Salta al contenuto principale
Sostituzione gruppo altoparlanti Nintendo 3DS
Cosa ti serve
  1. Sostituzione gruppo altoparlanti Nintendo 3DS, Cover posteriore: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    • Usa un cacciavite Phillips PH00 per allentare le quattro viti lungo la parte superiore della cover posteriore.
    • Tutte le viti in questo dispositivo sono viti JIS. I cacciaviti Phillips PH000-PH1 ufficiali di iFixit sono progettati per essere compatibili con le viti JIS, quindi sono sicuri da usare. Usare un cacciavite diverso da un cacciavite ufficiale iFixit o da un cacciavite JIS potrebbe causare lo spanamento delle viti.
    • Le viti sono tenute in posizione da rondelle di bloccaggio e non usciranno dalla cover posteriore.
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - Replica
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - Replica
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - Replica
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - Replica
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - Replica
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - Replica
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - Replica
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - Replica
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - Replica
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - Replica
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - Replica
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - Replica
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - Replica
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
    It's JIS #00
    It's not the same thing
    Alstein Einbert - Replica
    To all the people that seem to think it's ok to tell people to use a phillips
    A PHILLIPS WILL damage the head of a JIS screw.
    The middle is thicker, which breaks the inner corners and the angle is less extreme causing it to slip out
    The extra pressure you add is to break that screw into a "phillips-ier" shape
    A newbie will still slip out and risk stipping the scew
    Btw you don't need to press hard with a JIS driver in a JIS screw
    If you don't know what you are doing, please refrain from editing this
    "All screws in this device are JIS screws. All official iFixit Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws."
    - dude who doesn't know anything
    Hi Alstein!
    You're right about most Phillips screwdrivers damaging JIS screws, but our Phillips bits (#000–1) are designed to be compatible with JIS of that size. We can't guarantee that Phillips drivers from other manufacturers are also cross compatible. We added the aforementioned bullet as a clarifier for this difference.
    Alex Diaz-Kokaisl -
    Hi Alex
    The bit still slips out easier due to the less extreme vertical angle, causing someone inexperienced to damage their screws.
    I and the Nintendo Homebrew community (talking about the hardware repair part of it) believe that even if it's true that the bit is shaped to cause less damage its completly wrong to tell someone to use the wrong bit as we get both people who ask "this bit is JIS friendly right" on normal phillips screwdrivers and people who come crying that they stripped their screws and have 0 idea why everyday so we know for a fact people are taking these kind of messages the wrong way.
    I believe the message i am putting is important as it tells the user the bits are different, tells them what to do if they don't have a JIS screwdriver and the damage its gonna cause.
    I'd agree to add a bullet that clarifies that ifixit phillips screwdrivers are designed to cause less damage under our disclaimer, not to just say phillips is fine to use on JIS
    Alstein Einbert -
    why is this guide telling you to use a Phillips screwdriver on a JIS
    this is just wrong
    "All screws in this device are JIS Screws, Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screw" wtf is this
    so you are saying that
    1. ifixit's phillips bit is a JIS because yes a JIS will work fine in a phillips screw, not vice versa.
    2. "use a ifixit phillips screwdriver that's the right screwdriver" instead of the jis one they might already have EVEN MAYBE FROM IFIXIT.
    yeah you mention in passing "or you could use a JIS Screwdriver but you should be mentioning in passing that ifixits phillips is ji-... ahem... i mean is compatible with jis screws
    this is absolutely stupid. Add that with the lack of care for looking for selling long lasting products like batteries and the lower quality of the recent bits i think ifixit is at its end.
    Daninator - Replica
    "i think ifixit is at its end." not in any way overdramatic at all
    FarmYard Gaming -
  2. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 2, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 2, immagine 2 di 2
    • Tieni il dispositivo in una mano e giralo.
    • Afferra il bordo superiore della cover posteriore con l'altra mano in modo che non ritorni al suo posto da sola.
    • Gira ancora il 3DS in modo che la cover posteriore sia rivolta verso di te.
    • Tira la cover verso l'alto per rimuoverla dal dispositivo.
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - Replica
  3. Sostituzione gruppo altoparlanti Nintendo 3DS, Batteria: passo 3, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS, Batteria: passo 3, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS, Batteria: passo 3, immagine 3 di 3
    • Infila uno strumento di apertura in plastica nella fessura nella scocca inferiore sopra la batteria.
    • Fai leva con lo strumento di apertura in plastica per sollevare la batteria.
    • Afferra il bordo superiore della batteria e sollevalo dalla scocca inferiore.
  4. Sostituzione gruppo altoparlanti Nintendo 3DS, Scocca inferiore: passo 4, immagine 1 di 1
    • Usa un cacciavite JIS #00 per rimuovere le nove viti nere da 6,3 mm dal case inferiore.
