Introduzione
This replacement guide will address how to remove a damaged AV port from a Sony a7 model number ILCE-7 camera. The AV port is the centralized hub of all inputs and outputs for the camera. This step by step guide will provide the actions necessary to repair a faulty AV port.
If the camera is having difficulty connecting to an external device such as a computer or is unable to transfer photos and other files to an external storage platform then there is a possibility that the AV port is damaged. Before beginning this process, it may be helpful to reference this troubleshooting page, which could help with addressing issues before having to go through the tedious process of repairing the AV port. The special skill of soldering connectors will be required at certain points, a guide on how to do this can be found here.
Caution: It would be in the best interest of continuity to ensure that all files from the camera have been transferred and backed up. This replacement guide will require accessing the AV port and motherboard, which places the camera’s storage processes at risk of being damaged. If damage is incurred, there is a possibility that photos on the camera’s storage could be lost.
Cosa ti serve
Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
Using the blunt tweezers, remove the blue ribbon cable.
Peel off the small adhesive tape located on the top right side of the motherboard.
Take a soldering iron and place it onto a leg of the failed AV port.
Use a small flat head screwdriver to pry up each leg while the solder is molten.
Altre 2 persone hanno completato questa guida.
