Salta al contenuto principale
Ryobi CSB125 Power Cord Replacement
Cosa ti serve
    1. Ryobi CSB125 Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
      • Place the saw down on a flat surface with the motor facing up.
      • Make sure that the saw is unplugged from any power source.
      Chiedi a FixBot
      Aggiungi Commento
    2. Ryobi CSB125 Power Cord Replacement: passo 2, immagine 1 di 2 Ryobi CSB125 Power Cord Replacement: passo 2, immagine 2 di 2
      • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. Ryobi CSB125 Power Cord Replacement: passo 3, immagine 1 di 1
      • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    4. Ryobi CSB125 Power Cord Replacement: passo 4, immagine 1 di 2 Ryobi CSB125 Power Cord Replacement: passo 4, immagine 2 di 2
      • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
      • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
      • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
      Chiedi a FixBot
      Aggiungi Commento
    5. Ryobi CSB125 Power Cord Replacement: passo 5, immagine 1 di 1
      • Remove the plug from the saw.
      • You may have to use the wire strippers to expose the copper on the new plug.
      • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Curtis Melo
Membro da: 10/31/19
1.093 Reputazione
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 28
Tutti i Tempi: 2,267