    • Le viti JIS (Japanese Industrial Standards) non sono uguali alle viti Phillips. Per evitare di spanare queste viti, assicurati di usare un cacciavite JIS #00 e non un cacciavite Phillips #00. Puoi usare un Phillips #00 applicando molta forza verso il basso, ma attenzione: ciò potrebbe deformare la testa della vite e rischi di spanarla.
    • Il cacciavite a testa Phillips di iFixit è progettato per ridurre i danni alle viti con testa JIS, quindi dovrebbe andare bene utilizzarlo, ma applica comunque più forza. Assicurati che sia il cacciavite ufficiale di iFixit, poiché non siamo a conoscenza di altri produttori che offrano questa caratteristica.
    • Usa un cacciavite JIS #00 per rimuovere la vite argentata da 2,4 mm sopra lo slot della cartuccia di gioco.
    Had to give up at this point. Tried using the ifixit #00 phillips screwdriver to take out two screws and ended up stripping them.
    Demios - Replica
    Stuck at the same spot, those screws are in there really tight.
    John Pasula - Replica
    Ruined my screws because of incorrect head, thanks!
    3dsuser - Replica
    I had so much trouble with these screws, I gave up. Unfortunately, I can't accept failure so tried again. I figured out if you turn it right before you loosen it worked. Maybe it was just me, but I turned it right then kept pressure as I turned to loosen. I was surprised I hadn't stripped any screws out.
    Nicole Bauer - Replica
    Does anyone have any idea of how to remove these screws. I've pretty badly stripped the screws and I've gone to 20+ pages trying to figure this. I'm considering just prying the !@#$ thing.
    Vino - Replica
    use a dremil and make it a flat head
    Ralph Prowant -
    ruined my screws here too...what the !@#$ nintendo?
    trying to survive a nuclear meltdown inside the !@#$ thing
    Hamza Jarkas - Replica
    More like trying to subtly enforce planned obsolescence by not allowing you to make repairs to your device.
    Ullyssys -
    I used a #00 Philips 1/8" bit with no problem; however, the narrow diameter of the counter sunk hole can inhibit making secure contact with the screw head. You can be using the right bit (#00) but if the diameter of the bit shaft is too big you won't get proper contact.
    I found this to be an excellent guide. Thanks
    Dave W - Replica
    Unscrewed the nine 6.3 mm screws using the J000 bit from the iFixit 54 bit driver kit without much effort & without stripping the screw heads. Just gotta really position the bit correctly on the screw to have a proper fitting & not strip the screw heads.
    STZ9 - Replica
    The screws didn't strip but the philips screw driver did? @__@
    These are rough either way.
    John Zhou - Replica
    I used a "Whia 273 - PH000x40" screwdriver and held it firmly pushing the palm of my hand on the yellow end of the screwdriver and rocked the screw slightly (counter clockwise and clockwise) until it started to move. Then, without letting up on the pressure I carefully backed it out. The screwdriver is excellent because it is hardened (unlike some cheapo's out there) and the very tip is blunt not sharp. If the tip is too sharp, the point will bottom out in the screw and the sides that do all the work, won't be able to fully contact the inside of the screw. This screwdriver fits so well that the screws actually stick to it once they are removed. If the screwdriver moves AT ALL when you initially try it in the screw, STOP and find a better one. Also, start with the screws in the center, somehow they seem a little easier until you get the feel for it.
    Paul -
    Push down hard and turn counter-clockwise, or push down and rotate 3DS counter-clockwise until screw is loose.
    Jonathan - Replica
    Had the exact same problem, even tried the #000 screw driver too. Stripped the screws due to how tightly they are screwed in there and how easy they strip. I am now unsure what to do from here or if all I can do is give up.
    Sean Baldwin - Replica
    I second the one who suggested the Whia 273 PH000x40 screwdriver. I had a terrible time unscrewing these screws, and almost stripped them using a cheaper #000 screwdriver. Also tried a 3/16" flathead and destroyed the screwdriver. I bought the Whia and glad I did. It fit perfectly and did not slip at all. DEFINITELY recommend purchasing this high-quality screwdriver. Cost about $10 but well worth it to avoid the hassle.
    pbrazis - Replica
    The best way I found that works quite well, if you find a screwdriver or bit that is good enough: hold the screwdriver or bit with tons of pressure, and rotate the 3DS clockwise! It will come out in 5-6 rotations, you can do this step in about 10 minutes this way (put down a cloth first, don't scratch the front!)
