Introduzione
Follow this guide to replace the face gasket bezel on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Cosa ti serve
Twist the eye tube relief knob clockwise to fully extend it.
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Use your hand to gently pull the face gasket straight off of the headset.
Use your fingers to pull the tether cable straight up off of the head strap cable guide.
Pull the tether cable straight back out of the headset.
Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
