Introduzione
In this guide you will remove the back cover of the device and partially remove the motherboard. Disconnect the screen from the motherboard using a soldering iron and replace it with a new screen.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Cosa ti serve
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Remove the Speakers
Use the tweezers to remove the speakers from their compartments.
Remove the large ribbon cable from the socket that attaches it to the motherboard.
Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
Ensure that the motherboard and all other items are off before continuing.
Separate the screen and back housing by gently pulling on it.
Altre 4 persone hanno completato questa guida.
1Commento della guida
what is the part number & where can I get a replacement screen for the SC-8809
