Salta al contenuto principale
PowerBook G3 Pismo RAM Replacement
Cosa ti serve
  1. PowerBook G3 Pismo RAM Replacement, Keyboard: passo 1, immagine 1 di 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Chiedi a FixBot
    Aggiungi Commento
  2. PowerBook G3 Pismo RAM Replacement: passo 2, immagine 1 di 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Chiedi a FixBot
    Aggiungi Commento
  3. PowerBook G3 Pismo RAM Replacement: passo 3, immagine 1 di 1
    • Your laptop should look approximately like this.
    Chiedi a FixBot
    Aggiungi Commento
  4. PowerBook G3 Pismo RAM Replacement, Heat Shield: passo 4, immagine 1 di 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Chiedi a FixBot
    Aggiungi Commento
  5. PowerBook G3 Pismo RAM Replacement: passo 5, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  6. PowerBook G3 Pismo RAM Replacement, Airport Card: passo 6, immagine 1 di 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Chiedi a FixBot
    Aggiungi Commento
  7. PowerBook G3 Pismo RAM Replacement: passo 7, immagine 1 di 1
    • Disconnect the antenna cable from the Airport card.
    Chiedi a FixBot
    Aggiungi Commento
  8. PowerBook G3 Pismo RAM Replacement, PRAM Battery: passo 8, immagine 1 di 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    Chiedi a FixBot
    Aggiungi Commento
  9. PowerBook G3 Pismo RAM Replacement: passo 9, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  10. PowerBook G3 Pismo RAM Replacement, Heat Sink: passo 10, immagine 1 di 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Chiedi a FixBot
    Aggiungi Commento
  11. PowerBook G3 Pismo RAM Replacement: passo 11, immagine 1 di 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Chiedi a FixBot
    Aggiungi Commento
  12. PowerBook G3 Pismo RAM Replacement, Processor: passo 12, immagine 1 di 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Chiedi a FixBot
    Aggiungi Commento
  13. PowerBook G3 Pismo RAM Replacement: passo 13, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  14. PowerBook G3 Pismo RAM Replacement, RAM: passo 14, immagine 1 di 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • There are RAM slots on both sides of the processor. We recommend installing higher capacity chips on the bottom so that if you want to upgrade later, you won't have to remove the processor.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 16 persone hanno completato questa guida.
Documenti allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
1Commento della guida
Way too many steps in my opinion. First, the battery should be removed. I saw no reason to remove keyboard, folding it over was enough. Also, saw no reason to remove PRAM battery, I did disconnect it, however. The AirPort card didn’t have to be removed, either. Once the shield was removed along with the heatsink, the processor board just popped right out. When replacing board, make sure the little tabs are in their slots since the board won’t push back in all of the way. Thanks iRobot!
pjmrozinski - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 53
Tutti i Tempi: 17,788
