Introduzione
Use this guide to replace the volume buttons in an iPad Air 2 Wi-Fi. You may need this guide if the volume buttons are cracked or missing.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Strumenti
Parti
Nessuna parte specificata.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
Two 1.6 mm
Two 1.3 mm
Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
Use the flat end of a spudger to disconnect the iSight camera from its socket on the logic board.
Remove the iSight camera.
Remove the 1.2 mm Phillips screw from the bracket covering the volume button cable connector.
Using a spudger or your finger, press in on the top and bottom button cover to remove them.
Un commento
How does this compare to doing the same thing on the cellular version of the iPad Air 2?
