Salta al contenuto principale
VTechCS6719-16 Speaker Replacement
Cosa ti serve
  1. VTechCS6719-16 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Remove the sliding cover on the back of the phone case.
    Chiedi a FixBot
    Aggiungi Commento
  2. VTechCS6719-16 Speaker Replacement: passo 2, immagine 1 di 1
    • Now remove the battery by lifting it and removing the two pin cable.
    Chiedi a FixBot
    Aggiungi Commento
  3. VTechCS6719-16 Speaker Replacement: passo 3, immagine 1 di 1
    • Unscrew the two 10mm screws on the back of the phone base.
    Chiedi a FixBot
    Aggiungi Commento
  4. VTechCS6719-16 Speaker Replacement: passo 4, immagine 1 di 1
    • Using the metal spudger edge along the phone and locate the hooks and latches.
    • Locating each of them apply a light but firm lifting force to release the front and back case.
    Chiedi a FixBot
    Aggiungi Commento
  5. VTechCS6719-16 Speaker Replacement: passo 5, immagine 1 di 1
    • The front case should now be freed.
    • Put the front case aside for later.
    Chiedi a FixBot
    Aggiungi Commento
  6. VTechCS6719-16 Speaker Replacement: passo 6, immagine 1 di 1
    • There are two 10mm screws located at the top of the circuit board.
    • Unscrewing the screws allows for access to the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  7. VTechCS6719-16 Speaker Replacement: passo 7, immagine 1 di 1
    • Flipping the circuit board will expose the speaker rested in the white LCD base.
    • Gently using the scoop end of the spudger will free the speaker from the dock.
    • Careful not to jerk the speaker as it is still attached to the board.
    Chiedi a FixBot
    Aggiungi Commento
  8. VTechCS6719-16 Speaker Replacement: passo 8, immagine 1 di 1
    • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
    • If this is your first time soldering, check out this useful soldering guide.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
UMass Dartmouth, Team 5-5, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 32
Tutti i Tempi: 461
