Salta al contenuto principale
Xbox Series X Southbridge Board Replacement
Cosa ti serve
  1. Xbox Series X Southbridge Board Replacement, Uncover the back panel screws: passo 1, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Uncover the back panel screws: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Southbridge Board Replacement: passo 2, immagine 1 di 3 Xbox Series X Southbridge Board Replacement: passo 2, immagine 2 di 3 Xbox Series X Southbridge Board Replacement: passo 2, immagine 3 di 3
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Southbridge Board Replacement, Remove the back panel screws: passo 3, immagine 1 di 1
    Magnetic Project Mat
    $19.95
    Compra
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Southbridge Board Replacement, Unclip the back panel: passo 4, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Unclip the back panel: passo 4, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Unclip the back panel: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Southbridge Board Replacement: passo 5, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 5, immagine 2 di 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Southbridge Board Replacement, Remove the back panel: passo 6, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the back panel: passo 6, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the back panel: passo 6, immagine 3 di 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Southbridge Board Replacement: passo 7, immagine 1 di 3 Xbox Series X Southbridge Board Replacement: passo 7, immagine 2 di 3 Xbox Series X Southbridge Board Replacement: passo 7, immagine 3 di 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Southbridge Board Replacement, Remove the fan screws: passo 8, immagine 1 di 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X Southbridge Board Replacement, Disconnect the fan cable: passo 9, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the fan cable: passo 9, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the fan cable: passo 9, immagine 3 di 3
    Compra
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X Southbridge Board Replacement, Remove the fan: passo 10, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the fan: passo 10, immagine 2 di 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you are replacing the fan, a new fan will probably not include the plastic installation bracket. The bracket is attached to the fan with four T10 Torx screws. This is not pictured in this guide.
  11. Xbox Series X Southbridge Board Replacement, Unlatch the base: passo 11, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Unlatch the base: passo 11, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Unlatch the base: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Southbridge Board Replacement, Twist and remove the base: passo 12, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Twist and remove the base: passo 12, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Twist and remove the base: passo 12, immagine 3 di 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X Southbridge Board Replacement, Remove the optical drive screws: passo 13, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the optical drive screws: passo 13, immagine 2 di 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Southbridge Board Replacement, Remove the vibration isolator: passo 14, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the vibration isolator: passo 14, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the vibration isolator: passo 14, immagine 3 di 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Southbridge Board Replacement, Disconnect the power and data cables: passo 15, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the power and data cables: passo 15, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the power and data cables: passo 15, immagine 3 di 3
    Compra
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X Southbridge Board Replacement, Remove the optical drive: passo 16, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the optical drive: passo 16, immagine 2 di 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Southbridge Board Replacement, Disconnect the USB port cable: passo 17, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the USB port cable: passo 17, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the USB port cable: passo 17, immagine 3 di 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Southbridge Board Replacement: passo 18, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 18, immagine 2 di 2
    Compra
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, apply an iOpener or carefully heat it with a hair dryer to soften the adhesive.
  19. Xbox Series X Southbridge Board Replacement, Disconnect the power button cable: passo 19, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the power button cable: passo 19, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the power button cable: passo 19, immagine 3 di 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X Southbridge Board Replacement, Remove the chassis screws: passo 20, immagine 1 di 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Southbridge Board Replacement, Peel up the USB port cable: passo 21, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Peel up the USB port cable: passo 21, immagine 2 di 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
  22. Xbox Series X Southbridge Board Replacement, Remove the center chassis assembly: passo 22, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis assembly: passo 22, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis assembly: passo 22, immagine 3 di 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Southbridge Board Replacement, Unlatch the chassis strap: passo 23, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Unlatch the chassis strap: passo 23, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Unlatch the chassis strap: passo 23, immagine 3 di 3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Xbox Series X Southbridge Board Replacement: passo 24, immagine 1 di 3 Xbox Series X Southbridge Board Replacement: passo 24, immagine 2 di 3 Xbox Series X Southbridge Board Replacement: passo 24, immagine 3 di 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Xbox Series X Southbridge Board Replacement, Remove the power cable port: passo 25, immagine 1 di 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Xbox Series X Southbridge Board Replacement: passo 26, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 26, immagine 2 di 2
    • Lift the power connector out of its recess in the chassis.
  27. Xbox Series X Southbridge Board Replacement, De-route the power cables: passo 27, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, De-route the power cables: passo 27, immagine 2 di 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Xbox Series X Southbridge Board Replacement: passo 28, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 28, immagine 2 di 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Xbox Series X Southbridge Board Replacement, Remove the corner cover: passo 29, immagine 1 di 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Xbox Series X Southbridge Board Replacement: passo 30, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 30, immagine 2 di 2
    Compra
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Xbox Series X Southbridge Board Replacement, Remove the accessory antenna board: passo 31, immagine 1 di 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Xbox Series X Southbridge Board Replacement: passo 32, immagine 1 di 3 Xbox Series X Southbridge Board Replacement: passo 32, immagine 2 di 3 Xbox Series X Southbridge Board Replacement: passo 32, immagine 3 di 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  33. Xbox Series X Southbridge Board Replacement, Remove the board shield: passo 33, immagine 1 di 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Xbox Series X Southbridge Board Replacement: passo 34, immagine 1 di 3 Xbox Series X Southbridge Board Replacement: passo 34, immagine 2 di 3 Xbox Series X Southbridge Board Replacement: passo 34, immagine 3 di 3
    • Lift up the board shield to remove it from the center chassis.
