Salta al contenuto principale
Cosa ti serve
  1. iPad 5 Wi-Fi Headphone Jack Replacement, iOpener Heating: passo 1, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement, iOpener Heating: passo 1, immagine 2 di 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 5 Wi-Fi Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 5 Wi-Fi Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 5 Wi-Fi Headphone Jack Replacement, Alternate iOpener heating method: passo 4, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement, Alternate iOpener heating method: passo 4, immagine 2 di 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 5 Wi-Fi Headphone Jack Replacement, Front Panel: passo 5, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement, Front Panel: passo 5, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement, Front Panel: passo 5, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad 5 Wi-Fi Headphone Jack Replacement: passo 6, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 6, immagine 2 di 2
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
  7. iPad 5 Wi-Fi Headphone Jack Replacement: passo 7, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 7, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 7, immagine 3 di 3
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
  8. iPad 5 Wi-Fi Headphone Jack Replacement: passo 8, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 8, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 8, immagine 3 di 3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
  9. iPad 5 Wi-Fi Headphone Jack Replacement: passo 9, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 9, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 9, immagine 3 di 3
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  10. iPad 5 Wi-Fi Headphone Jack Replacement: passo 10, immagine 1 di 1
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  11. iPad 5 Wi-Fi Headphone Jack Replacement: passo 11, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 11, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 11, immagine 3 di 3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
  12. iPad 5 Wi-Fi Headphone Jack Replacement: passo 12, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 12, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 12, immagine 3 di 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  13. iPad 5 Wi-Fi Headphone Jack Replacement: passo 13, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 13, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 13, immagine 3 di 3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panicโ€”just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  14. iPad 5 Wi-Fi Headphone Jack Replacement: passo 14, immagine 1 di 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  15. iPad 5 Wi-Fi Headphone Jack Replacement: passo 15, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 15, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 15, immagine 3 di 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  16. iPad 5 Wi-Fi Headphone Jack Replacement: passo 16, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 16, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 16, immagine 3 di 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
  17. iPad 5 Wi-Fi Headphone Jack Replacement: passo 17, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 17, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 17, immagine 3 di 3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  18. iPad 5 Wi-Fi Headphone Jack Replacement: passo 18, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 18, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 18, immagine 3 di 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
  19. iPad 5 Wi-Fi Headphone Jack Replacement: passo 19, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 19, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 19, immagine 3 di 3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  20. iPad 5 Wi-Fi Headphone Jack Replacement: passo 20, immagine 1 di 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPadโ€”along the volume and lock buttons.
  21. iPad 5 Wi-Fi Headphone Jack Replacement: passo 21, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 21, immagine 2 di 2
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  22. iPad 5 Wi-Fi Headphone Jack Replacement: passo 22, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 22, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 22, immagine 3 di 3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  23. iPad 5 Wi-Fi Headphone Jack Replacement: passo 23, immagine 1 di 1
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
  24. iPad 5 Wi-Fi Headphone Jack Replacement: passo 24, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 24, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 24, immagine 3 di 3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  25. iPad 5 Wi-Fi Headphone Jack Replacement: passo 25, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 25, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 25, immagine 3 di 3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  26. iPad 5 Wi-Fi Headphone Jack Replacement: passo 26, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 26, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 26, immagine 3 di 3
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
  27. iPad 5 Wi-Fi Headphone Jack Replacement: passo 27, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 27, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 27, immagine 3 di 3
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
  28. iPad 5 Wi-Fi Headphone Jack Replacement: passo 28, immagine 1 di 1
    • Reheat and reapply the iOpener to the volume control side of the iPad.