    Gannon Trueman - Replica
    I HAVE A WAY TO GET OUT THE STRIPED SCREW. Like you, I had screwed up and tried everything to get the screw out. Do NOT try the glue in that tiny hole, you will get the screw glued permanently in there. The rubber band doesn't work in that tight space either. As desperate as I was, I was trying anything from nail polish to cramming the screw driver in as hard as I possible could. Until I realized that I had a drill. Yes, with the smallest head, I drilled into the screw a little bit, messed with the part I was trying to get out, drilled a little more, messed around, and then finally on my last attempt, I had successfully drilled off the top of the screw rendering the part free. It doesn't matter which drill you use as long as you can fit the head into the hole. Then drill forward like you are trying to drill a hole through wood. Now the only problem is that the remainder of the screw will be stuck in its place. All you really have to do is get a set of pliers and twist that puppy out. And there you go!
    YuuChan - Replica
    Most likely though, if you have all the other screws out and only have one striped screw, the part should just pop off and you wouldn't have to drill the entire head off the screw.
    YuuChan - Replica
    Got a brand new #00 screw drive and it striped the first time used it. So now I'm using eyeglass repair kit screw driver and it lasts longer that the one I got of of eBay.
    And I tried all of those tactics that people have been giving and none of them are working.
    The wiha 273 PH #000×40 unsrews it easily! It has a magnet on it!
    Najee - Replica
    I’m cant get these %#*@ screws out i want to die…
    FRØSTBIT3 - Replica
    Oh god, someone help i can’t get them out.
    Mark LaPierre - Replica
    omg everyone is struggling in here smh. I used my PH000 screwdriver made sure it went in aligned to the screws and applied pressure while turning counterclockwise. once it started the screw started lifting i stopped applying pressure and they lifted beautifully. saved damaging my screws with this technique. I also used the same screwdriver size to remove the orange screw where the game slot is. Yall are welcome lol
    Evelyn Avalos - Replica
    USE A DIFFERENT SCREWDRIVER.
    I was stuck on this for an hour. If your screwdriver is very thin, you won't get the grip necessary if your screws are on tight. I thought my screws were stripped but I switched to a bigger screwdriver and it was effortless. Just MAKE SURE IT IS A 00 PHILLIPS HEAD.
    brendon - Replica
    Use a JIS screwdriver, not Phillips! I bought the recommended screwdriver from this website and couldn't remove any screws. I went and purchased a J00 screwdriver and removed them quickly.
    danielle - Replica
    I used what I believe is a 1.5mm screwdriver which I received in one of those 60 in 1 precision screwdriver sets. It fit perfectly and much more snugly compared to any of the J0 - J000 bits.
    Andrew - Replica
    You should change the Screwdriver Type used. A Philipshead can damage Screws and/or Console. Use JIS Type-J00, which iFixIt sells, yes.
    J022 - Replica
    Lmao I've been using a Philips #00 for years and not known it was the wrong type. I ended up being fine here every time, a magnetic head helps. It's actually almost satisfying getting these ones out.
    using a J00 head. no luck at first (that's why i'm here lol) read one comment here saying turn a little bit clockwise and then try to unscrew and that did the trick!
    also, held the console with one hand and the screwdriver with the other for applying pressure but not to much or at least to grab the other side of the pressured place instead of letting the hinge press against the table.
    Thomas - Replica
  5. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 5, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 5, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 5, immagine 3 di 3
    • Solleva il bordo inferiore della scocca posteriore dal resto del Nintendo 3DS.
    • Ci sono ancora due cavi a nastro che collegano la scheda madre alla scocca, quindi non rimuoverla del tutto.
    • Usa uno strumento di apertura in plastica per scollegare i connettori dei tasti dorsali dalle loro prese sulla scheda madre sollevandoli.
    • Rimuovi la scocca inferiore dal dispositivo.
    When assembling, make sure that L ribbon is inside the case and R ribbon is not under the aluminium battery case. I got them both cut accidentally and had to replace :(
    Marek Jakóbiak - Replica
    Man muss die Folienkabel für die Tasten nicht unbedingt abziehen wenn man einen Gegenstand dahinter stellt, an dem man den Deckel senkrecht anlehnen kann.
    Jean - Replica
    Don't listen to the german guy. It's very easy to pop back
    Bruno N - Replica
  6. Sostituzione gruppo altoparlanti Nintendo 3DS, Levetta analogica: passo 6, immagine 1 di 1
    • Svita le due viti a croce Phillips da 7,7 mm che fissano il retro della levetta analogica alla scheda madre.
    my screws wont stop spining what to i do? i have the same problem with other screws and this leavs my joystick very loss and it is dificult to muve it becuase it is aganst the case not lifted up? any sugestions? (sorry for my bad speling jaja im very bad at speling..)
