Salta al contenuto principale
Sony DSC-RX10M3 Viewfinder Replacement
Cosa ti serve
    1. Sony DSC-RX10M3 Viewfinder Replacement, Back and Right Panel: passo 1, immagine 1 di 1
      • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony DSC-RX10M3 Viewfinder Replacement: passo 2, immagine 1 di 2 Sony DSC-RX10M3 Viewfinder Replacement: passo 2, immagine 2 di 2
      • Remove the two 0.7mm screws that secure the right side of the camera.
      • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
      Chiedi a FixBot
      Aggiungi Commento
    3. Sony DSC-RX10M3 Viewfinder Replacement: passo 3, immagine 1 di 2 Sony DSC-RX10M3 Viewfinder Replacement: passo 3, immagine 2 di 2
      • Gently pull off the plastic eye guard.
      Chiedi a FixBot
      Aggiungi Commento
    4. Sony DSC-RX10M3 Viewfinder Replacement: passo 4, immagine 1 di 2 Sony DSC-RX10M3 Viewfinder Replacement: passo 4, immagine 2 di 2
      • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
      • Use a plastic opening tool to detach the back panel of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    5. Sony DSC-RX10M3 Viewfinder Replacement: passo 5, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • This is a tight spot; make sure you use minimal force when removing the cover.
      • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    6. Sony DSC-RX10M3 Viewfinder Replacement: passo 6, immagine 1 di 1
      • This step is only needed if you wish to remove the right side panel.
      • Use a plastic openeing tool to gently detach the right panel.
      Chiedi a FixBot
      Aggiungi Commento
    1. Sony DSC-RX10M3 Viewfinder Replacement, Viewfinder: passo 7, immagine 1 di 1
      • Using a Phillips #000 screwdriver, remove the silver 0.5mm screw.
      Chiedi a FixBot
      Aggiungi Commento
    2. Sony DSC-RX10M3 Viewfinder Replacement: passo 8, immagine 1 di 1
      • Use tweezers to detach the ribbon cable from the motherboard.
      • Use upward force when removing the ribbon cable.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 13
Ultimi 30 giorni: 64
Tutti i Tempi: 2,009