  35. Xbox Series X Southbridge Board Replacement, Remove the chassis strap: passo 35, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the chassis strap: passo 35, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the chassis strap: passo 35, immagine 3 di 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Xbox Series X Southbridge Board Replacement: passo 36, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 36, immagine 2 di 2
    • Remove the chassis strap.
  37. Xbox Series X Southbridge Board Replacement, Remove the 10-pin power cable: passo 37, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the 10-pin power cable: passo 37, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the 10-pin power cable: passo 37, immagine 3 di 3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  38. Xbox Series X Southbridge Board Replacement, Remove the 2-pin power cable: passo 38, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the 2-pin power cable: passo 38, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the 2-pin power cable: passo 38, immagine 3 di 3
    • Grip and compress the locking tab on the 2-pin power connector.
  39. Xbox Series X Southbridge Board Replacement, Open the cable guide: passo 39, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Open the cable guide: passo 39, immagine 2 di 2
    • Open the lid on the power supply's plastic cable guide.
  40. Xbox Series X Southbridge Board Replacement, Remove the power supply screws: passo 40, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the power supply screws: passo 40, immagine 2 di 2
    • Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
    • Three 35 mm silver screws
    • One 8.8 mm black screw
  41. Xbox Series X Southbridge Board Replacement, Remove the power supply: passo 41, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the power supply: passo 41, immagine 2 di 2
    • Remove the power supply.
  42. Xbox Series X Southbridge Board Replacement, Remove the Wi-Fi board: passo 42, immagine 1 di 1
    • Use a T8 Torx driver to remove the three 8.8 mm screws securing the Wi-Fi antenna board.
  43. Xbox Series X Southbridge Board Replacement: passo 43, immagine 1 di 3 Xbox Series X Southbridge Board Replacement: passo 43, immagine 2 di 3 Xbox Series X Southbridge Board Replacement: passo 43, immagine 3 di 3
    • Don't pull the antenna board up until it is completely disconnected.
    • Remove the antenna board.
  44. Xbox Series X Southbridge Board Replacement, Disconnect the interconnect cable: passo 44, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the interconnect cable: passo 44, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Disconnect the interconnect cable: passo 44, immagine 3 di 3
    • Grip the base of the interconnect cable connector with your fingers.
    • Depress each side of the connector to unlock the cable locking tabs.
    • With the locking tabs depressed, grip the edges of the interconnect cable and pull it straight out of the connector to disconnect it.
    • With the locking tabs depressed correctly, the interconnect cable will slide out with very little force.
    • During reassembly, the interconnect cable should "snap" into place when fully inserted.
  45. Xbox Series X Southbridge Board Replacement, Remove the center chassis: passo 45, immagine 1 di 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis: passo 45, immagine 2 di 3 Xbox Series X Southbridge Board Replacement, Remove the center chassis: passo 45, immagine 3 di 3
    • Lift the center chassis off of the motherboard and heatsink assembly.
    • Route the interconnect cable through the cutout on the center chassis as you remove it.
  46. Xbox Series X Southbridge Board Replacement, Remove the southbridge board shield: passo 46, immagine 1 di 1
    • Use a T8 Torx driver to remove the seven 8.8 mm screws securing the southbridge board shield.
  47. Xbox Series X Southbridge Board Replacement: passo 47, immagine 1 di 2 Xbox Series X Southbridge Board Replacement: passo 47, immagine 2 di 2
    • Remove the board shield.
  48. Xbox Series X Southbridge Board Replacement, Remove the cable guide: passo 48, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the cable guide: passo 48, immagine 2 di 2
    • Lift up to remove the power supply cable guide from the southbridge board.
  49. Xbox Series X Southbridge Board Replacement, Remove the southbridge board: passo 49, immagine 1 di 2 Xbox Series X Southbridge Board Replacement, Remove the southbridge board: passo 49, immagine 2 di 2
    • Remove the southbridge board from the center chassis.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Altre 6 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
116.213 Reputazione
339 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.524 Guide realizzate
Un commento
I replace the south bridge board and now my console turns on then off instantly after replacing it. I know the board was working since i got it from another working console that just had a bad HDMI port. Originally this console would turn on then off so that’s when i change the power supply and it worked but the eject button would not work so that’s when I changed the board and after doing that its now turning on then off instantly like it use to do. Let me know if theirs anything else to check in case i missed anything or if it’s just a bad main board. Thanks
360 N One - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 440
Tutti i Tempi: 12,312
