Introduzione
Follow this guide to remove and replace the motherboard for the Galaxy S10+.
The hardest part of this guide is removing the back cover from the phone.
Cosa ti serve
Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
Press firmly to eject the tray.
Remove the SIM card tray.
Unplug and power off your phone before you begin.
Heat an iOpener and apply it to the back cover's right edge for two minutes.
As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
I can’t get the back cover to seperate, I’ve been trying for several hours now, it just stays with the rest of the phone. I’m fairly certain my phone is hot enough as I touched the back and I can’t place my hand there for more than a few seconds at a time. It’s just not coming off and I’m so frustrated! Any help?
Hi Fiona,
The back adhesive can be very difficult! Have you tried the suggestions in step 3? It may take a few heat cycles to weaken the adhesive. You can use a hairdryer to heat it pretty hot along the edge.
My back cover glass is shattered but not coming apart! What do I do?
I was able to use my fingernails first (with the assistance of the suction cup) to get in the gap, and then, with my fingernails still in the gap there was enough room to put in the pick. I couldn't get the pick in there by itself even after 10 minutes of warming and suction cup prying... but my fingernails could get in, and then I used them to hold the space open and pull a little more so the pick could be inserted.
Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
Press the edge of an opening tool into the seam between the back cover and the frame.
Slide the opening tool back and forth along the seam a few times.
Slide the opening pick along the edge of the phone, slicing through the adhesive.
Leave a pick in the seam to prevent the adhesive from re-sealing.
Remove the nine 4 mm Phillips screws securing the top midframe to the phone.
Lift the midframe from the top corners and remove it from the phone.
Align the midframe's top edge to the phone and lay the frame down on the phone.
Use fingers to apply pressure along the midframe perimeter to snap the midframe clips back into place. The edges should sit flush against the phone edge.
Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
Pry upwards to disconnect the connector from its socket.
Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
Remove the seven 4 mm Phillips screws securing the lower midframe to the phone.
Use the flat end of a spudger to pry up and disconnect the display connector from its motherboard socket, located near the bottom right corner of the phone.
Remove the three Phillips screws securing the motherboard to the phone:
One 3.8 mm screw
Two 3.7 mm screws
Using your fingers, grasp the motherboard by the top corners.
Lift the motherboard edge slightly out of its recess. Be careful not to snag any cables along the way.
Pull the motherboard towards the top edge of the phone while wiggling the board slightly. This will loosen the charging port from its socket.
Once the charging port is freed from its socket, remove the motherboard.
Gently push the motherboard against the bottom edge of the phone until the charging port is completely seated.
Lower the motherboard and press into place. Be careful not to trap any cables underneath the motherboard. The board should sit flush against the frame.
After you've completed the repair, follow this guide to test your repair.
Altre 17 persone hanno completato questa guida.
7 Commenti
Samsung S10 Plus motherboard need
you can try to order from E bay
How does changing the motherboard of a Samsung S10 plus affect its functionality?
So, I have owned multiple phones in my life and some of them had two doors, one for the Sim, one for the SD card. As it was darkish where I was installing the SD & SIM card, this is what I assumed my S10 plus 1tb had, and I poked a paper clip into the microphone hole and when it didn't open I pushed harder not realizing that it was the microphone. Some research that I've done says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true(I hope it is!) ? I don't want to have to take apart my phone if I don't have to, to replace the microphone or God forbid the motherboard to replace one small component. Come on Samsung, is this planned obsolescence?
Lin Car - Replica
Hi Lin,
Good question! I took apart our S10 and that is indeed true! Inserting the SIM eject tool into the top microphone hole shouldn’t damage your microphone, or compromise water resistance.
Here is a photo reference. The microphone hole is just an L-shaped tunnel drilled into the frame. At the end of the “L”, it is sealed by a thin waterproof gasket (red circle). The microphone is actually built into the motherboard (orange circle), which is pressed against this gasket. Sound is able to transfer across the thin gasket, but this design also allows it to be waterproof.
I will edit the steps to reflect this information. Thanks for the heads up!
Arthur Shi -
