Introduzione
Use this guide to replace the loudspeaker on your Samsung Galaxy A52.
You’ll need replacement adhesive to reattach components when reassembling the device. If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
Cosa ti serve
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in its place to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the ten 4.4 mm-long screws securing the motherboard cover.
Insert an opening pick underneath the left edge of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the six 4.4 mm-long screws securing the loudspeaker assembly.
Insert the pointed end of a spudger into the gap on the right edge of the loudspeaker assembly.
Pry up the loudspeaker assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Altre 3 persone hanno completato questa guida.
1Commento della guida
Excellent and very detailed tutorial thank you! Do you know what the impedance of the loudspeaker should normally be? After changing the charging port and reassembling my phone the loudspeaker is not working anymore. Many thanks in advance. Emmanuel