    AppleTopic - Replica
    I think you stripped your screws. I think the best solution is to change the upper cover of the lower assembly and the screws. The fastest, but temporarily is to stick in some way the joystick housing to the cover, but it won’t last long, so do this only if you have to use your console while you wait the cover to come. Anyway, so not overtighten the new screws, or you will be in the same situation once again.
    Daniele Carminati -
  7. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 7, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 7, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 7, immagine 3 di 3
    • Usa la parte piatta di uno spudger per fare leva sul retro della levetta analogica dalla scheda madre.
    • Solleva la levetta analogica dalla scheda madre e appoggiala sul suo retro in modo che il connettore del cavo a nastro sia accessibile.
    When reassembling verify that the circle pad control is oriented right. I had to go back in after completion when I realized it wasn't centered.
    Daniel Johnson - Replica
    I would not disable the back side all the way because it could really mess up your 3DS.
    masterspeggy3 - Replica
    From this step, follow this video https://youtu.be/XGdRim2Mvrk?t=627
    you can skipp from step 8 to 20
    lots of unnecessary steps
    Bruno N - Replica
  8. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 8, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 8, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 8, immagine 3 di 3
    • Usa la parte piatta di uno spudger o un'unghia per ruotare verso l'alto l'aletta di bloccaggio del connettore ZIF del cavo a nastro della levetta analogica.
    • Assicurati di star sollevando l'aletta di bloccaggio incernierata e non il connettore.
    • Solleva la levetta analogica dalla scheda madre.
    Can you replace a zif socket? The little metal pieces on mine broke off...
    Colton Alverson - Replica
    YOUR &&^&@@ HAHAHAAHA, no you cant you would have to purchase a new motherboard i feek you bro happened in my first time
    vrobinson -
    you might want to find someone who is skilled in component level microsoldering for that
    Samuel Martin -
    The retaining flap on mine broke off, is there any way to fix it?
    Madi Hansen - Replica
    Don't do this step! it is not necessary. you can skip steps 8 through 20
    S Maduras - Replica
    Skip steps 8 through 20. It will save a lot of time. Thanks S Maduras for the warning.
    clarissa.vetintegral - Replica
    Thanks S Maduras! Your tip
    made this super easy. No need for steps 8-20.
    Carl Vero -
    OH MY GOD THANK YOU SO MUCH!!!! I'm sure I would have destroyed my ds if I did all that
    Amber Selley -
    Just like everyone else I recommend skipping to step 21. You don't need to take all the components out to replace the circle pad.
    Callum M. - Replica
    Skip steps 8-20 like they said!! Doing all those unnecessary steps wasted so so much time and frustrated me hugely by causing me to damage my microphone ribbon cable…
    Falcon - Replica
    What do you mean by skipping 8-20? Do I not need to remove the screws in order to replace the lower LCD?
    Marion Saga -
    you know, after you disconnect the ribbon from the mobo, you can just remove the back discs and the rubber part. no need to go past here.
    TruGoose - Replica
  9. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 9, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 9, immagine 2 di 2
    • Per diminuire le possibilità di perdere le due guaine sotto la levetta analogica, potresti rimuoverle e metterle da parte.
    • Usa uno spudger o la punta di un cacciavite per sollevare le guaine e rimuoverle dal dispositivo.
    When reassembling, you can use the pointy end of the spudger to align the hold again with the joystick. It’ll probably have bounced around while you’re moving other things.
    anthonyhersey - Replica
    If your only goal is to replace the circle-pad, the following steps are unnecessary. You can skip to step 21, the removal of the circle-pad.
    Andrew - Replica
  10. Sostituzione gruppo altoparlanti Nintendo 3DS, Scheda lettore SD: passo 10, immagine 1 di 1
    • Svita le due viti a croce Phillips da 4,5 mm che fissano la scheda del lettore SD alla scheda madre.
  11. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 11, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 11, immagine 2 di 2
    • Usa la parte piatta di uno spudger per scollegare il connettore del cavo della scheda del lettore SD dalla sua presa sulla scheda madre sollevandolo.
  12. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 12, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 12, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 12, immagine 3 di 3
    • Infila la parte piatta di uno spudger tra la scheda del lettore SD e la scheda madre.
    • Solleva lentamente per allentare la scheda SD dallo schermo RF sotto di essa. Se sollevi troppo rapidamente, potresti strappare lo schermo o rompere i suoi punti di saldatura.
    • Passa lo spudger lungo i lati della scheda SD per liberarla dall'adesivo che la tiene in posizione.
    • Una volta liberata, solleva la scheda del lettore SD dalla scheda madre.
    be careful on this step, the sd card board is adhered to the rf shield below it, and bay result in the shield becoming bent as it is only soldered on one side. pry from the side of the board facing the cartridge slot.
    alex chargeer - Replica
    I didnt notice that and I broke the solders here :(
    Tony Greco -
    mine came off will this make the system not power on or make somthing not work? what do i do know?
