Salta al contenuto principale
Zeki Droid Tablet Battery Replacement
Cosa ti serve
  1. Zeki Droid Tablet Battery Replacement, Back Casing: passo 1, immagine 1 di 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  2. Zeki Droid Tablet Battery Replacement: passo 2, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Remove the tapes one by one from the connecting wires with tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  3. Zeki Droid Tablet Battery Replacement: passo 3, immagine 1 di 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
    Chiedi a FixBot
    Aggiungi Commento
  4. Zeki Droid Tablet Battery Replacement: passo 4, immagine 1 di 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
    Chiedi a FixBot
    Aggiungi Commento
  5. Zeki Droid Tablet Battery Replacement: passo 5, immagine 1 di 1
    • Pull the speakers away from the back casing carefullly.
    Chiedi a FixBot
    Aggiungi Commento
  6. Zeki Droid Tablet Battery Replacement, Battery: passo 6, immagine 1 di 1
    • To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
    • Do not bend the battery.
    Chiedi a FixBot
    Aggiungi Commento
  7. Zeki Droid Tablet Battery Replacement: passo 7, immagine 1 di 1
    • To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
    • Using a soldering tool, you will desolder the tabs from the circuit board.
    • Please refer to the Come saldare e dissaldare componenti elettrici
    • If your replacement battery already has the small circuit board attached, you can desolder the red and black wires connected to the mother board instead of the metal tabs.
    Chiedi a FixBot
    Aggiungi Commento
  8. Zeki Droid Tablet Battery Replacement: passo 8, immagine 1 di 1
    • To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
    • Please refer to Come saldare e dissaldare componenti elettrici
    • If you have the battery with the circuit board connected, then you can solder the red and black wires back to the mother board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Kyla
Membro da: 03/11/15
156 Reputazione
2 guide realizzate
3Commenti sulla guida
will this be the same for a tbqc 1065b?
mark campbell - Rispondi Condividi
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
CIaudia Bringe - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 46
Tutti i Tempi: 6,030
