Salta al contenuto principale
ZTE Axon 7 Screen Replacement
Cosa ti serve
  1. ZTE Axon 7 Screen Replacement, Back Case: passo 1, immagine 1 di 2 ZTE Axon 7 Screen Replacement, Back Case: passo 1, immagine 2 di 2
    • Make sure the device is powered off.
    • Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
    Chiedi a FixBot
    Aggiungi Commento
  2. ZTE Axon 7 Screen Replacement: passo 2, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 2, immagine 2 di 2
    • Heat the iOpener in the microwave for 15-30 seconds.
    • iOpener will be HOT! Use oven mitts if necessary.
    • Place the iOpener on top of the top and bottom speaker grills to loosen up the adhesive underneath.
    Chiedi a FixBot
    Aggiungi Commento
  3. ZTE Axon 7 Screen Replacement: passo 3, immagine 1 di 3 ZTE Axon 7 Screen Replacement: passo 3, immagine 2 di 3 ZTE Axon 7 Screen Replacement: passo 3, immagine 3 di 3
    • Use a Jimmy to pry off the top and bottom speaker grills.
    • Remove the speaker grills gently so they don't crack or break off.
    Chiedi a FixBot
    Aggiungi Commento
  4. ZTE Axon 7 Screen Replacement: passo 4, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six 3 mm screws located under the speaker grills.
    • There may be remaining adhesive covering some screws. Take time to gently scrape away the adhesive using a spudger or opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  5. ZTE Axon 7 Screen Replacement: passo 5, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 5, immagine 2 di 2
    • Carefully wedge the Jimmy between the screen and aluminum back plate of the device.
    • Begin near the bottom right of the device and carefully work under the screen and slide the Jimmy up the edge of the device to remove the back case.
    • Use plastic picks to keep the display and back aluminum casing from closing as you pry along the perimeter of the phone with the Jimmy.
    Chiedi a FixBot
    Aggiungi Commento
  6. ZTE Axon 7 Screen Replacement: passo 6, immagine 1 di 3 ZTE Axon 7 Screen Replacement: passo 6, immagine 2 di 3 ZTE Axon 7 Screen Replacement: passo 6, immagine 3 di 3
    • Separate the front and back of the phone, (like a book) to open and gain access to the internal components.
    • Careful to not damage the fingerprint sensor cable attached to the motherboard from the back casing.
    • Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
    • Be very careful to pry only under the edge of the connector, and not under the socket itself. If you pry under the socket, you will separate it from the circuit board, which requires specialized microsoldering skills and equipment to repair.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place. Don't press down on the middle of the connector until it's fully aligned and seated. If misaligned the connector can be permanently damaged.
    Chiedi a FixBot
    Aggiungi Commento
  7. ZTE Axon 7 Screen Replacement: passo 7, immagine 1 di 1
    • The back is now completely removed.
    Chiedi a FixBot
    Aggiungi Commento
  8. ZTE Axon 7 Screen Replacement, Battery: passo 8, immagine 1 di 3 ZTE Axon 7 Screen Replacement, Battery: passo 8, immagine 2 di 3 ZTE Axon 7 Screen Replacement, Battery: passo 8, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    $3.99
    • Use a Phillips #00 screwdriver to remove three 2.0 mm screw securing brackets on the top and bottom of the battery.
    • Use the angled tweezers and lift the bottom bracket up and off the phone.
    • Use the angled tweezers to slide the top bracket up and off the phone.
    Chiedi a FixBot
    Aggiungi Commento
  9. ZTE Axon 7 Screen Replacement: passo 9, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 9, immagine 2 di 2
    • Disconnect both ends of the cable covering the battery by placing the tip of your opening tool or spudger under the edge of the connector and prying the connector straight up from its socket.
    • Remove the press fit cable.
    • Do not press down on the middle of wider connectors until they're fully seated—if misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
    Chiedi a FixBot
    Aggiungi Commento
  10. ZTE Axon 7 Screen Replacement: passo 10, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 10, immagine 2 di 2
    • Place the tip of your opening tool or spudger under the edge of the battery connector, and pry the connector straight up from its socket to disconnect from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. ZTE Axon 7 Screen Replacement: passo 11, immagine 1 di 1
    • To remove the battery, use a spudger to carefully pry and slide along the edges of the battery in small increments to release the adhesive.