    What did come off? the sd card reader board, or the shield mentioned in the above comment?
    Daniele Carminati -
    When putting it all back together, its easier to put the ribbon connector on before laying on the SD board.
    Pepper - Replica
    The adhesive sticker between the RF shield and the SD slot got mauled quite badly as I separated them, will this turn out to be a problem later?
    Nico - Replica
  13. Sostituzione gruppo altoparlanti Nintendo 3DS, Scheda WiFi: passo 13, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS, Scheda WiFi: passo 13, immagine 2 di 2
    • Infila la parte piatta di uno spudger sotto un angolo della scheda WiFi e solleva la scheda dalla scheda madre.
    • Il cavo dell'antenna WiFi è ancora collegato alla scheda WiFi, quindi non puoi ancora rimuovere del tutto la scheda.
  14. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 14, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 14, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 14, immagine 3 di 3
    • Solleva la scheda WiFi dalla scheda madre e ruotala in modo che la faccia inferiore sia rivolta verso l'alto.
    • Usa la parte piatta di uno spudger per scollegare il connettore del cavo dell'antenna sollevandolo dalla sua presa sulla scheda WiFi.
    • Rimuovi la scheda WiFi dal dispositivo.
    That moment you bought all your supplies and realise while removing the wifi chip the antenna is not plugged in because you forgot to plug it in last time……… Scew me…
    Sidney the wolf - Replica
  15. Sostituzione gruppo altoparlanti Nintendo 3DS, Gruppo scheda madre: passo 15, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS, Gruppo scheda madre: passo 15, immagine 2 di 2
    • Afferra il cavo a nastro del microfono con un paio di pinzette vicno al microfono stesso.
    • Tira il microfono verso l'alto per sfilarlo dalla scocca superiore.
  16. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 16, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 16, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 16, immagine 3 di 3
    • Usa la parte piatta di uno spudger o un'unghia per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo a nastro del gruppo dello speaker.
    • Assicurati di agire sull'aletta di bloccaggio incernierata e non sul connettore. Danneggiare il connettore o il cavo causa un lampeggio del LED di alimentazione quando premi il tasto di accensione, ma la console non si accende.
    • Sfila il cavo a nastro del gruppo dello speaker dalla sua presa con un paio di pinzette.
    Can there be a guide on how to replace this part? I pry on the socket accidentally.
    im just a Ordinary marker - Replica
    I don't even know where they sell a new socket for this, but you'd need to have a soldering station and know how to micro solder. assuming no pads where ripped off then you'd just solder it back down. if a pad broke then you'd need to run jumpers to fix it. in short its very difficult and expensive to fix unless you have the know how and the tools already.
    ssanchez7610 -
  17. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 17, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 17, immagine 2 di 2
    • Usa la parte piatta di uno spudger o un'unghia per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo a nastro della camera.
    • Durante il rimontaggio ricordati che i contatti dorati sono rivolti verso la scheda madre (mentre quelli dorati del cavo sono rivolti dalla parte opposta).
    Be sure to fit the motherboard inbetween the joystick and volume slider in properly (you can double check by seeing if the volume slider on the outside goes up and down smoothly). When I closed it the first time it was stuck on full volume so I needed to go back in and readjust!
    Veronika Todd - Replica
    When putting the cable back I recommend to open the 3ds while keeping it face down so the cable has more room to fit.
    Roberto Cantu - Replica
    Thank you so much, opening the 3ds is needed to fit the cable back easily.
    Halefall -
    The camera ribbon cable contacts face towards the motherboard, the speaker ones face away.
    Nyuku - Replica
    skipped this step, didn't take the mobo out and continued from step 21
    Thomas - Replica
  18. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 18, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 18, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 18, immagine 3 di 3
    • Svita le sette viti a croce Phillips che fissano la scheda madre alla scocca superiore:
    • Quattro viti dorate da 2,5 mm
    • Due viti nere da 3,5 mm
    • Una vite cromata da 2,5 mm
    • Quando rimuovi questa vite il selettore del volume può cadere dal dispositivo.
    • Solleva il bordo della scheda madre che si appoggia al bordo inferiore del 3DS.
    Do yourself a favor and DON'T remove the 2.5 mm silver screw (yellow circle). It just holds in a little plastic bit under the volume control. The board comes out just fine with the screw still in. If you remove it, the plastic bit will fall out at random when you turn over the case.
    First time I took mine apart, I noticed something fall out later, tracked it down and then puzzled over what it was and where it came from.
