Salta al contenuto principale
Tagital T7X Battery Replacement
Cosa ti serve
    1. Tagital T7X Battery Replacement, Case: passo 1, immagine 1 di 3 Tagital T7X Battery Replacement, Case: passo 1, immagine 2 di 3 Tagital T7X Battery Replacement, Case: passo 1, immagine 3 di 3
      • Place the Tagital T7X on a sturdy surface.
      • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
      Chiedi a FixBot
      Aggiungi Commento
    1. Tagital T7X Battery Replacement, Battery: passo 2, immagine 1 di 2 Tagital T7X Battery Replacement, Battery: passo 2, immagine 2 di 2
      • Follow the attached wires to the positive and negative connections.
      Chiedi a FixBot
      Aggiungi Commento
    2. Tagital T7X Battery Replacement: passo 3, immagine 1 di 3 Tagital T7X Battery Replacement: passo 3, immagine 2 di 3 Tagital T7X Battery Replacement: passo 3, immagine 3 di 3
      • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
      • Touch the tip of the soldering iron to the solder connecting the negative wire.
      • Pull back on the wire with the iron in place, removing it from the hot solder.
      • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
      • Repeat this step for the positive wire.
      Chiedi a FixBot
      Aggiungi Commento
    3. Tagital T7X Battery Replacement: passo 4, immagine 1 di 3 Tagital T7X Battery Replacement: passo 4, immagine 2 di 3 Tagital T7X Battery Replacement: passo 4, immagine 3 di 3
      • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
      • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Kevin Dennis
Membro da: 02/10/16
184 Reputazione
Una guida realizzata
USF Tampa, Team 2-1, Sullivan Spring 2016 Membro di USF Tampa, Team 2-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G1
4 Membri
12 guide realizzate
1Commento della guida
We're can I get a battery? And I don't think the part should have died in less than a year . The battery lasted less than 6 mos. I bought the tablet for my mom to play cards on and that's it .She doesn't go on line. I put a book on it before I gave it to her and that is it. She doesn't even use it every day . What's the deal?
Melanie Bouy - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 1,393
