Introduzione
Follow this guide to replace the head strap on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Cosa ti serve
Twist the eye tube relief knob clockwise to fully extend it.
Insert an opening pick between the eye relief knob and the head strap.
Gently pry with the opening pick while pulling the eye relief knob off until it is removed.
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Use your hand to gently pull the face gasket straight off of the headset.
Use your fingers to pull the tether cable straight up off of the head strap cable guide.
Insert your T6 Torx screwdriver into the hole on the face gasket bezel to remove the captive screw securing the left side of the head strap.
Skip to step 12.
Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
Use a T6 Torx screwdriver to remove the two 6.6 mm screws underneath the eye relief knob.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Altre 24 persone hanno completato questa guida.
5 Commenti
I'm having troubles with my left speaker, I just got done replacing it, is this the next step I wanna try in troubleshooting it? The last thing I want to do is buy a whole new headset? It cuts out when the strap moves. I've already replaced the cable as well.
Try to tighten left part of the strap (step 14)
When will they be in stock again
Any word on restocking for this part?
No stock for 2 Years now. Great...