    • The adhesive under the battery is strong. Be sure to avoid puncturing and bending the battery.
    • Under the battery, on the left side, is a display cable. Be careful not to damage this cable if future intentions are to reuse the display for any purpose.
    Chiedi a FixBot
    Aggiungi Commento
  12. ZTE Axon 7 Screen Replacement: passo 12, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 12, immagine 2 di 2
    • Gently apply force and lift the battery out.
    • If you're having trouble lifting the battery, use the opening pick to slide further under the battery. This will help separate it from the adhesive.
    • Remove the battery, and replace with a new battery. Recycle old batteries as stated by your local regulations.
    Chiedi a FixBot
    Aggiungi Commento
  13. ZTE Axon 7 Screen Replacement, Screen: passo 13, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove a single 2.0 mm screw near the vibration motor.
    Chiedi a FixBot
    Aggiungi Commento
  14. ZTE Axon 7 Screen Replacement: passo 14, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 14, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two 2.0 mm screws securing the white speaker cover.
    • Remove the speaker cover.
    Chiedi a FixBot
    Aggiungi Commento
  15. ZTE Axon 7 Screen Replacement: passo 15, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 15, immagine 2 di 2
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial antenna cable.
    • To reinstall, hold the connector in place and gently press it straight down. This connector should “snap” into the socket much like the metal snaps on a jacket.
    Chiedi a FixBot
    Aggiungi Commento
  16. ZTE Axon 7 Screen Replacement: passo 16, immagine 1 di 3 ZTE Axon 7 Screen Replacement: passo 16, immagine 2 di 3 ZTE Axon 7 Screen Replacement: passo 16, immagine 3 di 3
    • Use a spudger to pry under the USB-C board and lift it from the chassis.
    • There is adhesive underneath the charging port so work the spudger around the perimeter of the USB-C board to ease it out before trying to remove it fully.
    Chiedi a FixBot
    Aggiungi Commento
  17. ZTE Axon 7 Screen Replacement: passo 17, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 17, immagine 2 di 2
    • Disconnect the vibration motor cable by placing the tip of an opening tool or spudger under the edge of the connector.
    • Pry the connector straight up from its socket.
    Chiedi a FixBot
    Aggiungi Commento
  18. ZTE Axon 7 Screen Replacement: passo 18, immagine 1 di 3 ZTE Axon 7 Screen Replacement: passo 18, immagine 2 di 3 ZTE Axon 7 Screen Replacement: passo 18, immagine 3 di 3
    • Use a spudger to pry the lower speaker from the case.
    • The speaker is set in tight so you may need to use slight force to get it out.
    • Use tweezers to remove the lower speaker out of the device.
    Chiedi a FixBot
    Aggiungi Commento
  19. ZTE Axon 7 Screen Replacement: passo 19, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 19, immagine 2 di 2
    • Place the tip of your opening tool or spudger under the edge of the two press connectors on the left side of the motherboard.
    • Pry the connector straight up from its socket to disconnect from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  20. ZTE Axon 7 Screen Replacement: passo 20, immagine 1 di 2 ZTE Axon 7 Screen Replacement: passo 20, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 3.0 mm screws securing the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  21. ZTE Axon 7 Screen Replacement: passo 21, immagine 1 di 3 ZTE Axon 7 Screen Replacement: passo 21, immagine 2 di 3 ZTE Axon 7 Screen Replacement: passo 21, immagine 3 di 3
    • Lift and remove the motherboard using tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  22. ZTE Axon 7 Screen Replacement: passo 22, immagine 1 di 3 ZTE Axon 7 Screen Replacement: passo 22, immagine 2 di 3 ZTE Axon 7 Screen Replacement: passo 22, immagine 3 di 3
    • Use a spudger to pry the top speaker out from the phone chassis.
    • Remove the top speaker with tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  23. ZTE Axon 7 Screen Replacement: passo 23, immagine 1 di 1
    • Use tweezers to pull the volume/power buttons up and out from the display frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repeat the steps in reverse order to reassemble into new display assembly. Use the 2mm Tesa Tape to secure the battery and speaker grills into place during reassembly.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 19
Tutti i Tempi: 838
