Salta al contenuto principale
Solio CLASSIC2 LED Light Replacement
Cosa ti serve
    1. Solio CLASSIC2 LED Light Replacement, Disconnecting the Battery: passo 1, immagine 1 di 1
      • Turn off the device by pressing on the clear power button behind the device.
      • To make sure that it is off, make sure the button is not flashing green.
      Chiedi a FixBot
      Aggiungi Commento
    2. Solio CLASSIC2 LED Light Replacement: passo 2, immagine 1 di 1
      • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
      Chiedi a FixBot
      Aggiungi Commento
    3. Solio CLASSIC2 LED Light Replacement: passo 3, immagine 1 di 3 Solio CLASSIC2 LED Light Replacement: passo 3, immagine 2 di 3 Solio CLASSIC2 LED Light Replacement: passo 3, immagine 3 di 3
      • Using the plastic opening tools, gently pry open the side of the large panel.
      • Keeping the tool in, slowly slide the tool along the side of the panel.
      Chiedi a FixBot
      Aggiungi Commento
    4. Solio CLASSIC2 LED Light Replacement: passo 4, immagine 1 di 2 Solio CLASSIC2 LED Light Replacement: passo 4, immagine 2 di 2
      • Rotate the device 180 degrees.
      • Make sure the opening on other side of the device does not snap closed.
      • Gently slide the plastic opening tool along the side of the panel.
      Chiedi a FixBot
      Aggiungi Commento
    5. Solio CLASSIC2 LED Light Replacement: passo 5, immagine 1 di 2 Solio CLASSIC2 LED Light Replacement: passo 5, immagine 2 di 2
      • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
      • Using both hands, slowly pull apart the back panel from the rest of the device.
      • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
      Chiedi a FixBot
      Aggiungi Commento
    6. Solio CLASSIC2 LED Light Replacement: passo 6, immagine 1 di 2 Solio CLASSIC2 LED Light Replacement: passo 6, immagine 2 di 2
      • Softly pinch the red and blue wires close to the white connector.
      • To pull the wires out, wiggle them back and forth until the connector is fully out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Solio CLASSIC2 LED Light Replacement, Circuit Board: passo 7, immagine 1 di 1
      • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Solio CLASSIC2 LED Light Replacement: passo 8, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
      • Gently lift the circuit board out of the device using tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    1. Solio CLASSIC2 LED Light Replacement, LED Light: passo 9, immagine 1 di 1
      • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attemptingDesolder the LED lights.
      • Desolder the LED lights.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 4-28, Amido Fall 2013 Membro di Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Membri
22 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 25
Tutti i Tempi: 619