  29. iPad 5 Wi-Fi Headphone Jack Replacement: passo 29, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 29, immagine 2 di 2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
  30. iPad 5 Wi-Fi Headphone Jack Replacement: passo 30, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 30, immagine 2 di 2
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
  31. iPad 5 Wi-Fi Headphone Jack Replacement: passo 31, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 31, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 31, immagine 3 di 3
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
  32. iPad 5 Wi-Fi Headphone Jack Replacement: passo 32, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 32, immagine 2 di 2
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
  33. iPad 5 Wi-Fi Headphone Jack Replacement, LCD: passo 33, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement, LCD: passo 33, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement, LCD: passo 33, immagine 3 di 3
    • Remove any tape obscuring the LCD screws.
  34. iPad 5 Wi-Fi Headphone Jack Replacement: passo 34, immagine 1 di 1
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
  35. iPad 5 Wi-Fi Headphone Jack Replacement: passo 35, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 35, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 35, immagine 3 di 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
  36. iPad 5 Wi-Fi Headphone Jack Replacement: passo 37, immagine 1 di 1
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
  37. iPad 5 Wi-Fi Headphone Jack Replacement: passo 38, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 38, immagine 2 di 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so donโ€™t push the spudger too far under the bracket, or you may damage the connector.
  38. iPad 5 Wi-Fi Headphone Jack Replacement: passo 39, immagine 1 di 1
    • Remove the LCD.
  39. iPad 5 Wi-Fi Headphone Jack Replacement, Front Panel Assembly: passo 40, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement, Front Panel Assembly: passo 40, immagine 2 di 2
    • Remove any tape covering the home button ribbon cable connector.
  40. iPad 5 Wi-Fi Headphone Jack Replacement: passo 41, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 41, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 41, immagine 3 di 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
  41. iPad 5 Wi-Fi Headphone Jack Replacement: passo 42, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 42, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 42, immagine 3 di 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  42. iPad 5 Wi-Fi Headphone Jack Replacement: passo 43, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 43, immagine 2 di 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  43. iPad 5 Wi-Fi Headphone Jack Replacement, Upper Component Cable Bracket: passo 45, immagine 1 di 1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  44. iPad 5 Wi-Fi Headphone Jack Replacement: passo 46, immagine 1 di 1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  45. iPad 5 Wi-Fi Headphone Jack Replacement, Headphone Jack: passo 47, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement, Headphone Jack: passo 47, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement, Headphone Jack: passo 47, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Only pry up on the connectorโ€”not on the socket itself.
    • Fold the front-facing camera cable out of the way.
  46. iPad 5 Wi-Fi Headphone Jack Replacement: passo 48, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 48, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 48, immagine 3 di 3
    • Lift the tape covering the headphone jack cable toward the top of the iPad to free the cable for removal.
  47. iPad 5 Wi-Fi Headphone Jack Replacement: passo 49, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 49, immagine 2 di 2
    • Use the flat end of a spudger to lift the headphone jack cable connector straight up from its socket on the logic board.
  48. iPad 5 Wi-Fi Headphone Jack Replacement: passo 50, immagine 1 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 50, immagine 2 di 3 iPad 5 Wi-Fi Headphone Jack Replacement: passo 50, immagine 3 di 3
    • Slide the flat end of a spudger under the headphone jack cable to free it from the adhesive securing it to the rear case.
  49. iPad 5 Wi-Fi Headphone Jack Replacement: passo 51, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 51, immagine 2 di 2
    • Continue to slide the spudger under the end of the headphone jack cable to remove the last of the adhesive.
  50. iPad 5 Wi-Fi Headphone Jack Replacement: passo 52, immagine 1 di 1
    • Remove the single 4.3 mm Phillips #000 screw from the headphone jack.
  51. iPad 5 Wi-Fi Headphone Jack Replacement: passo 53, immagine 1 di 2 iPad 5 Wi-Fi Headphone Jack Replacement: passo 53, immagine 2 di 2
    • Use the headphone jack cable to gently remove the headphone jack from its recess in the case.
Conclusione
Altre 3 persone hanno completato questa guida.
Evan Noronha
Membro da: 05/02/2015
218.230 Reputazione
177 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 44
Tutti i Tempi: 2,100
