Salta al contenuto principale
Sony GTK-XB5 Surge Fuse Replacement
Cosa ti serve
  1. Sony GTK-XB5 Surge Fuse Replacement, Top Casing: passo 1, immagine 1 di 1
    • Before you begin, be sure to unplug the speaker.
    • First, remove the eight screws on the speaker's back panel. These screws should be located on the top and bottom corners of the back, as well as along the sides.
    • Remove the 7.5 mm Phillips-head screws using a Phillips #1 screwdriver with a J sized head.
  2. Sony GTK-XB5 Surge Fuse Replacement: passo 2, immagine 1 di 2 Sony GTK-XB5 Surge Fuse Replacement: passo 2, immagine 2 di 2
    • Next, remove 4 more 7.5 mm Phillips-head screws on the top part of the speaker (where the power buttons and extra BASS buttons are located). Two of the screws are located on the underside of the handle and are hidden beneath black rubber covers. Remove the covers and use a Phillips #1 screwdriver to unscrew the screws.
    • The remaining two 7.5 mm Phillips-head screws are located on the base of the indented section of the speaker, pictured here. They are also hidden beneath black rubber covers. Repeat same process in removing the screws.
  3. Sony GTK-XB5 Surge Fuse Replacement: passo 3, immagine 1 di 2 Sony GTK-XB5 Surge Fuse Replacement: passo 3, immagine 2 di 2
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Gently lift up the entire top plastic section of the speaker. Do so slowly, the section is still connected to the circuitboard by a belt.
    • Gently remove the belt from its junction on the board, and after doing so the top plastic casing of the speaker will be fully detached.
  4. Sony GTK-XB5 Surge Fuse Replacement: passo 4, immagine 1 di 2 Sony GTK-XB5 Surge Fuse Replacement: passo 4, immagine 2 di 2
    • Additionally, the sides need to be taken apart. You will need to take out 4 additional 7.5 mm Phillips-head screws on either side. These screws are located beneath larger grey pads with adhesive on them at the side corners of your speaker.
    • Remove the pads slowly, as the adhesive makes them tougher to remove and you do not want to rip them.
    • Use an opening tool to help take out the side shell from the rest of the speaker.
    • This step can be difficult to perform and do not hesitate to use some force, there are no delicate components on the immediate underside of the side panel.
  5. Sony GTK-XB5 Surge Fuse Replacement: passo 5, immagine 1 di 1
    • The speaker should now be stripped of its basic shell except for the bottom and front panels.
    • You have now disassembled the top casing of your speaker and you are prepared to make replacements of components!
  6. Sony GTK-XB5 Surge Fuse Replacement, Daughterboard: passo 6, immagine 1 di 1
    • Find the gold-yellow daughterboard, located underneath the top plastic housing of the speaker.
  7. Sony GTK-XB5 Surge Fuse Replacement: passo 7, immagine 1 di 1
    • Remove the belt connecting the daughterboard to the motherboard by gently removing the yellow clip from its housing on the motherboard.
    • The belt can only be disconnected from the motherboard side of the connection.
  8. Sony GTK-XB5 Surge Fuse Replacement: passo 8, immagine 1 di 1
    • Remove the four 6.4mm phillips head screws located at each corner of the daughterboard with a Phillips head screwdriver.
  9. Sony GTK-XB5 Surge Fuse Replacement: passo 9, immagine 1 di 2 Sony GTK-XB5 Surge Fuse Replacement: passo 9, immagine 2 di 2
    • Gently slide the entire daughterboard towards the frontside of the speaker, unhooking it from the prong that keeps it in place.
    • The daughterboard is free to be fully removed. You are now prepared to replace or make replacements components on the daughterboard!
  10. Sony GTK-XB5 Surge Fuse Replacement, Surge Fuse: passo 10, immagine 1 di 2 Sony GTK-XB5 Surge Fuse Replacement, Surge Fuse: passo 10, immagine 2 di 2
    • Flip the daughterboard over and desolder the fuse from it's position on the circuit. If you would like more information on the technique to soldering, refer to this link.
    • You are now prepared to replace the surge fuse in your speaker!
  11. Sony GTK-XB5 Surge Fuse Replacement: passo 11, immagine 1 di 1
    • Solder new component onto motherboard
    • Evaluate soldering and desoldering techniques by looking up tutorials on each process to ensure best results
Conclusione
Altre 7 persone hanno completato questa guida.
Tim Meagher
Membro da: 02/14/17
447 Reputazione
2 Guide realizzate
Cal Poly, Team 9-3, Banghart Winter 2017 Membro di Cal Poly, Team 9-3, Banghart Winter 2017
CPSU-BANGHART-W17S9G3
4 Membri
6 Guide realizzate
8 Commenti
does anyone knows where can I buy the surge fuse for my Sony speaker
Eduardo - Replica
Does anyone knows where I can buy the surge fuse for my Sony Bluetooth speaker
Eduardo - Replica
T315A250V fuse
Eduardo - Replica
Did you have any look finding fuse i need 1 myself
Richard Sanders -
I checked my fuse with a meter and it seems to be fine. No signs of a blow out…
I have no power to power, bluetooth or party chain buttons. However, the lights button to turn the light demo on and off does work.
Any ideas?
Jesse Vogelgesang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 118
Tutti i Tempi: 31,282
