Salta al contenuto principale
Surface Laptop Studio Battery Replacement
Cosa ti serve
  1. Surface Laptop Studio Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
    Chiedi a FixBot
  2. Surface Laptop Studio Battery Replacement: passo 2, immagine 1 di 2 Surface Laptop Studio Battery Replacement: passo 2, immagine 2 di 2
    • Remove the two rubber feet on the lower case with an opening tool.
    Chiedi a FixBot
  3. Surface Laptop Studio Battery Replacement: passo 3, immagine 1 di 1
    • Remove the two screws with a T3 Torx screwdriver.
    Chiedi a FixBot
  4. Surface Laptop Studio Battery Replacement: passo 4, immagine 1 di 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
    Chiedi a FixBot
  5. Surface Laptop Studio Battery Replacement: passo 5, immagine 1 di 2 Surface Laptop Studio Battery Replacement: passo 5, immagine 2 di 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
    Chiedi a FixBot
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: passo 6, immagine 1 di 2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: passo 6, immagine 2 di 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
    Chiedi a FixBot
  7. Surface Laptop Studio Battery Replacement, Battery: passo 7, immagine 1 di 2 Surface Laptop Studio Battery Replacement, Battery: passo 7, immagine 2 di 2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
    Chiedi a FixBot
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.c
6Commenti sulla guida
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - Rispondi Condividi
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - Rispondi Condividi
The what you need section should also mention Surface Laptop Studio Cosmetic Plate - Genuine, possibly as an optional part.
Ronno Das - Rispondi Condividi
Great point, Ronno! We added that to the parts list. Thanks for your comment.
Connor Bassolino - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 20
Ultimi 7 giorni: 117
Ultimi 30 giorni: 478
Tutti i Tempi: 15,117