    Chupi - Replica
    There is some adhesive where the AC adapter plugs in so I recommend watching out for that
    Devin Stephenson - Replica
    LISTEN TO CHUPI seriously that is such a pain to get back in
    NyxNullify - Replica
  19. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 19, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 19, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 19, immagine 3 di 3
    • Continua a sollevare e ruotare il gruppo della scheda madre finché non è appoggiato accanto al resto del dispositivo.
    • Usa la parte piatta di uno spudger o un'unghia per ruotare verso l'alto l'aletta di bloccaggio sul connettore ZIF del cavo a nastro dello schermo.
    • Assicurati di agire sull'aletta di bloccaggio incernierata e non sul connettore. Danneggiare il connettore o il cavo causerà un Nintendo 3DS che non avrà uno schermo superiore funzionale.
    Reinserting this ribbon cable is quite difficult. I found opening the case so that it sits upright at a 90 degree angle helps. The first two times I tried reassembling the top display did not work. Turned out that I was not inserting the ribbon cable in enough. I used tweezers to push this in by gently grabbing the ribbon cable. I was continually inspecting the cable for damage but apparently did not damage it. If anyone has a better idea on how to reinsert this cable I think others would greatly appreciate it.
    pbrazis - Replica
    Putting the cable back in is the hardest part out of all of this (if you can get past the screws near the beginning). If you have a friend that you trust very much and is very gentle, another pair of hands here really will help. If you're without a friend, make sure to use some flat, angled precision tweezers to push the ribbon in with one hand (pointed tweezers will do in a pinch but you'll have to be careful - I put a small dent in the ribbon and thought I'd broke it), and then use a spudge or something in the other to push the flap down.
    Also worth noting is that the ribbon for the top screen also handles the 3D - if you complete the guide and find you are unable to turn the 3D effect off, you didn't insert the ribbon enough, as I had the problem and re-inserting the ribbon fully fixed it.
    malcolmdemaggio - Replica
    Careful when reassembling -- watch the position of the black wifi antenna wire! I got mine most of the way back together and noticed it wouldn't close all the way. This wire had come out of the little posts holding it in place and was wedged between the screen and motherboard. Now I have to take it all apart again to fix this.
    Also if you're taking the board out of a working unit to get at the CLK signal to backup the NAND chip ("hardmod"), you don't need to remove the difficult ribbon cable in this step, or the other two wide ones at the top right from earlier. Leave them attached and swing the board out. It won't rotate a full 180 degrees to sit flat outside the unit, but you can open the screen 90 degrees to prop the rest up while having the board out on your table.
    Chupi - Replica
    I recommend not taking it off in the first place, as reattaching it is awfully difficult. You can easily clean out your abxy buttons with it still attached
    Martin - Replica
    I am having problems re-inserting the three ribbon cables (3DS XL). Do you need to flip up the retaining flaps first? (I just pulled them out of the slots when removing them.
    darren.brundell - Replica
    if the flap for the ribbon cable breaks what do you do
    lionmine ____ - Replica
    who else felt really proud after finally reinserting the cable
    Harrison Rigg - Replica
    The easiest way to get that ribbon back in is to hold it with some reverse tweezers that I fix it sells and use it to grab the ribbon and hold it while you fiddle with getting the ribbon in the slot. It’s super easy this way. You’ll have it installed in 36 seconds. Try it. (Reverse tweezers…press to release ones)
    Chris - Replica
  20. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 20, immagine 1 di 1
    • Rimuovi il gruppo della scheda madre dal resto del dispositivo.
    Make sure when putting the motherboard back onto the bottom part of the casing that the antenna wire is where it should be - the first time I put this back together the wire got loose and was smooshed in between the casing and the Y and Power buttons, causing them to be stiff/not work. Using the spudge should help in pushing the wire back into the slots along the inside of the case.
    when reassembling, watch out for the wireless on/off slider - i had started screwing things back in when i realized the slider had slipped to the wrong side, making the slider non functional. by the same token, watch out for the volume slider on the other side.
    meatshaped - Replica
  21. Sostituzione gruppo altoparlanti Nintendo 3DS, Protezione anteriore schermo superiore: passo 21, immagine 1 di 1
    • Prima di continuare con lo smontaggio, usa delle pinzette per rimuovere il diffusore in plastica trasparente del LED della connessione WiFi. Questa piccola componente può cadere da sola ed è difficile da ritrovare.
  22. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 22, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 22, immagine 2 di 2
    • Sfila il cavo dell'antenna WiFi dalla parte inferiore della scocca superiore.
    • Questo passaggio non è necessario se stai sostituendo solo la protezione anteriore. Comunque è richiesto per la sostituzione dello schermo superiore, degli altoparlanti, delle fotocamere e dell'antenna WiFi.
