Salta al contenuto principale
Samsung Refrigerator Control Board Replacement
Cosa ti serve
  1. Samsung Refrigerator Control Board Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Refrigerator Control Board Replacement, Remove the board access panel: passo 2, immagine 1 di 1
    • Remove the screws securing the board access panel to the back of the refrigerator.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Refrigerator Control Board Replacement: passo 3, immagine 1 di 2 Samsung Refrigerator Control Board Replacement: passo 3, immagine 2 di 2
    • Remove the board access panel.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Refrigerator Control Board Replacement, Reassembly information: passo 4, immagine 1 di 2 Samsung Refrigerator Control Board Replacement, Reassembly information: passo 4, immagine 2 di 2
    • Note the locations and number of the connectors on the control board, and photograph them or draw a diagram. This example control board has nine wire connectors:
    • Three connectors along the top edge
    • One connector along the right edge
    • One connector along the bottom edge
    • Four connectors along the left edge
    • During reassembly, use your diagram or the photo you took (like the second image here) to make sure you've reconnected all of the connectors.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Refrigerator Control Board Replacement, Remove the control board: passo 5, immagine 1 di 2 Samsung Refrigerator Control Board Replacement, Remove the control board: passo 5, immagine 2 di 2
    • Pull and disconnect each of the connectors from the control board.
    • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
    • Move the wires away from the control board so it can swing out of its recess.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Refrigerator Control Board Replacement: passo 6, immagine 1 di 3 Samsung Refrigerator Control Board Replacement: passo 6, immagine 2 di 3 Samsung Refrigerator Control Board Replacement: passo 6, immagine 3 di 3
    • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
    • Swing the control board out and remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Ask our Answers Community for help.
Altre 2 persone hanno completato questa guida.
Bill Gilbert
Membro da: 06/30/22
40.137 Reputazione
261 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
28.236 guide realizzate
5Commenti sulla guida
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Carolyn whittaker - Rispondi Condividi
Is this Samsung
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
Sewell Nikki - Rispondi Condividi
My refrigerator light is on but the comppresor is not working and anytime I on it is not piping sounds again
Asiafa - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 74
Ultimi 30 giorni: 396
Tutti i Tempi: 8,879
