Salta al contenuto principale
Samsung WB35F Flash Capacitor Replacement
Cosa ti serve
  1. Samsung WB35F Flash Capacitor Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung WB35F Flash Capacitor Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung WB35F Flash Capacitor Replacement, Rear Case: passo 1, immagine 3 di 3
    • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
    • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung WB35F Flash Capacitor Replacement: passo 2, immagine 1 di 2 Samsung WB35F Flash Capacitor Replacement: passo 2, immagine 2 di 2
    • Using the spudger, and plastic opening tool open the casing of camera.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung WB35F Flash Capacitor Replacement: passo 3, immagine 1 di 3 Samsung WB35F Flash Capacitor Replacement: passo 3, immagine 2 di 3 Samsung WB35F Flash Capacitor Replacement: passo 3, immagine 3 di 3
    • Once you open the camera case, you will be able to work on any part of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung WB35F Flash Capacitor Replacement, Flash Capacitor: passo 4, immagine 1 di 2 Samsung WB35F Flash Capacitor Replacement, Flash Capacitor: passo 4, immagine 2 di 2
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Carefully take out the capacitor using the spudger.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung WB35F Flash Capacitor Replacement: passo 5, immagine 1 di 1
    • Disconnect the wire from battery and replace the old battery with new battery.
    • Connect the wires to new battery and put the battery back in terminal.
    • Connect the positive wire to the positive terminal of the battery and negative wire to the the negative terminal of the battery.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 1-6, Tanski Winter 2015 Membro di USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 49
Tutti i Tempi: 2,758
