Salta al contenuto principale
Samsung Galaxy Watch3 Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Watch3 Battery Replacement, Unfasten the back cover screws: passo 1, immagine 1 di 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Samsung Galaxy Watch3 Battery Replacement, Wedge open the back cover: passo 2, immagine 1 di 2 Samsung Galaxy Watch3 Battery Replacement, Wedge open the back cover: passo 2, immagine 2 di 2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: passo 3, immagine 1 di 3 Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: passo 3, immagine 2 di 3 Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: passo 3, immagine 3 di 3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Samsung Galaxy Watch3 Battery Replacement, Remove the back cover: passo 4, immagine 1 di 2 Samsung Galaxy Watch3 Battery Replacement, Remove the back cover: passo 4, immagine 2 di 2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
  5. Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: passo 5, immagine 1 di 3 Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: passo 5, immagine 2 di 3 Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: passo 5, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
  6. Samsung Galaxy Watch3 Battery Replacement, Unfasten the motherboard screw: passo 6, immagine 1 di 1
    • Remove the Phillips #00 screw.
  7. Samsung Galaxy Watch3 Battery Replacement, Remove the motherboard: passo 7, immagine 1 di 2 Samsung Galaxy Watch3 Battery Replacement, Remove the motherboard: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • The motherboard is held in place by two small plastic clips.
    • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
    • Remove the motherboard.
  8. Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: passo 8, immagine 1 di 3 Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: passo 8, immagine 2 di 3 Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: passo 8, immagine 3 di 3
    • Place the flat end of a supdger in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • The battery is adhered to the core with light adhesive, so take your time.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core.
  9. Samsung Galaxy Watch3 Battery Replacement, Remove the battery: passo 9, immagine 1 di 2 Samsung Galaxy Watch3 Battery Replacement, Remove the battery: passo 9, immagine 2 di 2
    Tesa 61395 Tape
    $5.99
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not replace it with double sided or pre-cut adhesive tape.
    • Remove the battery.
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Altre 21 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 03/31/14
124.320 Reputazione
189 Guide realizzate
17Commenti sulla guida
Once I had the correct tools and replacement battery, fixing was easy. Tyvm!
Jeremy Salazar - Replica
One question, where can I find an authorized battery for this watch? or one that you highly recommend. Thanks.
**Edit - Your store doesn’t have a 45mm battery for my Galaxy Watch 3. Only 42 and 46.
Gilberto Garcia - Replica
The 42 and 46 mm models are the first Galaxy Watch sizes. We ’re working on getting the Watch3 batteries and parts but it may take some time.
Tobias Isakeit -
Hi, is it possible to put the battery from samsung watch 472mAh, on samsung watch 3, instead of 340mAh?
Andrey Irnazarov - Replica
Hi Andrey, short answer is no—although basically a good idea. But even if you cut the battery contact plate to fit (cut off the part with the alignment hole) its polarity is inverted. The Watch3 contact plate has -/+ (noted under the cable) whereas the original has +/-. Also the original Galaxy Watch battery is much bigger than the one in the Watch3. So it won’t fit inside the recess. Here is an image with the Watch3 battery on top of the original battery.
Tobias Isakeit -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 147
Ultimi 30 Giorni: 844
Tutti i Tempi: 41,968