  23. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 23, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 23, immagine 2 di 2
    • Scalda i bordi della protezione anteriore dello schermo superiore con un asciugacapelli o una pistola termica per ammorbidire l'adesivo che lo fissa alla cornice dello schermo.
    • Inizia a separare i bordi della protezione anteriore con uno strumento di apertura in plastica.
    • Se hai difficoltà a separare la protezione, riscalda l'area dove sei arrivato con la pistola termica, quindi torna a fare leva. Fare troppa forza può crepare la protezione anteriore.
    Maybe a dumb question, but how would I go about reattaching the top screen if it's attached to the 3ds by an adhesive? If I have to use more adhesive to put it back on, what would be the recommended kind to do so?
    jgonsoski - Replica
    I have the same question/concern that "jgonsoski" has. Is the adhesive on the front panel still usable after it's pried off the display bezel? Or does it have to be removed? If so, what adhesive can be used or is suitable to adhere back the front panel to the display bezel?
    STZ9 - Replica
    adhesive is definitely reusable. I just completed this step. Please make sure the new display is ready to take the tape as soon as you remove it from the old display.
    Xpider - Replica
    Disclaimer: I replaced my front panel entirely, and threw away the old one.
    If you do not have a replacement front panel, gently removing it (without getting the adhesive oily from your fingers/dusty) and replacing it is an option. The adhesive is incredibly tacky, and while removing the front panel will weaken the adhesive - it will likely be sticky enough to do its job. If not, double-sided tape or small amounts of water based craft glue may help (disclaimer again: I haven't tried these)- do NOT use superglues/liquid cements/epoxies.
    Tai -
  24. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 24, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 24, immagine 2 di 2
    • Continua a separare i bordi restanti della protezione anteriore facendo scorrere lo strumento di apertura in plastica sotto ogni bordo.
    • Scaldare troppo poco farà piegare troppo o romperà la protezione anteriore, mentre scaldare troppo scioglierà e danneggerà il pannello LCD sottostante. Prenditi tutto il tempo necessario.
    BE VERY CAREFUL NOT TO MELT THE SPEAKERS. This happened to me and now one of the plastic covers for the speakers is melted inside the speaker itself, despite the display cover being undamaged. It is made of a much thinner plastic and i assume it heats up faster.
    Kishin Slayer - Replica
  25. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 25, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 25, immagine 2 di 2
    • Dopo aver scollato tutti i bordi, solleva la protezione anteriore dello schermo superiore dalla cornice dello schermo.
  26. Sostituzione gruppo altoparlanti Nintendo 3DS, Cornice posteriore dello schermo: passo 26, immagine 1 di 1
    • Svita le sei viti a croce Phillips da 3,6 mm che fissano la cornice posteriore dello schermo a quella anteriore.
    Some versions have a seventh screw under the right speaker, I almost broke mine because of that
    AD RC - Replica
  27. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 27, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 27, immagine 2 di 2
    • Gira il dispositivo in modo che la cornice posteriore dello schermo sia rivolta verso l'alto e la cerniera sia dalla parte opposta a te.
    • Solleva il bordo della cornice posteriore più vicino a te e ruotalo verso la cerniera.
    • Continua a sollevare la cornice posteriore dal dispositivo finché non l'hai rimossa del tutto.
    • Ci sono delle clip nella parte inferiore della cornice posteriore per tenerla ferma. Fai abbastanza forza da rilasciare i gancetti, ma stai attento a non romperli.
  28. Sostituzione gruppo altoparlanti Nintendo 3DS, Gruppo schermo superiore: passo 28, immagine 1 di 1
    • Rimuovi il regolatore della profondità 3D dalla cornice anteriore dello schermo.
    • Questo passaggio non è necessario per lo smontaggio, ma il regolatore molto probabilmente cadrà da solo. Rimuovendolo ora riduci le probabilità di perderlo.
    What if I need a new one
    cbryans - Replica
  29. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 29, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 29, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 29, immagine 3 di 3
    • Infila una sonda in metallo nello spazio sopra i tasti ABXY, toccando con la punta la cerniera in metallo.
    • Spingi la cerniera verso il centro della scocca superiore. Questo passaggio richiederà una buona dose di forza.
    • Nelle immagini viene mostrata la cerniera prima e dopo questo passaggio, guardandola dal retro dello schermo superiore.
    When reassembling you may find it difficult to get the bar back into the hole in the hinge. A couple of tips:
    * Reassemble it with the clamshell pieces in a ‘closed’ position (same position that you took it apart).
    * The pin/bar may have rotated slightly during disassembly (mine did). It only goes into the hole one way - the hole is actually a slot. If the alignment is off even a couple of degrees it won’t pop back in. If this happens simply lift the edge with the bar up out of the hinge and push the bar so it pops back out (like it was going into the hinge). The take a pair of pliers and gently rotate the bar to fix the alignment, pop the bar back to the ‘unhinged/open’ position, then reassemble.
