Salta al contenuto principale
Wacom Intuos Pro Battery Replacement
Cosa ti serve
    1. Wacom Intuos Pro Battery Replacement, Battery: passo 1, immagine 1 di 3 Wacom Intuos Pro Battery Replacement, Battery: passo 1, immagine 2 di 3 Wacom Intuos Pro Battery Replacement, Battery: passo 1, immagine 3 di 3
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
      Chiedi a FixBot
      Aggiungi Commento
    2. Wacom Intuos Pro Battery Replacement: passo 2, immagine 1 di 3 Wacom Intuos Pro Battery Replacement: passo 2, immagine 2 di 3 Wacom Intuos Pro Battery Replacement: passo 2, immagine 3 di 3
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
      Chiedi a FixBot
      Aggiungi Commento
    3. Wacom Intuos Pro Battery Replacement: passo 3, immagine 1 di 2 Wacom Intuos Pro Battery Replacement: passo 3, immagine 2 di 2
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
      Chiedi a FixBot
      Aggiungi Commento
    4. Wacom Intuos Pro Battery Replacement: passo 4, immagine 1 di 2 Wacom Intuos Pro Battery Replacement: passo 4, immagine 2 di 2
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
      Chiedi a FixBot
      Aggiungi Commento
    5. Wacom Intuos Pro Battery Replacement: passo 5, immagine 1 di 2 Wacom Intuos Pro Battery Replacement: passo 5, immagine 2 di 2
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
7Commenti sulla guida
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - Rispondi Condividi
Do you know where can I find the battery replacement?
Valerio _ - Rispondi Condividi
Has anyone got a lint to the replacement battery?
Luca Di Meo - Rispondi Condividi
PTH-660 works fine without the battery, just remove it and use it with USB cable
Where can I find a replacement battery for this model?
Denise Hanly - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 53
Ultimi 30 giorni: 199
Tutti i Tempi: 11,773
