket: passo 10, immagine 2 di 2
      • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
      Chiedi a FixBot
      Aggiungi Commento
    10. iPad Mini 6 Screen Replacement, Remove the display cable bracket: passo 11, immagine 1 di 2 iPad Mini 6 Screen Replacement, Remove the display cable bracket: passo 11, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
      Chiedi a FixBot
      Aggiungi Commento
    11. iPad Mini 6 Screen Replacement, Disconnect the display: passo 12, immagine 1 di 3 iPad Mini 6 Screen Replacement, Disconnect the display: passo 12, immagine 2 di 3 iPad Mini 6 Screen Replacement, Disconnect the display: passo 12, immagine 3 di 3
      • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
      Chiedi a FixBot
      Aggiungi Commento
    12. iPad Mini 6 Screen Replacement, Remove the screen: passo 13, immagine 1 di 2 iPad Mini 6 Screen Replacement, Remove the screen: passo 13, immagine 2 di 2
      • Remove the screen from the frame.
      Chiedi a FixBot
      Aggiungi Commento
    1. iPad Mini 6 Screen Replacement, Only the screen remains: passo 14, immagine 1 di 1
      • You're now left with the screen separated from the frame.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Altre 21 persone hanno completato questa guida.
Alex Diaz-Kokaisl
Membro da: 01/16/22
247.177 Reputazione
1.203 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
64.861 guide realizzate
3Commenti sulla guida
Apple iPad Mini 6, 이전 세대보다 화면이 커지긴 했어도 필기용으로은 조금 별로..
그렇다고 Mini 에서 Pro 급의 초대형 화면을 바라기엔 좀 그렇고,,
Turtle - Rispondi Condividi
El primer paso la foto esta mal...
sergiocb - Rispondi Condividi
Are there any steps for assembling the screen, instead of only showing the assembly? And does the screen replacement come with adhesive strips, or do I need to order them seperately from another store? If so, how do I apply that?
Wikiredia - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 33
Ultimi 7 giorni: 242
Ultimi 30 giorni: 1,379
Tutti i Tempi: 54,467