    Bob Pony - Replica
    This comment saved me after 20 mins of frustration. Also, needle nose pliers work great to rotate the bar to proper position.
    Joe_271 - Replica
  30. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 30, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 30, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 30, immagine 3 di 3
    • Prima di continuare segnati come sono disposti i tre cavi a nastro (in che direzione guardano i contatti dorati) e in che ordine sono disposti gli uni sugli altri (quale cavo è sopra a quale altro). I cavi risulteranno troppo corti se non sono posizionati in questa configurazione.
    • Lentamente tira via il gruppo dello schermo superiore dalla scocca superiore.
    • Assicurati che i vari cavi a nastro scorrano attraverso la fessura nella scocca superiore.
    • Separa il gruppo dello schermo dalla scocca superiore.
  31. Sostituzione gruppo altoparlanti Nintendo 3DS, Gruppo altoparlanti: passo 31, immagine 1 di 2 Sostituzione gruppo altoparlanti Nintendo 3DS, Gruppo altoparlanti: passo 31, immagine 2 di 2
    • Fai scorrere con cura il cavo a nastro del gruppo dello speaker attraverso la fessura nella cornice dello schermo superiore.
    • Devi avvolgere delicatamente su loro stessi i cavi a nastro per fare in modo che ci passino: i cavi sono più larghi della fessura.
    You may want to use small pieces of scotch tape to reinforce each individual ribbon cable before proceeding, being careful not to cover the gold contacts. The cables can be very brittle and when rolled up tightly they can crack and break like a dry leaf. The tape can be left on the cables after removal and installation.
    Benjificus - Replica
  32. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 32, immagine 1 di 1
    • Svita le due viti a croce Phillips da 2,5 mm che fissano la scheda dell'altoparlante destro alla cornice dello schermo superiore.
  33. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 33, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 33, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 33, immagine 3 di 3
    • Usa la parte piatta di uno spudger o un'unghia per ruotare verso l'alto le alette di bloccaggio sui connettori ZIF dei cavi a nastro della barriera di parallasse.
    • Usa un paio di pinzette in metallo per scollegare i due cavi a nastro.
    does it matter if these cables are not connected?
    nuggets321 - Replica
  34. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 34, immagine 1 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 34, immagine 2 di 3 Sostituzione gruppo altoparlanti Nintendo 3DS: passo 34, immagine 3 di 3
    • Usa la parte piatta di uno spudger per rimuovere gli altoparlanti destro e sinistro dai loro alloggi nella cornice dello schermo superiore.
    • Solleva il LED di stato della fotocamera dalla cornice superiore con la punta di uno spudger.
    I accidentally broke the ribbon cable for the camera status LED, reckon I'll get away with it being broken or will it need replacing?
    Dean Withington - Replica
  35. Sostituzione gruppo altoparlanti Nintendo 3DS: passo 35, immagine 1 di 1
    • Rimuovi il gruppo dell'altoparlante dal gruppo dello schermo.
    Das Flexkabel des Lautsprechers muss nicht entfernt werden. Das macht die Montage hinterher nur schwieriger
    Hardver Doki - Replica
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 24 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
David Hodson
Membro da: 04/13/10
152.757 Reputazione
127 Guide realizzate
6Commenti sulla guida
Getting the new assembly ribbon cable through the hinge is excruciatingly tedious. I tore my cable when I tried fishing it through with a small hooked pry tool. Learn from my mistakes
Ellie Horne - Replica
Whatever you do, don’t accidentally hook the display ribbon cable into the slot for the speaker ribbon cable when reassembling. It holds it too firmly, and will rip easily. I now have to spend $15 on a new lcd ribbon cable.
Juicy Fruit - Replica
I bought a new speaker cable to replace on my sons 3ds. I’m in sure oh to connect the speakers to the new cable. Any help? Or are there any places out there that I can send it to get it fix?
laura1402 - Replica
This can be fix the error of the 3d screen comprovetion? i have a 3ds with that problem, any advice?
kosmosalfa - Replica
For reassembly: when trying to put the ribbon cable through the hinge, you need to curve the end a bit to make it ‘flush’ with the hinge. I would also reccomend pulling the black hinge part out and lace the ribbon cable throught that way, then lace it through the hinge part, and then put the black hinge part back in the hinge socket.
Electronik - Replica
a while after fixing my lcd ribbon cable broke. now i need to do this again. be craeful with the other ribbon cables when doing this
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 93
Ultimi 30 Giorni: 460
Tutti i Tempi: 61,776
