Salta al contenuto principale
Sony DSC-RX10M3 Back and Right Panel Replacement
Cosa ti serve
  1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
    Chiedi a FixBot
    Aggiungi Commento
  2. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, immagine 1 di 3 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, immagine 2 di 3 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, immagine 3 di 3
    • Remove the battery located at the bottom of the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: passo 3, immagine 1 di 1
    • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
    Chiedi a FixBot
    Aggiungi Commento
  4. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 4, immagine 1 di 2 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 4, immagine 2 di 2
    • Remove the two 0.7mm screws that secure the right side of the camera.
    • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
    Chiedi a FixBot
    Aggiungi Commento
  5. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 5, immagine 1 di 2 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 5, immagine 2 di 2
    • Gently pull off the plastic eye guard.
    Chiedi a FixBot
    Aggiungi Commento
  6. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 6, immagine 1 di 2 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
    • Use a plastic opening tool to detach the back panel of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  7. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 7, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • This is a tight spot; make sure you use minimal force when removing the cover.
    • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  8. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 8, immagine 1 di 1
    • This step is only needed if you wish to remove the right side panel.
    • Use a plastic openeing tool to gently detach the right panel.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 16
Ultimi 30 giorni: 68
Tutti i Tempi: 1,921
