Salta al contenuto principale
Razer DeathAdder V3 Pro Encoder Replacement
Cosa ti serve
  1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: passo 1, immagine 1 di 3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: passo 1, immagine 2 di 3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: passo 1, immagine 3 di 3
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Razer DeathAdder V3 Pro Encoder Replacement: passo 2, immagine 1 di 2 Razer DeathAdder V3 Pro Encoder Replacement: passo 2, immagine 2 di 2
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    Chiedi a FixBot
    Aggiungi Commento
  3. Razer DeathAdder V3 Pro Encoder Replacement: passo 3, immagine 1 di 2 Razer DeathAdder V3 Pro Encoder Replacement: passo 3, immagine 2 di 2
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    Chiedi a FixBot
    Aggiungi Commento
  4. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: passo 4, immagine 1 di 1
    • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
    • Unplug the battery from its connection on the right side.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  5. Razer DeathAdder V3 Pro Encoder Replacement: passo 5, immagine 1 di 1
    • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
    Chiedi a FixBot
    Aggiungi Commento
  6. Razer DeathAdder V3 Pro Encoder Replacement: passo 6, immagine 1 di 2 Razer DeathAdder V3 Pro Encoder Replacement: passo 6, immagine 2 di 2
    • Wear eye protection.
    • Take care not to damage the PCB or any other components.
    • Use a pair of flush cutters to cut the legs of the encoder.
    • Desolder the legs of the 15 mm encoder on the underside of the PCB.
    • Remove the encoder.
    • Always solder in a well ventilated area.
    • Use a solder sucker to remove any excess solder.
    Chiedi a FixBot
    Aggiungi Commento
  7. Razer DeathAdder V3 Pro Encoder Replacement: passo 7, immagine 1 di 1
    • Press the new 15 mm encoder into place
    • If the encoder does not fit properly, clean the old solder more thoroughly.
    • Solder the new 15 mm encoder into place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Nicholas
Membro da: 09/24/25
453 Reputazione
4 guide realizzate
Texas Tech, Team 2-5, Johansen Fall 2025 Membro di Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 59
Ultimi 30 giorni: 269
Tutti i Tempi: 1,308
