Salta al contenuto principale
Pentax Super Program Front Block Functional Check
  1. Pentax Super Program Front Block Functional Check, Prepare the front block: passo 1, immagine 1 di 3 Pentax Super Program Front Block Functional Check, Prepare the front block: passo 1, immagine 2 di 3 Pentax Super Program Front Block Functional Check, Prepare the front block: passo 1, immagine 3 di 3
    • Connect a lead wire to the main flex PCB to supply battery power (early production).
    • Connect a lead wire to the main flex PCB to supply battery power (late production).
    • Make a ground connection to the body of the camera.
    Chiedi a FixBot
    Aggiungi Commento
  2. Pentax Super Program Front Block Functional Check, Prepare the mode dial: passo 2, immagine 1 di 2 Pentax Super Program Front Block Functional Check, Prepare the mode dial: passo 2, immagine 2 di 2
    • Ground the mode dial plate to the chassis of the front block.
    • Move the mode dial to the 'M' position.
    • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
    Chiedi a FixBot
    Aggiungi Commento
  3. Pentax Super Program Front Block Functional Check, Check power to the front block: passo 3, immagine 1 di 2 Pentax Super Program Front Block Functional Check, Check power to the front block: passo 3, immagine 2 di 2
    • Use a source of 2.8 V to power the front block, the lowest battery voltage that the camera should operate at.
    • If an external power supply is not available, use fresh batteries to supply power.
    • Check the voltage at these locations to make sure that power is getting to all of the components.
    Chiedi a FixBot
    Aggiungi Commento
  4. Pentax Super Program Front Block Functional Check, Check the main shutter release: passo 4, immagine 1 di 3 Pentax Super Program Front Block Functional Check, Check the main shutter release: passo 4, immagine 2 di 3 Pentax Super Program Front Block Functional Check, Check the main shutter release: passo 4, immagine 3 di 3
    • Charge the mirror mechanism.
    • Press the shutter button. The mirror should release and flip up into the taking position.
    • Push the mirror return latch to flip the mirror down into the viewing position (the shutter would trigger this mechanism when the camera is fully assembled).
    Chiedi a FixBot
    Aggiungi Commento
  5. Pentax Super Program Front Block Functional Check, Check the self-timer: passo 5, immagine 1 di 2 Pentax Super Program Front Block Functional Check, Check the self-timer: passo 5, immagine 2 di 2
    • Pull out the tab on the self-timer switch.
    • Press the shutter release button.
    • The self-timer led should blink and the buzzer should sound.
    • After ten seconds, the mirror should flip up.
    Chiedi a FixBot
    Aggiungi Commento
  6. Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: passo 6, immagine 1 di 2 Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: passo 6, immagine 2 di 2
    • Ground this pad to release the shutter (early production).
    • Ground this pad to release the shutter (late production).
    • This is the signal that the accessory motor drive uses to fire the shutter. It's also a useful alternative if you think there is an issue with the main shutter release.
    Chiedi a FixBot
    Aggiungi Commento
    • Mount a lens on the front block. Set the aperture ring to 'A'.
    • Point the front block at scenes with varying brightness. Check that the aperture value in the viewfinder display changes accordingly.
    Chiedi a FixBot
    Aggiungi Commento
  7. Pentax Super Program Front Block Functional Check, Check viewfinder backlight: passo 8, immagine 1 di 2 Pentax Super Program Front Block Functional Check, Check viewfinder backlight: passo 8, immagine 2 di 2
    • Cover the ambient light panel for the viewfinder displays.
    • Press viewfinder light button on the side of the lens mount.
    • The displays at the bottom of the viewfinder should light up.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Sam Gustafson
Membro da: 09/01/22
14.384 Reputazione
78 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 33
Tutti i Tempi: 131
