Introduzione
To replace a broken wire connected to the circuit board, soldering must be done. Before attempting this guide, please read the IFixit's guide to soldering (Come saldare e dissaldare componenti elettrici). For this replacement, perform all steps on a table away from any flammable objects.
Cosa ti serve
Turn off the device by pressing on the clear power button behind the device.
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
Using a solder iron with a fine tip, slowly solder off the broken wire from the first connection point.
Repeat for other connection point of wire.
