Salta al contenuto principale
Samsung Galaxy Note10 Daughterboard Replacement
Cosa ti serve
  1. Samsung Galaxy Note10 Daughterboard Replacement, Heat the back panel: passo 1, immagine 1 di 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Chiedi a FixBot
  2. Samsung Galaxy Note10 Daughterboard Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Chiedi a FixBot
  3. Samsung Galaxy Note10 Daughterboard Replacement, Begin to slice the adhesive: passo 3, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Begin to slice the adhesive: passo 3, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Begin to slice the adhesive: passo 3, immagine 3 di 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
  4. Samsung Galaxy Note10 Daughterboard Replacement, Slice the left side adhesive: passo 4, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Slice the left side adhesive: passo 4, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Slice the left side adhesive: passo 4, immagine 3 di 3
    • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
  5. Samsung Galaxy Note10 Daughterboard Replacement, Slice the top side adhesive: passo 5, immagine 1 di 1
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
    Chiedi a FixBot
  6. Samsung Galaxy Note10 Daughterboard Replacement: passo 6, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement: passo 6, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement: passo 6, immagine 3 di 3
    • Insert a third opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
    Chiedi a FixBot
  7. Samsung Galaxy Note10 Daughterboard Replacement, Slice the right side adhesive: passo 7, immagine 1 di 1
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
    Chiedi a FixBot
  8. Samsung Galaxy Note10 Daughterboard Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Note10 Daughterboard Replacement: passo 8, immagine 2 di 2
    • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
    • The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
    Chiedi a FixBot
  9. Samsung Galaxy Note10 Daughterboard Replacement, Lift off the back panel: passo 9, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Lift off the back panel: passo 9, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Lift off the back panel: passo 9, immagine 3 di 3
    • Lift up and remove the back panel.
    Chiedi a FixBot
  10. Samsung Galaxy Note10 Daughterboard Replacement, Lift up the metal cover: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
    Chiedi a FixBot
  11. Samsung Galaxy Note10 Daughterboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement: passo 11, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
    Chiedi a FixBot
  12. Samsung Galaxy Note10 Daughterboard Replacement, Disconnect the battery: passo 12, immagine 1 di 2 Samsung Galaxy Note10 Daughterboard Replacement, Disconnect the battery: passo 12, immagine 2 di 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
    Chiedi a FixBot
  13. Samsung Galaxy Note10 Daughterboard Replacement, Disconnect the wireless charging coil: passo 13, immagine 1 di 2 Samsung Galaxy Note10 Daughterboard Replacement, Disconnect the wireless charging coil: passo 13, immagine 2 di 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    Chiedi a FixBot
  14. Samsung Galaxy Note10 Daughterboard Replacement, Remove the wireless charging coil: passo 14, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Remove the wireless charging coil: passo 14, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Remove the wireless charging coil: passo 14, immagine 3 di 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
    Chiedi a FixBot
  15. Samsung Galaxy Note10 Daughterboard Replacement, Remove the loudspeaker screws: passo 15, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
    Chiedi a FixBot
  16. Samsung Galaxy Note10 Daughterboard Replacement, Remove the loudspeaker: passo 16, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Remove the loudspeaker: passo 16, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Remove the loudspeaker: passo 16, immagine 3 di 3
    • Use a pair of tweezers to remove the loudspeaker.
    Chiedi a FixBot
  17. Samsung Galaxy Note10 Daughterboard Replacement, Remove the interconnect cables: passo 17, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Remove the interconnect cables: passo 17, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement, Remove the interconnect cables: passo 17, immagine 3 di 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
    Chiedi a FixBot
  18. Samsung Galaxy Note10 Daughterboard Replacement: passo 18, immagine 1 di 3 Samsung Galaxy Note10 Daughterboard Replacement: passo 18, immagine 2 di 3 Samsung Galaxy Note10 Daughterboard Replacement: passo 18, immagine 3 di 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
    Chiedi a FixBot
  19. Samsung Galaxy Note10 Daughterboard Replacement: passo 19, immagine 1 di 2 Samsung Galaxy Note10 Daughterboard Replacement: passo 19, immagine 2 di 2
    • Remove both interconnect cables.
    Chiedi a FixBot
  20. Samsung Galaxy Note10 Daughterboard Replacement, Daughterboard: passo 20, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 4 mm screws securing the charging assembly.
    Chiedi a FixBot
  21. Samsung Galaxy Note10 Daughterboard Replacement: passo 21, immagine 1 di 2 Samsung Galaxy Note10 Daughterboard Replacement: passo 21, immagine 2 di 2
    • Use a pair of tweezers to lift up and remove the daughterboard.
    Chiedi a FixBot
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 3 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
164.714 Reputazione
439 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
25.718 guide realizzate
2Commenti sulla guida
thank you my friend
العندليب الأسمر - Rispondi Condividi
Works like a charm with the Note10+ as well.
sultandx - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 17
Ultimi 30 giorni: 113
Tutti i Tempi: 4,850
